2014-07-10, 21:57
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
2014-07-11, 01:37
(2014-07-10, 02:13)Djangostar Wrote: [ -> ](2014-07-10, 01:55)dahlSTROM Wrote: [ -> ](2014-07-08, 01:54)Djangostar Wrote: [ -> ]Hi , Sorry for the delay , So I uncheked demuxing Mpeg , and restarted the htpc , enabled debug , tried to watch 3 streams
(wait of about 30sec each) and says channel unavailble , I also enabled the extra log details in the pvr advanced menu .
hope it helps
Log : http://pastebin.com/ts6U3YV4
I believe we're facing the same problem. I've created an issue on Github: https://github.com/janbar/xbmc-pvr-addons/issues/19
You might be right , let me see if I can try the cmyth one .
The issue should be fixed now. Please let me know. Also I rebuild binary versions from my cloud and from my ubuntu ppa.
The defect affected all versions (0,27 & 0,28) when trying to play channels providing an airdate for programs . Now it should be play, but i cannot confirm because mine havent any airdate.
EDIT: dahlSTROM confirm is not fixed !!! I will check the new log soon.
EDIT: dahlSTROM confirm is fixed !!! As the dev version of addon does change , importing the zip using xbmc ui does not upgrade the addon. You have to unzip manually into the .xbmc/addons/ folder.
2014-07-11, 15:42
Thx for the update , let me know if there is anything I can do to help .
2014-07-11, 19:42
(2014-07-11, 15:42)Djangostar Wrote: [ -> ]Thx for the update , let me know if there is anything I can do to help .
Please can try the new, it could run now else it will generate new log to identify the defect. thanks
2014-07-11, 20:35
(2014-07-10, 21:57)nickr Wrote: [ -> ]You'll need to compile it I think.
I can't seem to find build instructions to build this plugin to run on my Rasberry PI under OpenElec can anyone point me at instructions to compile this plugin?
Robert
2014-07-11, 21:59
(2014-07-11, 20:35)rmiddle Wrote: [ -> ](2014-07-10, 21:57)nickr Wrote: [ -> ]You'll need to compile it I think.
Robert
go to http://wiki.xbmc.org/index.php?title=PVR...o_OpenELEC
then replace "https://github.com/fetzerch/xbmc-pvr-addons/archive/master.zip" to "https://github.com/janbar/xbmc-pvr-addons/archive/master.zip" in "wget --no-check-certificate " instruction.
2014-07-11, 23:19
(2014-07-11, 21:59)janbar Wrote: [ -> ](2014-07-11, 20:35)rmiddle Wrote: [ -> ](2014-07-10, 21:57)nickr Wrote: [ -> ]You'll need to compile it I think.
Robert
Looks easy enough now just need a few days for OpenElec to build for the first time.
2014-07-11, 23:27
Heavens what are you building it on?
2014-07-11, 23:52
(2014-07-11, 19:42)janbar Wrote: [ -> ](2014-07-11, 15:42)Djangostar Wrote: [ -> ]Thx for the update , let me know if there is anything I can do to help .
http://xbmclogs.com/show.php?id=244805
New log , I updated /upgraded (ppa) and tried the channels again , still a no go , I am gonna try to reinstall the backend this weekend , just in case .
2014-07-12, 05:39
(2014-07-11, 23:27)nickr Wrote: [ -> ]Heavens what are you building it on?
i7 with 8gig of ram. The second time I did a make it finished in a few hours. So it must have been something wrong with the repo the first time I pulled. After it finished I relized I screwed up and was on the wrong branch. Working on the 4.0 branch right now.
Robert
2014-07-12, 06:15
Yeah it usually downloads and compiles from scratch in about 8 hours for me, the source files come from all over the place though so if even one server is slow, it can hold you up. Also i7 with 8G RAM.
2014-07-12, 08:23
(2014-07-11, 23:19)rmiddle Wrote: [ -> ](2014-07-11, 21:59)janbar Wrote: [ -> ](2014-07-11, 20:35)rmiddle Wrote: [ -> ]I can't seem to find build instructions to build this plugin to run on my Rasberry PI under OpenElec can anyone point me at instructions to compile this plugin?
