Hello, firstly, thanks a lot for your work.
I want to show you a problem in the label "4K".
When the label is ".4K." in the name of de file, it is well recognized in the botton of de display, showing the image 4kultraHD, but when the label is "4K." it is not recognized. It work well previously, two or three updates before.
Thanks a lot.
latts9923 thanks for the updates 2 things
the bluray icon right now is missing for me 3 updtes before shows the bluray icon
the label of my movies is this 60 Segundos (2000) 1080p AC3 Blu-ray-banner
the addon color picker have a issue i cant install
@latts9923 show shadown fanart doesnt work for tv series
for movies work fine
i dont know is a issue but when you are in tv series 1 season apear thumb perfect
but when is in season 2 the thumb not shows only apear the same image for season 1
escoces1968 @
Uploadergt
Those flags now require a period or dot in front of them as the first character. Try naming .4K and .Blu-ray that should work.
As for the art it may help if you clean your cache and thumbnails.
escoces1968
You're welcome! As @
Juan Mortyme stated, I reworked the code for mediatype to require only a leading "." for the flag to display. I can look at adding an option to allow for "4k."
Uploadergt
Do all of your blu-ray video files contain "Blu-ray-banner" in the filename?
What version of Colorpicker are you trying to install?
The "SHOW FANART SHADOW" button is working fine for me. Can you provide a screenshot of your KodiFlixTV Top Menu settings?
For Season 2, do you have an image named season02-fanart.jpg in the TV Show folder?
Hi, it's been a while since I wrote here. I have started using kodi again. But I only see 1.0.2.7 in the repo
1.0.5.8 zip also cannot be installed.
skin.aeonmq7.leia.mod]: Dependency for service.skin.widgets version 0.0.33 could not be satisfied.
Bruce_Banner
Howdy! For Leia you need v1.0.5.8. You can download the Skin Widget add-on
here.
Bruce_Banner
Make sure you have all these add-ons installed...
xml:
<requires>
<import addon="plugin.program.autocompletion" version="1.0.1"/>
<import addon="resource.images.studios.coloured" version="0.0.15"/>
<import addon="resource.uisounds.aeonmq6" version="1.0.0"/>
<import addon="resource.images.actorart" version="0.0.6"/>
<import addon="resource.images.moviegenreicons.xzener-flat" version="0.0.3"/>
<import addon="resource.images.musicgenreicons.text" version="0.1.0"/>
<import addon="resource.images.weathericons.animated" version="0.0.6"/>
<import addon="script.artistslideshow" version="2.1.4"/>
<import addon="script.cu.lrclyrics" version="5.5.14"/>
<import addon="script.extendedinfo" version="5.6.0" />
<import addon="script.favourites" version="7.1.3"/>
<import addon="script.games.rom.collection.browser" version="2.1.3"/>
<import addon="script.globalsearch" version="8.0.11"/>
<import addon="script.image.resource.select" version="2.0.4"/>
<import addon="script.libraryeditor" version="2.0.0"/>
<import addon="script.randomandlastitems" version="2.2.2"/>
<import addon="script.skin.helper.colorpicker" version="1.0.12" />
<import addon="script.skin.helper.service" version="1.1.24" />
<import addon="script.skin.helper.skinbackup" version="1.0.19" />
<import addon="script.skin.helper.widgets" version="1.0.38" />
<import addon="script.tv.show.next.aired" version="7.0.1"/>
<import addon="service.library.data.provider" version="0.3.2"/>
<import addon="service.skin.widgets" version="0.0.33"/>
<import addon="service.upnext" version="1.0.1"/>
</requires>
(2022-09-25, 02:54)latts9923 Wrote: [ -> ]@Bruce_Banner
xml:
<requires>
</requires>
Thanks but only this scipt can't i find script.random and last items" version="2.2.2"/>
and i get this when i try to install zip
AddonInstallJob[skin.aeonmq7.leia.mod]: Dependency for xbmc.gui version 5.14.0 could not be satisfied.
/BruceBanner
Bruce_Banner
You can download Random and last item
here.
The Leia skins definitely use xbmc.gui v5.14.0. Try installing again after you get Random and last item installed.
(2022-09-25, 13:38)latts9923 Wrote: [ -> ]@Bruce_Banner
You can download Random and last item here.
okey i try I also did a clean install of kodi and installed your repo but on your my repo. There is only 1.0.2.7 version not the latest version.
hm. It's starting to be a series of problems
AddonInstallJob[script.randomandlastitems]: The dependency on xbmc.python version 2.1.0 could not be satisfied
Maybe its better to have 1.0.2.7 version who works
Bruce_Banner
Hold on...are you trying to install this on KODI v19?
