hi i am using windows 10 with Leia mod , i am having problems with adding external or internal images i have added the background folder in 3 different places within kodi , i have told windows 10 to show all files and folders but going through kodi to add source it just doesn't show up i have done a video to show you what i mean thanks for your advice
JanM201
Search IncludesVariables.xml for the variable named "value_widgets_rating_star_di". The last line needs to be changed. I'll include this in the next update.
(2019-05-29, 10:23)JanM201 Wrote: [ -> ] (2019-05-28, 17:56)shedrock Wrote: [ -> ] (2019-05-28, 17:44)latts9923 Wrote: [ -> ]@shedrock
Hmm...that should have been fixed some time back. I'll make sure I included the updated file...$INFO(Container(510).ListItem.Rating) needs to be changed to $INFO[Container(510).ListItem.Rating].
Thanks Latts,
That did the trick.
Where can i find this code to also change it?
It can be found in the IncludesVariables.xml file.
Cant find the button in the SMART SHORTCUTS. i have macos kodi 18.2.
How can i make the playlist work. Thanks!
creeker
The "GO TO PLAYLIST" button will be part of the next update.
latts9923 - I am not sure if this was addressed, but the
Trakt options in the
Context Menu does not work. I get an error every time I try to rate a movie. I did test it on Aeon Tajo and it works as it should. Also, it appears that the option appears more than once in the Context menu as well.
Thanks for you help,
Shedrock
Hey there latts, I have a suggestion for a new update if it's possible. Can the boxset description and cases be sorted by sorttitle instead of dates?
Widgets from video node show first previous video node section, than refresh and show current video node section. Is there way to always show current video node section?
nomnom27
I think the Skinhelper script only lists them by date.
(2019-06-04, 13:54)latts9923 Wrote: [ -> ]@nomnom27
So do I need to ask marcelveldt about this instead?
(2019-06-06, 11:23)nomnom27 Wrote: [ -> ] (2019-06-04, 13:54)latts9923 Wrote: [ -> ]@nomnom27
Or is there any way to configure skin helper to sort by sort tittle?
What is the url to install Latts repository?
