Bruce_Banner
Ah...OK. You need the Matrix version of the skin. Check out my Aeon MQ 7 for Matrix thread. It has an installation guide.
Just updated, loving the skin, but have an issue i can't figure out [was hoping the update would resolve it]. music art related..i have an artist info folder, separate from my music folder if that helps, using view 7.. When playing an album from my music folder i get fanart and discart as long as i choose fanart as the background. Skinhelper as the background is blank. when playing a station in shoutcast the opposite is true; fanart is blank, but skinhelper loads fanart from the extrafanart folder in the artist info folder... any ideas are welcome. With that exception, the skin has been a joy since inception. of note the cd is named disc.png in the artist info folder? I've named all others as discart.png everywhere else and they load fine...
latts9923
When in TV series if select show fanart shadow works fine but if i have no floor selected at the same time. The show fanart shadow doesnt work
HSV AVGuy
I did some testing with the artwork settings. Skin Helper was displaying fanart in music viz until I removed the artist and imported again. I'll see if I can figure out what's going on. Use discart.png for all your disc images.
Uploadergt
I reproduced the problem. I'll take a look. Thanks for letting me know!
latts9923
In the view list3D when you disabled the option use case. Nothing happend follow show the case
I add the dot .Blu-ray the icon shows again only when the option show kodiflix flags is disabled. When is enabled the icon is missing
(2022-10-02, 19:44)Uploadergt Wrote: [ -> ]@latts9923
Uploadergt
That is normal. Different flags are displayed if the Show Kodiflix Flags is enabled. You may have noticed when enabled the Subtitle and additional Audio Stream flags are also not displayed either. On the other hand when disable the rotten tomato's and Oscars flags are not displayed.
Perhaps @
latts9923 could look into adding the RT and Oscars flags to the normal flags then that setting could be removed. If the spacing between the flags is tightened up there might be room.
Uploadergt
Juan Mortyme
I can add the mediatype flag to the KodiFlix flags, but I don't think I can tighten the default flags enough to get the RT and Oscar flags inserted. I think the only way to get them to fit would be to reduce the size of the flags across the board.
KodiFlix came with it's own flag code when I added the view to MQ 7, so I left it in and made it work. When MQ 8 was released and I started adding mods, I left out the KodiFlix flags and just used the default flags.
latts9923 dont worry its not necesary the Blu-ray flag. The rt and oscars work great. Im using all new things you implemented im checking if work correctly.
juan mortyme thanks to explain me
Thanks @
latts9923
Please check this
"SHOW ALTERNATE POSTER" not shows for me when disabled case in right list
SHOW CAST" shows for me when is enabled nothing happend
CHANGE PAUSE SCREEN" no display this option in context menú
3D view when I disabled use case. Nothing happend the case follow display the case
Uploadergt
I need to add a note to the update post. You have to use "POSTER" as the "CASE ART" in order to see "SHOW ALTERNATE POSTER".
The new "SHOW CAST" button is visible by going to SKIN SETTINGS > OPTIONS MENU and enable the CHANGE PAUSE SCREEN setting.
If you're talking about the "USE MEDIA CASE" button in the Top Menu for List 3D, I just removed it. It served no purpose and was added by mistake at some point. Thanks for letting me know!
Thanks a lot for the upgrade.
Solved the problem with the label 4k. Now work well when the name don't have dot before 4K
I only have a problem. Is not possible to update the addon "colorpicker".
escoces1968
You're welcome! I'm glad that fixed your 4k problem.
You can download v1.0.14 of the Colorpicker add-on
here.
MB1968
You're welcome!
latts9923 please check this
in the kodifilix view when in the context menu when the option "cases" is disabled. i think only shows the poster but when you are watching a movie and pause the movie the box of the movie is there
in the same view when you pause the movie the poster is not displaying correctly
