2015-03-12, 20:55
(2015-03-12, 20:36)nickr Wrote: [ -> ]What version of kodi is in raspbian?
I get the latest, but I get it from here: http://michael.gorven.za.net/raspberrypi/xbmc
sudo apt-get install kodi-pvr-mythtv
(2015-03-12, 23:30)BenH Wrote: [ -> ]typo? kodi-pvr-mythtvThank you, corrected now!
(2015-03-12, 21:32)nickr Wrote: [ -> ]You have a couple of choices - ask the raspbian people, or compile yourself.
Are you sure pvr.mythtv isn't a separate package?
EDIT sorry I was being rushed out the door and didn't get to finish.
On ubuntu you have to install the pvr packages individually like
Code:sudo apt-get install kodi-pvr-mythtv
I don't know if it is the same in raspbian.
Raspbian is kind of EOL anyway, so I am not sure if it is the best choice for ongoing support. This pvr addon is under constant development and improvement.
EDIT: more apologies, raspbian is not EOL, raspbmc is. Silly me.
(2015-03-13, 04:56)teeedubb Wrote: [ -> ]You can compile on raspbian using the Ubuntu instructions here: http://kodi.wiki/view/MythTV_PVR/BuildFromSource
The only thing I did differently was not install ubuntu-restricted-extras
Here is v1.12.10 for Helix https://www.dropbox.com/s/qzp0qrefqj8b9i...x.zip?dl=0
(2015-03-15, 07:16)mikebetz42 Wrote: [ -> ]Where can I get the OpenElec Cubox-i myth-pvr versions? I no longer see them on the cloud....
Quote:10:15:01 T:4940 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'pvr://recordings/Default/NCIS/NCIS - Ships in the Night, TV (5 Later), 20150308_200500.pvr'
10:15:01 T:4940 DEBUG: VIDEO::CVideoInfoScanner::OnProcessSeriesFolder - no match for show: 'NCIS', season: 201503, episode: 8.0, airdate: '01/01/1601', title: ''
Quote:10:15:44 T:4940 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'pvr://recordings/Default/Fresh Meat/Fresh Meat - S02, E08, TV (4Music), 20150226_001300.pvr'
10:15:45 T:4940 DEBUG: ADDON::CScraper::GetVideoDetails: Reading episode 'http://thetvdb.com/api/1D62F2F90030C444/series/251889/all/en.zip' using The TVDB scraper (file: 'C:\Program Files (x86)\Kodi\addons\metadata.tvdb.com', content: 'tvshows', version: '1.7.1')
(2015-03-15, 11:48)janbar Wrote: [ -> ]@all,(2015-03-15, 07:16)mikebetz42 Wrote: [ -> ]Where can I get the OpenElec Cubox-i myth-pvr versions? I no longer see them on the cloud....
I let you know when available. I removed old binary because those platforms often don't have hardware supported by Kodi. Use it as your risk .
(2015-03-15, 13:30)se99paj Wrote: [ -> ]I'm trying to get my recordings into the tv show menu, I've added the "Recordings" option as a source in the File menu.
I've taken a look at the logs and picked out one where the program has worked and one where it hasn't.
(required) unique id of the recording on the client.
(required) the title of this recording
(required) stream URL to access this recording
(optional) directory of this recording on the client
(optional) plot outline
(optional) plot
(optional) channel name
(optional) icon path
(optional) thumbnail path
(optional) fanart path
(optional) start time of the recording
(optional) duration of the recording in seconds
(optional) priority of this recording (from 0 - 100)
(optional) life time in days of this recording
(optional) genre type
(optional) genre sub type
(optional) play count of this recording on the client
(optional) last played position of this recording on the client
