2015-04-15, 21:30
(2015-04-15, 08:29)janbar Wrote: [ -> ]@peterman1002 , remove or replace file channel.png from folder pvr.mythtv/resource/
Thanks! I will give this a try later.
(2015-04-15, 23:14)nickr Wrote: [ -> ]XFS is the generally accepted norm for mythtv I think, although there should be nothing wrong these days with ext4.
(2015-04-14, 16:40)mattlach Wrote: [ -> ](2015-04-14, 13:14)carpa5 Wrote: [ -> ]Has this been solved ? I am having a similar issue with the latest 0.28. I can pause live TV for lets say 10 minutes, and then when I try to skip any time back or forward it always ends up doing only about 10 seconds in either direction. If I use fast forward "f" then it works ok but I really would like to be able to skip the regular way ( ">" "<" "[" "]" )without having to watch the video.
Maybe this is a 0.28 issue? It works fine in 0.27 for me.
Funnily enough, skipping live tv was NOT working well for me with the old cmyth plugin :p
(2015-04-16, 11:38)carpa5 Wrote: [ -> ](2015-04-14, 16:40)mattlach Wrote: [ -> ](2015-04-14, 13:14)carpa5 Wrote: [ -> ]Has this been solved ? I am having a similar issue with the latest 0.28. I can pause live TV for lets say 10 minutes, and then when I try to skip any time back or forward it always ends up doing only about 10 seconds in either direction. If I use fast forward "f" then it works ok but I really would like to be able to skip the regular way ( ">" "<" "[" "]" )without having to watch the video.
I have finally fixed the problem. After I disabled "Enable demuxing MPEG-TS" in the Advanced config setting of the addon, the live tv time skipping works as advertised.
(2015-04-14, 10:20)janbar Wrote: [ -> ]I pushed the git branch helix_read_timeout including the fixes. You can try it.
(2015-04-15, 22:20)Natronch Wrote: [ -> ]Prior, with btrfs as livetv cache, I constantly had warnings about long write times in the backend causing then lags an freezes in Kodi.Watch out for btrfs if you make the jump to kernel 3.16 as there were a boat load of fixes added. I just had a test with a few thousand RAW photos go horribly wrong. Same test on same disk, XFS partition was flawless.
(2015-02-22, 17:59)FatGerman Wrote: [ -> ]Is commercial skipping working for anybody with the PPA version? I know my shows have been flagged and commercials found, but the plugin is not skipping them like it did with Gotham. I've tried changing the setting from 'Always' to 'Dialog' but it made no difference. I see nothing in the debug log that makes any sense to me....@tdavis, @allan87 and any others that mentioned this previously, debian/*buntu PPAs are properly packaging again. See this post.
(2015-04-17, 16:48)gibbonlicker Wrote: [ -> ]Hi there. Please excuse my ignorance - I'm looking for some (mental) help. I mistakenly installed updates and now my mythtvpvr addon no longer works. "Check the log file" it says. Please bear with me, I'm not very good at this stuff (it took me about half an hour to find the log file, so any help given would be great if you could write as if you're talking to an 8 year old with step by step instructions).
15:32:38 T:140243832228032 ERROR: GetDirectory - Error getting addons://disabled/xbmc.pvrclient
15:32:38 T:140243832228032 ERROR: CGUIMediaWindow::GetDirectory(addons://disabled/xbmc.pvrclient) failed
15:32:38 T:140243357730560 NOTICE: Thread BackgroundLoader start, auto delete: false
15:32:53 T:140243832228032 NOTICE: PVRManager - stopping
15:32:54 T:140243072173824 NOTICE: PVRManager - starting up
15:32:54 T:140242542184192 NOTICE: Thread PVRManager start, auto delete: false
15:32:54 T:140243097351936 NOTICE: Thread PVRClient start, auto delete: false
15:32:54 T:140243097351936 ERROR: PVR - Add-on 'MythTV PVR Client' is using an incompatible API version. XBMC minimum API version = '1.9.6', add-on API version '1.9.2'
15:32:54 T:140243097351936 WARNING: UpdateAndInitialiseClients - failed to create add-on MythTV PVR Client, status = 6
15:32:54 T:140243097351936 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on MythTV PVR Client, disabling it
15:32:58 T:140243357730560 NOTICE: Thread BackgroundLoader start, auto delete: false
I guess I'm trying to find out how I get the API version to 1.9.6. I've tried following the guide here: http://kodi.wiki/view/PVR/Backend/MythTV...FromSource but with no luck - to be fair, I'm not sure which version on Kodi I'm running so tried the 3 different options; gotham, helix and doityourself but none of them worked.
According to Kodi system summary I'm running Ubuntu 14.10 (kernel: Linux 3.16.0.34-generic)
Don't know if this helps but when I try to enable the addon I get the following:
15:42:48 T:140243072173824 NOTICE: Thread BackgroundLoader start, auto delete: false
15:42:49 T:140243072173824 NOTICE: Thread JobWorker start, auto delete: true
15:44:24 T:140243832228032 NOTICE: PVRManager - stopping
15:44:25 T:140243072173824 NOTICE: PVRManager - starting up
15:44:25 T:140243097351936 NOTICE: Thread PVRManager start, auto delete: false
15:44:25 T:140242542184192 NOTICE: Thread PVRClient start, auto delete: false
15:44:27 T:140243357730560 NOTICE: Thread BackgroundLoader start, auto delete: false
15:44:33 T:140243832228032 ERROR: GetDirectory - Error getting addons://disabled/xbmc.pvrclient
15:44:33 T:140243832228032 ERROR: CGUIMediaWindow::GetDirectory(addons://disabled/xbmc.pvrclient) failed
15:44:33 T:140243357730560 NOTICE: Thread BackgroundLoader start, auto delete: false
Are any of you people able to tell me what I need to do to get my addon working again based on the information above? I will try to provide any further information you need.
(2015-04-24, 20:19)gibbonlicker Wrote: [ -> ]Anyone?You need to build the latest pvr.mythtv addon.
(2015-04-24, 20:50)dahlSTROM Wrote: [ -> ](2015-04-24, 20:19)gibbonlicker Wrote: [ -> ]Anyone?You need to build the latest pvr.mythtv addon.
https://github.com/janbar/pvr.mythtv
