2014-12-21, 12:23
Any chance of defining a folder image per tv show instead of the default blue folder. My son is 4 yo and uses this plugin but can't read so would be easier if the folder image displayed some fanart or something.
(2014-12-21, 12:23)JasonPell Wrote: [ -> ]Any chance of defining a folder image per tv show instead of the default blue folder. My son is 4 yo and uses this plugin but can't read so would be easier if the folder image displayed some fanart or something.
(2014-12-21, 12:41)janbar Wrote: [ -> ]I added 2 new options for users want to browse faster (thanks to nerddtvg):I am surprised that the small channel icon files would be an issue. Are they scaled each time they are displayed? If so, maybe a good fix would be to cache a scaled version of the icon the first time it is encountered. If that improved performance, it might be a better solution than yet another preference.
Enable channel icons (since version 1.10.1)
Disable this option on low powered platform as RPi
(2014-12-22, 07:35)JasonPell Wrote: [ -> ]@JasonPell, there is no way to change icon of folder. That's handled by Kodi itself.(2014-12-21, 12:23)JasonPell Wrote: [ -> ]Any chance of defining a folder image per tv show instead of the default blue folder. My son is 4 yo and uses this plugin but can't read so would be easier if the folder image displayed some fanart or something.
I was referring to the folder to the right of the recordings list.
How would I configure fanart for this? Is this done on mythtv backend?
(2014-12-22, 23:41)allan87 Wrote: [ -> ]I have done same remark, but scaling should be handled by kodi itself, and probably already handled.So here i have included tiny dummy icon.(2014-12-21, 12:41)janbar Wrote: [ -> ]I added 2 new options for users want to browse faster (thanks to nerddtvg):I am surprised that the small channel icon files would be an issue. Are they scaled each time they are displayed? If so, maybe a good fix would be to cache a scaled version of the icon the first time it is encountered. If that improved performance, it might be a better solution than yet another preference.
(2014-12-06, 06:26)janbar Wrote: [ -> ](2014-12-02, 03:53)mikebetz42 Wrote: [ -> ]Still having problems with pvr.mythtv stopping randomly during playback of live TV, pvr-mythtv-cmyth works without any issues...
MythTV Logs: http://pastebin.com/u9Wh4Rkq
Kodi debug log: http://xbmclogs.com/show.php?id=360331
MythTV 27+ current fixes and Kodi Helix RC1 are on the same PC, Two Ceton Infinitv 4 PCIe cards.
Thank you,
Mike
Hi Mike, your log is full of ERROR during icons loadings, then full of NOTICE during playback: ...read ahead. That s means player wants read more than the head of stream. What kind of stream you try to read ? mpeg-ts , mpeg-ps or other ? Is it analog channel ?
It is really strange cmyth addon is able to read it without issue ! Could you provide log with extra debug enabled for cmyth addon and new addon ? Thanks
Also you could try new addon with same version of xbmc you use with cmyth... For now i didn't provide cmyth addon for kodi RC1, but i could.
There i think the root cause could be the new version of ffmpeg / kodi player. So i would like you try new addon with same version of xbmc you use cmyth addon.
(2014-12-25, 00:07)dgrayfromdc Wrote: [ -> ]Hello,
One of my machines just upgraded to Kodi Helix and everything went smoothly except one thing. MythTV seems to have disaapeared. My machine (working perfectly under Gotham 13.2) can't seem to install or upgrade the mythtv add-on to work with Helix.
I've gone to Settings > Add-ons > Get Add-ons > All Add-ons > PVR clients. From there, I select MythTV cmyth PVR Client, and select Install. I get a notification stating "Dependancies not met. Please contact Add-on author."
The first question I had was why wasn't the Add-on still installed to begin with? Normally, if an Add-on hasn't caught up yet, you'll be prompted to disable it. This time, it just disappeared.
But ever forward, I Googled for the latest .deb package and attempted to install it hoping to get the right dependancies. The latest thing I found was kodi-bin (>= 5:14.0~rc3-dmo1) on http://www.deb-multimedia.org. I'm guessing that this was the latest operational package, but can't be certain. In any event, when I attempted to install it, it blew up with errors about missing files. I can't seem to find a proper copy of the mythtv PVR Add-on.
I'm Running a Mythbuntu 14.04.1 with KDE and MythTV 0.27 as my backend. Any thoughts?
(2014-12-24, 11:05)Huuh Wrote: [ -> ](2014-12-06, 06:26)janbar Wrote: [ -> ](2014-12-02, 03:53)mikebetz42 Wrote: [ -> ]Still having problems with pvr.mythtv stopping randomly during playback of live TV, pvr-mythtv-cmyth works without any issues...
Thank you,
Mike
Hi, I also seem to be having the same problem on my raspberry pi and on my laptop. When I loaded up openelec 4.2 gotham on my raspberry, using 1.9.20 it worked fine. However, as soon as I tried using 1.9.29 for gotham that you provided on your cloud server, video stalls after about 5 seconds.
On my laptop 1.10.1 stalls as well.
I have a ceton infinitv 4 PCIe card, which streams digital cable mpeg2-ts files.
(2014-12-25, 23:19)glubbish Wrote: [ -> ]HiAre you using janbar's ppa?
I just upgraded to kodi 14.0 from xbmc 13.2 via
sudo apt-get update
sudo apt-get install kodi
I got a message saying the the pvr was not compatible.
I had been getting updates in gotham via the ppa
I tried running an update, but it says I am up to date.
What change do I need to get the kodi version of this product?
(2014-12-26, 00:10)glubbish Wrote: [ -> ]The package for kodi has a new name: kodi-pvr-mythtv-helix. So you have to install this new one. Also you could keep gotham version usable with xbmc 13.Quote:Are you using janbar's ppa?
Yes.
http://ppa.launchpad.net.jlbarriere68/ppa/ubuntu trusty main
