2012-11-08, 10:47
(2012-11-08, 09:44)scottyten Wrote: [ -> ]Still having the dependencies not met error, have tried heaps of combinations and currently using alpha 7's with a zip downloaded from git and still have no luck. How do I fix this?
Refocus original works fine.
You're missing the required add-ons versions.
As the frodo's repo is not yet ready, the addons are not imported automatically. You will need to install them manually first.
I'd unzip the file on your addons xbmc folder.
Either that, or editing the addon.xml file on the root folder of the skin zip file,
by removing all the import addon lines at the beginning.
In any case, you might find unexpected behavior as you are missing some of the required dependencies.
(2012-11-08, 06:25)knewknow Wrote: [ -> ](2012-11-08, 05:51)Crimzin Wrote: [ -> ]Ummm, ok i've never had this problem before ever when using this skin. Updated to the latest (as far as i can tell) git version for Eden and.....i have no 'Skin' options in Settings..at all. Everything else is there except i can't taylor the skin at all. What blindingly obvious thing have i missed? :o/
The latest version for Eden is v083.1. Anything on the main branch on git is for Frodo. In Frodo, the skins are customized through the appearance setting, so there's a good chance that if you're running the latest git on Eden, you won't be able to find the settings because it can't find them. Either update to Frodo Alpha7 and use latest git, or drop down to 083.1 on Eden. I have tried running various Frodo versions over the past few months and none of my "go to" skins are running well, including reFocus BIG, and I'm running a monster HTPC (i5 3450s). The only skin that seems to run flawlessly for me in Frodo seems to be confluence.
btw....
Is there a way to have smart video playlists show on the main menu and not just under the "video" menu? I'm looking for something like this under the main menu ..... I'm using v083.1 on Eden.
Movies
TV Shows <------- this would not contain ANY cartoons. So would be based on "not" a folder location.
Cartoons <------- this would be based on a folder location
Thanks for everyone who helps improve this skin. It really is the absolute best on xbmc.
Latest git version of big works quite fine here, except for live tv, which seems to be broken.
If you want to have playlists on the main menu you will to add them manually on the xml files. That would be a really nice feature though.
