Wake up from sleep is something else ... as most likely your edid feels like being absent. You can try:
http://wiki.openelec.tv/index.php/Config...#tab=Intel after a 100% succesful boot.
Edit: The EDID part - xorg.conf might most likely not be needed but does not hurt.
@fritsch: i have also the problem with kernel 4.4 and the color passthrough. when kodi is set to limited color the brightness is too high and in the test video the bars are all visible from 0 to 255. i have to disable limited color to have limited color. in the black test video from 16 and up are visible and in the white test video up to 235.
xrandr --verbose is showing that video "Video 16:235 pass-through" is enabled.
is something different to setup in new kernel?
i will have a look. can you give me the link to the old patch for 4.3? so i have something to compare.
okay, that was also the first thing i have seen in case INTEL_BROADCAST_RGB_VIDEO. because of that i have asked for the old patch. to compare.
until now i didn't build OE from your sources. Only from the official sources. Today i won't get time to setup up the envirionment to your ones. tomorrow i can try to build.
edit: i try the image instead ;-)
@fritsch: old behaviour from 4.3 is restored. i have to say thank you very much!
Apologies if this is off-topic.
Without having gone through the entire thread - has anyone already "Fedorized" post #1
The closest I can find is:
Here
The wiki references nvidia configuration. I'm using the N3150 beebox - but unfamiliar with the equivalent intel nomenclature. For the rest of it setting up a standalone Kodi box seems fairly standard.
(2015-12-20, 19:29)NightFlight Wrote: [ -> ]Apologies if this is off-topic.
The closest I can find is: Here
Nope. You are welcome to be the first.
Using latest build I allso have the problem when stopping a movie 'interface' restarts back at home screen or black screen with mouse pointer.
from 19:06 boot then 2x 'interface restart' on stop and at end of log hang at black screen with mouse pointer.
http://sprunge.us/bFKL
http://sprunge.us/RKUB
http://sprunge.us/LFQC
http://sprunge.us/AYYb
edit: when running a file untill it stops there seems to be no problem and I get back to folder where I started the video
(2015-12-20, 20:13)neox387 Wrote: [ -> ]Using latest build I allso have the problem when stopping a movie 'interface' restarts back at home screen or black screen with mouse pointer.
@fernet: does that ring a bell?
(2015-12-20, 20:05)fritsch Wrote: [ -> ] (2015-12-20, 19:29)NightFlight Wrote: [ -> ]Apologies if this is off-topic.
In the interest of sanity I think I'll swallow the ubuntu pill for the first attempt and go from there.
Not sure what you need to swallow - religious discussions happen in the Windows forum. Head over there.
Just wanted to add that "Refreshrate Switching not working" that is claimed to be fixed on page 1 is not working for me. If Iset refreshrate in GUI to 60Hz I have sync issues and not correct refreshrate when playing videos. I will try to add the xorg.conf settings when i'm back from holiday.
