I´ve jerky playback (skipped fr.) everytime forced PGS subs jump in with mkv (avatar).
Log:
http://sprunge.us/CFVK
(2016-03-06, 09:46)D-an-W Wrote: [ -> ]I now seem to be missing the OpenELEC menu from your latest build fritsch (Apologies if this is a known problem, I have been away!)?
The OpenELEC menu in Estuary is an upstream change not yet in fritsch's build.
(2015-07-12, 20:06)fritsch Wrote: [ -> ]1.) Now finally we install all the wsnipex goodies, which are mesa, libva and fernetmenta's egl rewrite:
sudo apt-add-repository ppa:wsnipex/vaapi
sudo apt-add-repository ppa:wsnipex/xbmc-fernetmenta-master
# the next one is needed for pvr addons
sudo apt-add-repository ppa:team-xbmc/xbmc-nightly
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install kodi kodi-bin
Just tried a fresh install with 15.10 server iso.
Do I still need to add both repos -> xbmc-fernetmenta-master AND xbmc-nightly ?
Because when I do , the kodi versions from fernetmenta-master will be replaced by the ones from the nightly.
Nevertheless I need the nightly because of the pvr-hts stuff.
you don't need the nightly ppa anymore, I've put the addons in the other ppa as well.
I found the projectm visualization on this ppa: team-xbmc/unstable.
It is woking with 17.0 EGL version?
wsnipex
but on your ppa the kodi.pvr.hts says '3.0.1' , but in kodi nightly it says '3.1.0' .
Typo or wrong version ?
A very egoistic and off topic question... Please don't blame me!
Is there any 6.0.x VAAPI build that integrates the new AirPlay, iOS 9 compatible, plugin that can be found in 7.0.x?!
I own an Intel Nuc DN2820FYKH, first gen. As you may already know it's a relatively difficult device to find the best configuration... Fritsch helped me a lot when he showed me this build and saved my Nuc from a premature death caused by constant overheating! Straight Openelec, with the "wrong" drivers, was killing my device. Of course it's not an Openelec fault!!!
After saying that you can understand better why I don't want to leave this wonderful configuration I have but, at the same time, I really would like to have latest AirPlay on my system... My wife and kids really love to use it for photos and music!
Is that possible?
(2016-03-06, 20:21)fedux Wrote: [ -> ]A very egoistic and off topic question... Please don't blame me!
Is that possible?
There won't be any builds form from Fritsch as he already stated a few times.
But maybe Matdewo the Chromebox Guy will make a build once Openelec released their Beta for Kodi 16.
As for Airplay you have to understand that it is mostly broken with Ios9 and will only work with Audio and not with Photos.
Best just buy a used AppleTV 3 if you need airplay mirroring.
(2016-03-06, 20:38)psysfaction Wrote: [ -> ] (2016-03-06, 20:21)fedux Wrote: [ -> ]A very egoistic and off topic question... Please don't blame me!
Is that possible?
Thanks a lot for the quick answer!
I thought Memphiz and the other guys finally had fixed it, but, if this is the result, I have the good answer to give to my wife! You know how wives are....!!!! We, men, are just simple creatures!!!
Have a good day.
Last time i checked (around 2pm) it stated 3.0.1 at your repo.
But now it's all ok :-)
I'm having a couple of issues:
1. I can't seem to get 4k@60hz as available screen resolution in settings. Only can get refresh rates 30 or less. Xrandr reports the same.
2. 4k content seems to play well but getting jitter on
http://4ksamples.com/elysium-4k-trailer/ I guess because the hardware acceleration isn't kicking in. CPU spikes during playback also.
Any ideas?
Am using a skylake i3 6100.
Skylake only has HDMI 1.4b - max is 4k@30hz nothing more.
For the rest. No
Debug Log no issue no problem to solve - alternatively posts are ignored next time (as mentioned in the very first post).
(2016-03-08, 14:12)fritsch Wrote: [ -> ]Skylake only has HDMI 1.4b - max is 4k@30hz nothing more.
For the rest. No Debug Log no issue no problem to solve - alternatively posts are ignored next time (as mentioned in the very first post).
Here you go paste.ubuntu.com/15327358/
