Wanilton
Thanks for the heads up! It's strange that only the albums are not working. Do the widgets depend on script.skin.helper.widgets? I'm using v1.0.38...same on your side?
I'm on my regular work now, but yes, its the same version. I don't have time enough for check the skin code used in your mod.
Wanilton
No worries bud. Thanks for your help!
1. Hi i want to start the mainmenue with movies, but kodi starts always with TV-Shows.
How can I change this?
2. Is it possible to update the skin automatically?
3. Is artworkbeef preinstalled?
klarahimmel
1. There is a bug with Leia where TV Shows is displayed by default only with the horizontal main menu...I'm still unable to fix the bug. The vertical menu does not have that problem.
2. I'm working on making updates to the skin available on my Repo. It's not entirely stable yet...still working on it.
3. Artwork Beef is a separate install.
Just updated to Kodi Leia RC5 and now my Aeon MQ7 leia mod has disappear
Any help!
(2019-01-03, 14:43)Wanilton Wrote: [ -> ]XBMC GUI = 5.14.0 in Kodi Leia 18 RC5, mod author need fix the addon.xml file for fix. Or change yourself 5.13.0 to 5.14.0, will solve.
@latts9923, the widget for music recently albums work fine here with mq8 using the same script skin helper service version, i don't have issue in my MQ7 mod version too.
Wanilton
I change 5.13.0 to 5.14.0 in the addon.xml file and still doesn't work.
import addon="xbmc.gui" version="5.14.0"/>
Any help
I have the same problem. Changed the xml file to what was suggested and the skin stil does not appear in my list.
Fyi I am running on Kodi 18!on the Nvidia shield TV. Latest updates etc.
Hi there,
I recently downloaded the 1.0.1.3 version and it have a size of 244 MB. Yea, Mega Byte.
Could this be correct?
Greetings
(2019-01-05, 13:48)K1ngLear Wrote: [ -> ]Hi there,
Greetings
Yeah that's the correct size for the full skin
movie78
ttringle
I just installed the latest nightly and the skin is working.
(2019-01-05, 07:01)ttringle Wrote: [ -> ]I have the same problem. Changed the xml file to what was suggested and the skin stil does not appear in my list.
I am on Nvidia Sheild too and @
latts9923 its still not working:
movie78
Hmm...I installed the Windows version. Let me install the latest Android nightly on my FireTV Cube and see what happens.
