Thank you very much.
I poked around looking for links. I apologize for not poking enough.
It is a long thread
So, I can browse the Channel List, the Program Guide, schedule a recording from the Program Guide, Watch completed recordings, and Watch a recording in progress that was previously submitted.
Trying to watch a channel "Live" gives an "Channel unavailable"
Is perhaps my back end misconfigured?
I'll try to generate a log.
*start edit*
Log at
http://xbmclogs.com/show.php?id=421401
ok, interesting part of the log
18:23:02 T:140564202235776 NOTICE: DVDPlayer: Opening: pvr://channels/tv/All channels/0.pvr
18:23:02 T:140564202235776 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:23:02 T:140562392934144 NOTICE: Thread DVDPlayer start, auto delete: false
18:23:02 T:140562392934144 NOTICE: Creating InputStream
18:23:02 T:140562392934144 ERROR: AddOnLog: MythTV PVR Client: (CPPMyth)__connectAddr: failed to connect (101)
18:23:02 T:140562392934144 ERROR: Previous line repeats 6 times.
18:23:02 T:140562392934144 ERROR: AddOnLog: MythTV PVR Client: OpenLiveStream: Failed to open live stream
18:23:02 T:140562392934144 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All channels/0.pvr]
18:23:02 T:140562392934144 NOTICE: CDVDPlayer::OnExit()
18:23:02 T:140564202235776 NOTICE: CDVDPlayer::CloseFile()
18:23:02 T:140564202235776 NOTICE: DVDPlayer: waiting for threads to exit
18:23:02 T:140564202235776 NOTICE: DVDPlayer: finished waiting
Hmmm....
I changed the backend setup for ipv6 to ::1 and now live tv works
I guess I gotta figure out my internal ipv6 network if I want to use ipv6
In mythtv-setup on the backend, what IP addresses are set up and did you disable ipv6?
Is the backend on the same machine?
OOps I see you already posted back and jhave fixed it. forget ipv6 unless you really need it. Too much pain.
Is rewind in live TV supposed to work? When I try it, it just hangs. Fast forward works fine. Rewind works fine when watching a recording. I'm running a .27.4 myth backend and openelec 5.0.2 on an Asus chrome box. PVR add on is version 1.11.2.
I never ever use rew/ff in kodi, but I know skip forward* and back works in pvr.mythtv.
*Assuming you are somewhere behind 'live'.
I know skipping back works, but I don't use rewind - its so 1990's...
(2015-02-11, 13:21)ToBeFrank Wrote: [ -> ]Is rewind in live TV supposed to work? When I try it, it just hangs. Fast forward works fine. Rewind works fine when watching a recording. I'm running a .27.4 myth backend and openelec 5.0.2 on an Asus chrome box. PVR add on is version 1.11.2.
I updated to 1.12.1 and now it is working. Not great, but it works.
Hey janbar,
Any chance you have a compiled/updated version of your addon for RPi2? The current version being shipped with openelec (1.11.2) ends up crashing the RPi2 frequently.
Is there perhaps an OpenElec / Gotham build that would work on the Pi2?
I would take less bleeding edge over stability any day of the week. Right now I cannot even go in and disable the MythTv pvr add-on (1.12.1) before it crashes. I would not want to anyways as MythTV is the reason I bought the Pi2 in the first place.
/Mat
(2015-02-13, 11:12)hallon Wrote: [ -> ]Is there perhaps an OpenElec / Gotham build that would work on the Pi2?
/Mat
If you disconnect your Ethernet cable (or, I assume, WiFi adapter) and restart your Rpi2, the MythTV PVR addon won't be able to access the backend, and OpenELEC will start without crashing. Then you can disable Live TV in the settings menu. That will allow you to use other functions of Kodi but not, of course, MythTV.
janbar has looked at this, but needs more debug information. Is there anyone out there who knows how to obtain what he needs?
https://github.com/janbar/xbmc-pvr-addon...t-74219361
