Uploadergt
The case for the pause screen is controlled by "USE MEDIA CASE" for the Right List view.
This is for anyone using the MQ7 skin v1.0.5.9 for Leia that would prefer a cleaner look without the ... being displayed on the Media Bar when there is information missing.
Download this repacked Textures.xbt file and use it to replace the Textures.xbt located in the "media" folder of the skin. Doing this will not have any adverse effect on functionality so all flags will still display if/when the required information is available. It only substitutes the ... with a blank space. Make a backup copy of the original Textures.xbt file first in case you wish to revert back to default.
Here are a couple screenshots taken after replacing the Textures.xbt file.
With missing information
With all info available
Enjoy!
latts9923 check this please
In the view Showcase when the case is disabled. works fine but you can select at the same the option "open media case' when the case is disabled. Not stop showing the option in the context menu
Uploadergt
I see what you mean. I'll work on that. I also noticed it leaves the inside of the case visible for Sets when you disable the case. I've already started pushing the skin updates to the repo, so this will be a fix in a future update. Thanks for letting me know!
Repacked Textures.xbt for Aeon MQ7 Leia Mod v1.0.6.0
This is for anyone using the MQ7 skin v1.0.6.0 for Leia that would prefer a cleaner look without the ... being displayed on the Media Bar where there is information missing.
This Textures.xbt only differs from the original in that I have replace the flag_default.png with a clear blank .png. This will not have any adverse effect on functionality so all flags will still display if/when the required information is available.
DOWNLOAD
How to install:
1) Make a backup copy of the original Textures.xbt file first in case you wish to revert back to default.
2) Unzip the download.
3) Using the Textures.xbt from download replace the existing Textures.xbt file located in the skin's "Media" folder.
Media Bar will missing info but no ...
Media Bar with all info
Hello friend, I have problems with script.embuary.helper constantly giving an error and I can't enter files from the movies submenu. discs.
I have uninstalled and now I can not install it gives installation failed. I am in the new version 1.0.6.0 pwero I already did it in 1.0.5.5, how can I solve this?
Eladios
Can you post your log after you get the installation failed message?
(2022-11-04, 14:58)latts9923 Wrote: [ -> ]@Eladios
Hi, friend. Well, the problem is that when I go to the Kodi registry there is nothing. puts kodi booted fine and nothing else. I don't know if there is another place to look at the log. I use an android box. Now I also have problems with the Oscars and fundraising. it no longer appears or appears.
Eladios
On my Fire TV, the log is located at Android/data/org.xbmc.kodi/files/.kodi/temp
MB1968
You're welcome!
(2021-09-12, 17:17)Juan Mortyme Wrote: [ -> ]@Eladios
You are very welcome. Let us know if it fixes your problem?
Yes thank you very much this solved the problem. it has worked great until now that kodi was broken. and it wouldn't start. so i had to go settings and totally wipe the data. started from scratch. good thing i had a backup of version 1.0.5.5 aeon mq7. and it was perfectly restored. the problem is that when restoring aeon mq7 now no Oscars or collections appear. The problem with the embuary helper has been resolved for the time being since it hasn't been released anymore. but the collection and oscars do not come out. I have updated again to the metautils version 1.0.37.1 since now there was 1.0.46 at the moment nothing comes out. thanks for all the help you provide.
(2022-11-05, 12:20)latts9923 Wrote: [ -> ]@Eladios
@MB1968
You're welcome!
Voy a comprobar si tengo registro allí. Gracias. Como le comentado al compañero esto se a resuelto de momento no a dado más error. Y los oscars y recaudación he bajado la versión de metautils a 1.0.37.1 que me funcionó muy bien. De momento no a funcionado ya que sigue sin aparecer.. gracias de nuevo @
latts9923 por todo tu trabajo que haces. Para mí es la mejor skin que hay para kodi. Mil gracias
(2022-11-05, 13:49)Eladios Wrote: [ -> ] (2022-11-05, 12:20)latts9923 Wrote: [ -> ]@Eladios
@MB1968
You're welcome!
Voy a comprobar si tengo registro allí. Gracias. Como le comentado al compañero esto se a resuelto de momento no a dado más error. Y los oscars y recaudación he bajado la versión de metautils a 1.0.37.1 que me funcionó muy bien. De momento no a funcionado ya que sigue sin aparecer.. gracias de nuevo @latts9923 por todo tu trabajo que haces. Para mí es la mejor skin que hay para kodi. Mil gracias
I'm going to check if I have registration there. Thanks. As I commented to the colleague, this has been resolved for the time being, it has not given any more errors. And the oscars and collection I have lowered the version of metautils to 1.0.37.1 which worked very well for me. So far it hasn't worked as it still doesn't appear... thanks again @
latts9923 for all the work you do. For me it is the best skin there is for kodi. Thank you sorry for spanihs
