I see stuff switched to v17? I take it the code isnt going to make it into v17. Currently the most recent build broke tvheadend-pvr-addon for me.
19:39:36 T:140025801541760 NOTICE: PVRManager - stopping
19:39:36 T:140024667367168 NOTICE: PVRManager - starting up
19:39:36 T:140024188237568 ERROR: PVR - Add-on 'Tvheadend HTSP Client' is using an incompatible GUI API version. XBMC minimum GUI API version = '5.10.0', add-on GUI API version '5.8.0'
19:39:36 T:140024188237568 WARNING: UpdateAndInitialiseClients - failed to create add-on Tvheadend HTSP Client, status = 6
19:39:36 T:140024188237568 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on Tvheadend HTSP Client, disabling it
19:40:03 T:140025801541760 ERROR: GetDirectory - Error getting addons://disabled/xbmc.pvrclient
19:40:03 T:140025801541760 ERROR: CGUIMediaWindow::GetDirectory(addons://disabled/xbmc.pvrclient) failed
Add-on version is 2.2.9
I reverted to v16 for now. Im back to football (soccer)
I downloaded the correct debs from the ppa and did a dpkg -i kodi* ..
wget http://ppa.launchpad.net/wsnipex/xbmc-fernetmenta-master/ubuntu/pool/main/k/kodi/kodi-bin_16.0~git20151206.0500-a99657f-0wily_amd64.deb
wget http://ppa.launchpad.net/wsnipex/xbmc-fernetmenta-master/ubuntu/pool/main/k/kodi/kodi_16.0~git20151206.0500-a99657f-0wily_all.deb
dpkg -i kodi*.deb
ppa build has failed tonight, too the reason is known <- the official one. Fernet's has that fix - though same addon issues.
I uploaded another release for updating for the OpenELEC version. This includes the latest pvr version. Some addons - like hts were not (!) updated upstream, so they won't work ... until their maintainer fixes them.
Openvpn needs an update too.
Quote:openvpn: error while loading shared libraries: libssl.so.35: cannot open shared object file: No such file or directory
Milhouse included an updated version for his build via his addons folder, but it has a dependency issue on your latest build.
Yeah - I won't as I don't care. I don't do the OE bumpery and keep what I have as master. Therefore most of the unofficial addons that need rebuild won't work anymore.
No worries.
Other than the vpn and my bleedin remote (not your fault, I even compiled the latest openelec version 7 for myself and it exists there too.) the latest version you loaded seems to be working fine.
Edit: Update. lrusak has released a repository with openvpn updated for newer versions. If people are needing it or what not. Details are at the openelec forum.
Thanks for that feedback.
Perhaps I need to explain something: OE is bumping everything they can find. Proper testing does most of the time not happen. When I want to test videoplayer in that thread here I cannot afford to also debug upstream breakage of packages no one would have any interest in bumping at all.
I will bump kernel to 4.4 cause of intel fixes soon. I will also bump libva / libva-driver-intel as it has patches for broxton. But the rest - I just keep.
(2015-12-08, 21:31)fritsch Wrote: [ -> ]Perhaps I need to explain something: OE is bumping everything they can find. Proper testing does most of the time not happen. When I want to test videoplayer in that thread here I cannot afford to also debug upstream breakage of packages no one would have any interest in bumping at all.
Yeah, it's a PITA to be sure.
With my RPi and x86 builds closely tracking OE master, hopefully there will be a little more testing than usual, but also increased risk of breakage due to random bumps - I've uploaded the more common addons and I'm willing to upload others if suitably notified of the exact error (ie. "xyz addon doesn't work" will be ignored, but a specific error message from an actual log will most likely result in a new addon).
However anyone that wants a more stable build (with less add-on breakage) should stick with your releases.
@fritch: r21596 still have sync issue when passthrough is enabled.
New build is up - that will fix the passthrough issues (as good as it can). hts did not update upstream yet - so, yes - that still won't work.
pvr.hts should be alright now after the transifex bump
looks good after short test.
edit: the audio get after some time out of sync again. currently seen on "Das Erste".
