I thought I had licked the Rotten Tomatoes scores as a percentage in my heavily modified script using a variable as had been suggested, but there seems to be a Kodi core issue that limits reading the decimal scores past the first digit for 6.7 only returns the 6 which becomes a variable replacement of 60. I noticed your skin has percents working with Skin Helper and I've tried mimicking your code but not getting any results. Is there any other settings required within the SH add-on or elsewhere in the skin? Just trying to learn how this particular feature works so I can implement it and help out another user who's asked for some guidance.
Cheers!
Hey Latts,
All my percentages score show up on my video info page, but nothing shows in the kodi flix view media icons (green leaf with a percentage sign)
Where does it gets its data pull from?
Thanks for continuing updating this Mod.
(2019-07-19, 02:36)K0D1User1138 Wrote: [ -> ]I thought I had licked the Rotten Tomatoes scores as a percentage
there are to InfoLabels for Rotten Tomatoes rating in SkinHelper ->
https://github.com/kodi-community-addons...ideo-items
SkinHelper.ListItem.RottenTomatoes.Ratingrotten -> tomatoes rating
SkinHelper.ListItem.RottenTomatoes.Rating.Percentrotten -> tomatoes rating as percentage of 100
When using kodi core ratings for rotten tomatoes it is also possible to translate 6.7 to 67% just with the skin code. look ->
https://forum.kodi.tv/showthread.php?tid...pid2785205
(2018-03-06, 05:31)latts9923 Wrote: [ -> ]Aeon MQ 7 Mod v1.0.1.7 for Kodi v18 "Leia"You can now update the Aeon MQ 7 Leia Mod via my repo. The manual update process is no longer required. The following how-to video will walk you through installing my repo, and then installing/updating the Leia Mod. Installing my repo will begin the download process of v1.0.1.7, so make a backup of your skin if you have customized anything. This video is quite long, so there will be links provided in the video description that will allow you to skip to different portions of the video.DownloadsAeon MQ 7 Leia Mod v1.0.1.7Additional themes(You must first install the Aeon MQ Skin Themes Add-on, then you can copy the themes from this file into that Add-on.)Library Editor (Leia update)Skin Info Service (Leia update)Updates03/24/18 - Update for v1.0.0.1. Read here for more info.03/29/18 - Update for v1.0.0.2. Read here for more info.04/07/18 - Update for v1.0.0.3. Read here for more info.04/12/18 - Update for v1.0.0.4. Read here for more info.05/10/18 - Update for v1.0.0.5. Read here for more info.07/22/18 - Update for v1.0.0.6. Read here for more info.10/15/18 - Update for v1.0.0.7. Read here for more info.11/06/18 - Update for v1.0.0.8. Read here for more info.11/24/18 - Update for v1.0.0.9. Read here for more info.12/05/18 - Update for v1.0.1.0. Read here for more info.12/17/18 - Update for v1.0.1.1. Read here for more info.01/01/19 - Update for v1.0.1.2. Read here for more info.01/19/19 - Update for v1.0.1.3. Read here for more info.02/15/19 - Update for v1.0.1.4. Read here for more info.03/07/19 - Update for v1.0.1.5. Read here for more info.03/07/19 - Update for v1.0.1.6. Read here for more info.
Does this skin work with the latest development test builds of Kodi?
(2019-07-20, 15:14)chrissix Wrote: [ -> ] (2019-07-19, 02:36)K0D1User1138 Wrote: [ -> ]I thought I had licked the Rotten Tomatoes scores as a percentage
there are to InfoLabels for Rotten Tomatoes rating in SkinHelper -> https://github.com/kodi-community-addons...ideo-itemsSkinHelper.ListItem.RottenTomatoes.Ratingrotten -> tomatoes rating
When using kodi core ratings for rotten tomatoes it is also possible to translate 6.7 to 67% just with the skin code. look -> https://forum.kodi.tv/showthread.php?tid...pid2785205
Thanks for the info. I had one part of the string in my variable code wrong. Got it figured out now. Always good to post more knowledge for others to use though!
Ecplise
I haven't tried to install this on Matrix yet.
latts9923
Feel free to ignore Eclipse. He is part of a small group causing a bit of trouble in the forum.
Karellen
Doh...OK, thanks for the heads up.
Hi, I noticed that in none of my animes the japanese flag is shown:
English flags are shown correctly
Kupo91
If you change the "AUDIO AND SUBTITLE FLAGS" to "TEXT", what is the result for the Japanese language? Post another screenshot if you would. Thanks!
Kupo91
The flag image (jpn.png) was missing for round. I'll include it in the next update. If you change the flag style to square or rectangular it should display.
Hi, there. Is there a way to make the up next add-on display episode thumbnails instead of landscape or fanart as default?
I already asked the Up Next thread and they told me to ask here because Aeon MQ7 might be specially coded for this. I'll leave a link in the bottom.
Link:
https://forum.kodi.tv/showthread.php?tid=336747&page=7
nomnom27
I can look at adding a setting that allows you to choose which artwork is displayed by default.
Update...there is a new button in the Top Menu that will allow you to choose between landscape, fanart and thumb for the Up Next Add-on. It will be part of the next update.
