(2017-02-19, 20:55)gurabli Wrote: [ -> ]fritsch, maybe you can help me, ot is somewhat off here, but still. If avr is in standby passtrough mode, so audio is sent from Kodi to TV speakers, can I still use my TV remote to controll Kodi with CEC? I plan to buy a new AVR that has hdmi standby passtrough, but not sure if it passes the CEC commands to Kodi if AVR is not turned on.
Sent from Tapatalk from my Z5 Compact
CEC works with my yamaha rx-v473 when it is off.
Driver: has zero to do with Kodi. Was added for wsnipex ppa and 16.04, 16.10. Kodi is an application, not a os with drivers.
(2017-02-19, 21:03)fritsch Wrote: [ -> ]I don't know - never did something with CEC.
Sorry, I somewhat remembered you were using CEC, I was wrong then.
(2017-02-20, 03:35)teeedubb Wrote: [ -> ]CEC works with my yamaha rx-v473 when it is off.
Thanks teedubb, this is great to hear. The Denon should work then too!
Question: On the
PPA page of Wolfgang Schupp's "xbmc-fernetmenta-master", it states:
Quote:Current highlight:
play HEVC 4k@60p videos on intel braswell and skylake CPUs
Does that mean it is no longer necessary to build Kodi-agile from source, and use mesa drivers from Padoka PPA to achieve this?
What about proper HD pass-through support, it too is supported in this Ppa?
xbmc-fernetmenta-master is not updated anymore, everything is in mainline.
OK thanks. But is it true that "HEVC 4k@60p" is supported then, in mainline (unstable?) ?
No - it's not there. It's currently living in kodi-agile - inclusion of that work started yesterday with AudioEngine bits.
(2017-02-27, 12:14)fritsch Wrote: [ -> ]No - it's not there. It's currently living in kodi-agile - inclusion of that work started yesterday with AudioEngine bits.
Thanks for the clarification.
I've now installed latest mesa using Padoka PPA and built kodi-agile from scratch.. But, now I'm no longer able to reach Xserver. What is the correct forum to troubleshoot the use of these unofficial drivers, do you know?
www.ubuntuforums.org - a simple Xorg.0.log is required and you are allowed to take part in the party :-)
Good call, I'll try thanks!
(2017-02-27, 10:55)Axman Wrote: [ -> ]OK thanks. But is it true that "HEVC 4k@60p" is supported then, in mainline (unstable?) ?
Sorry for (possibly) lame question, but what about support for hardware decoding of HEVC 10-bit @ 24-30 FPS?
Changelog for Krypton, at Linux-specific section clearly states:
Quote:Added support for HEVC Main 10 profile (10-bit) hardware video decoding via VAAPI if hardware support it
The reason I ask is exactly related to this - I have a HEVC 10-bit sample, rated at 24 FPS and Krypton 17.1 RC on Ubuntu doesn't use H/W acceleration in this case, while my vainfo would suggest it should be able to do so (see profile VAProfileHEVCMain10):
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
H/W acceleration works for me on H264 FHD sources. Hardware: Asrock J3455-ITX.
Many thanks for clarification.
Changelog is wrong. It was 8bit at that time.
(2017-03-01, 11:36)Blechmann Wrote: [ -> ]Can someone help me ?
How did you install Kodi? Does `sudo systemctl start kodi` work for you from command line on TV?
Pls show output of `which kodi` and `cat <kodi-user-home-dir>/.config/openbox/autostart`
[i]How did you install Kodi? : According to the instructions of fritsch (Post 1)
Does `sudo systemctl start kodi` work for you from command line on TV? : No - remote from other terminal
Log:
kodi@homeserver:~/.kodi/temp$ which kodi
/usr/bin/kodi
kodi@homeserver:~/.kodi/temp$ cat /home/kodi/.config/openbox/autostart
OUTPUT=`xrandr -display :0 -q | sed '/ connected/!d;s/ .*//;q'`
xrandr -display :0 --output $OUTPUT --set "Broadcast RGB" "Full"
xsetroot #000000
devmon &
MALLOC_MMAP_THRESHOLD_=131072 /usr/bin/kodi --standalone
while [ $? -ne 0 ]; do
done
openbox --exit[/i]
Update: I have found my mistake /home/dir was encrypted.
Sorry