Robert
Just errored out. Looks like OpenElec applys 2 patches to the standard branch. Error below.
Information: no *.so.[0-9]* libs found
UNPACK xbmc-pvr-addons
APPLY PATCH (common) /home/rmiddle/repo/OpenELEC.tv/packages/mediacenter/xbmc-pvr-addons/patches/xbmc-pvr-addons-buildfix.patch
patching file addons/Makefile.include.am
Hunk #1 FAILED at 36.
1 out of 1 hunk FAILED -- saving rejects to file addons/Makefile.include.am.rej
cat Makefile.include.am.rej
--- addons/Makefile.include.am 2014-05-04 14:27:57.000000000 +0200
+++ addons/Makefile.include.am 2014-05-04 14:35:47.618601552 +0200
@@ -36,7 +36,9 @@
mkdir -m 755 -p $(DESTDIR)@LIBDIR@/$(ADDONNAME)
mkdir -m 755 -p $(DESTDIR)@DATADIR@/$(ADDONNAME)
cp -f @BINPREFIX@$(ADDONBINNAME)@BIN_EXT@ $(DESTDIR)@LIBDIR@/$(ADDONNAME) ; chmod 655 $(DESTDIR)@LIBDIR@/$(ADDONNAME)/@BINPREFIX@$(ADDONBINNAME)@BIN_EXT@
- cp -r -f @abs_top_srcdir@/addons/$(ADDONNAME)/addon/* $(DESTDIR)@DATADIR@/$(ADDONNAME) ; chmod -R o+rx $(DESTDIR)@DATADIR@/$(ADDONNAME)
+ cp -r -f @abs_top_srcdir@/addons/$(ADDONNAME)/addon/* $(DESTDIR)@DATADIR@/$(ADDONNAME)
+ cp -r -f @abs_top_builddir@/addons/$(ADDONNAME)/addon/* $(DESTDIR)@DATADIR@/$(ADDONNAME)
+ chmod -R o+rx $(DESTDIR)@DATADIR@/$(ADDONNAME)
endif
all: @BUILD_TYPE@
(openelec-4.0)
Reviewing the patch to see what needs tweaked.
Robert
2014-07-12, 09:35
(2014-07-11, 23:52)Djangostar Wrote: [ -> ](2014-07-11, 19:42)janbar Wrote: [ -> ](2014-07-11, 15:42)Djangostar Wrote: [ -> ]Thx for the update , let me know if there is anything I can do to help .
I see something weird ... i am trying to explain the thing . seems the backend returns the response "Okay the live is spawned you can try to catch my stream..." very late ! I have a solution in my pocket but i never see that before...
EDIT: "very late" does mean your host is slow. It is the inverse in fact: all operations are already done before catching the OK. Crazy !
2014-07-12, 11:36
I commited and pushed a fix. ppa packages are built now. Let me know.
Your case is interesting because it allows to fix how to handle the protocol (which is undocumented for part).
2014-07-12, 17:11
(2014-07-12, 11:36)janbar Wrote: [ -> ](2014-07-11, 23:52)Djangostar Wrote: [ -> ](2014-07-11, 19:42)janbar Wrote: [ -> ]Please can try the new, it could run now else it will generate new log to identify the defect. thanks
Cool ! I havn't reinstalled myth yet but let me try the fix and let you know in 10 mins .
Edit : This is the update I got from ppa .
Unpacking wine-compholio-i386 (1.7.22~ubuntu14.04.1) over (1.7.21~ubuntu14.04.1) ...
Preparing to unpack .../xbmc-pvr-mythtv_1.9.14-0~339~ubuntu14.04.1_amd64.deb ...
Unpacking xbmc-pvr-mythtv (1.9.14-0~339~ubuntu14.04.1) over (1.9.14-0~336~ubuntu14.04.1) ...
I rebooted the system , tried a channel, it says buffering for about 3 sec and goes back to the channel selection page .
I double checked the tuner delay is still at 30 sec .
here is the new log . http://xbmclogs.com/show.php?id=245286
