(2015-12-11, 12:52)wwessel Wrote: [ -> ]I have an issue with the latest version on an ASUS Chromebox:
Starting a movie works fine, the movie is played flawlessly.
But when I stop the movie OE is restarting and I only have a black screen with mouse pointer on it. Then I have to stop/start kodi via ssh to make it work again.
cat ~/.kodi/temp/kodi.log | pastebinit: http://sprunge.us/GChJ
dmesg | pastebinit: http://sprunge.us/VIjE
EDIT: It looks like it only happens with SD material. I can't reproduce this with HD movies. But stopping the first SD movie it happens again...
Issue still there with today's build. I tried latest Milhouse build and it has the same behaviour. The last one without this issue was the Jarvis 16.0 build, so something is broken in 17.0?
(2015-12-13, 12:45)jteeuw Wrote: [ -> ]Hi ,
I did a fresh install and followed the how to from page one, everything is working perfecty but when watching Live TV I have green frames ,about 3 green frames per minute.
Can somebody tell from the logs I my setup is good?
dpkg -l |grep mesa | pastebinit
http://paste.ubuntu.com/13987283/
DISPLAY=:0 vainfo | pastebinit
libva info: VA-API version 0.38.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_38
libva info: va_openDriver() returns 0
http://paste.ubuntu.com/13987289/
cat /home/kodi/.kodi/temp/kodi.log | pastebinit
http://paste.ubuntu.com/13987306/
dmesg | pastebinit
http://paste.ubuntu.com/13987307/
Not a
Debug Log - can you test without tvheadend? What about recordings?
(2015-12-13, 14:26)wwessel Wrote: [ -> ] (2015-12-11, 12:52)wwessel Wrote: [ -> ]I have an issue with the latest version on an ASUS Chromebox:
Your build is 4 days outdated - reproduce with today's version.
(2015-12-13, 14:33)fritsch Wrote: [ -> ] (2015-12-13, 14:26)wwessel Wrote: [ -> ] (2015-12-11, 12:52)wwessel Wrote: [ -> ]I have an issue with the latest version on an ASUS Chromebox:
OK, here are the latest logs:
http://sprunge.us/eJHK
http://sprunge.us/bJPH
There's one thing changed in the behaviour: After restarting it stays with black screen for some seconds, then the GUI comes up again. The same is happening after wake up from suspend state:
http://sprunge.us/eXMN
http://sprunge.us/hWZa
Can you upload the crashlog from your home directory?
(2015-12-13, 15:34)fritsch Wrote: [ -> ]Can you upload the crashlog from your home directory?
I can't find one in /storage. Is there another place?
(2015-12-13, 15:38)wwessel Wrote: [ -> ] (2015-12-13, 15:34)fritsch Wrote: [ -> ]Can you upload the crashlog from your home directory?
OK, I found it in ~/.kodi/temp:
http://sprunge.us/QXfS
Still problems with OOS audio when using audio passthrough. And now downgrading to an older version doesn't fix the problems either
(2015-12-13, 14:29)fritsch Wrote: [ -> ] (2015-12-13, 12:45)jteeuw Wrote: [ -> ]Hi ,
dmesg | pastebinit
Not a Debug Log - can you test without tvheadend? What about recordings?
I have it with live tv and (tv) recordings other files not .
here is my debug log :
http://paste.ubuntu.com/13992295/
For an average joe, is it recommended to use the Isenguard OE 15.2 build (which was last updated a month ago) or the newer Video Player 17 build (what is this?)
Average Joe should buy a FireTV ...
(2015-12-13, 21:26)fritsch Wrote: [ -> ]Average Joe should buy a FireTV ...
Haha... In post #2 it mentions beginner Isenguard OE build is for every day joe, just wondering if that's still the case.
Also problem with black screen with only pointer after finish watching a video file is back....
(2015-12-13, 22:05)_Spook_ Wrote: [ -> ]Also problem with black screen with only pointer after finish watching a video file is back....
No help without the required logfiles from thread 1.
When I first tried these builds back in September, I had an issue where I was getting
no HDMI output on a refresh rate switch.
I filed a bug with freedesktop.org.
Just today, I thought I would give this another try.
I had the same issue, but discovered disconnecting the HDMI cable and reconnecting it would restore the video/audio.
So it seems my problem all along was an issue with hand-shaking after a refresh rate change.
I've temporarily worked around this by chaining the GUI to 1080p 23.98 which means for 90% of my content, no refresh rate change is required, and thus no loss of signal.
How do I fix this properly so I can get Kodi to do refresh rate switching and be able to re-establish handshake/signal with my AVR (Yamaha RX-A3050 with HDMI 2.0 and HDCP 2.2)?
