I am using the latest version of this add-on from "* doityourself e42e9b1", It works fine with myth [v0.28-pre-2693-gc4ed359]. Now when I try to use it with the latest version [v0.28-pre-2811-ga9e8f44]. All the EPG listings are the same. They all get set to the same listings as the first channel displayed. I looked a bit through the change log for mythtv and I noticed there have been some changes to the GetProgramGuide API. This all happens from March 25 to 30'th 2015. Could this be the reason why the I am having this issue ? An example of one change log is below:
commit 05647132c2285a6d58e9afe7318f2bc50a14e3aa
Author: Stuart Morgan <
[email protected]>
Date: Fri Mar 27 17:49:43 2015 +0000
Services API: Fix a logical issue with GetProgramGuide
GetProgramGuide took an argument - StartChanId but since the list of
channels is sorted by the Channel Number, and not it's ID this made no
sense. This meant there was no way of restricting the results to just
a subset (page) of the guide.
So to address this issue, and make GetProgramGuide consistent with
other service API methods StartChanId has been replaced with
StartIndex, and NumChannels has been replaced with Count.
'TotalAvailable' is included in the results, but for now it will only
contain zero. A fix for this will be committed soon, I hope.
Unfortunately, the changes to make this necessary have negated the
earlier performance improvements. Fetching the complete guide is now
25-50% slower than it was before this commit, this is obviously not
acceptable and I'm trying a variety of approaches to get performance
back at least to where it was. On the other hand, since data can now
be fetched in ranges, perceived loading time can be reduced by
backgrounding the loading of most of the guide.
