latts9923
No worries, buddy. It's no big deal for me to do a quick recompile of the textures.xbt and tossing it up for sharing. It's the least I can can do. Just trying to contribute in some small way.
(2022-11-12, 13:46)latts9923 Wrote: [ -> ]@Eladios
Correct...I see the same behavior. I can make the "BACKGROUND IMAGE - USE COLLECTION FANARTS" option display Movie images for video playlists in the main menu, however it will be random movie fanart of your entire library...not your video playlist.
Thank you very much @
latts9923 if for me it would be nice to have random images from the library. it's better than having to create a folder with images. thanks for the update. Tomorrow I will install and test. you're the best.
Eladios
You're welcome...and thanks for the kind words! I have the grab fanart script working for video playlists in the main menu. It will be included in the next update.
Hello all,
Is there a way to disable widgets on the main menu?
Youffran
Howdy,
Go to the menu item that has the widget you want to disable, access the widget menu again and select "NONE - CLEAR".
latts9923, what's the difference between having diffuse for discart enabled or disabled? Can you show it with 2 screenshots?
Hi @
latts9923 thank you very much for the update. I already installed it and background image - grab fanart script is working great. you're the best. we have the best skin for kodi out there and the best developer. Thanks again for all you do.
MB1968
If you have a transparent background for your disc art, you won't notice much of a difference. Here's an example of the setting enabled and disabled...
Enabled
Disabled
When you'll really notice the difference is when you have not removed the background...like
this.
Eladios
Hello again @
latts9923. in the update there is a problem with library fanart. Now the artwork helper fanart option is checked, nothing comes out. black screen. Before, multiple images of the film came out. extra fanart if you display a wallpaper. but always fixed does not change. Do you know what could be due to?
(2022-12-01, 13:42)latts9923 Wrote: [ -> ]@MB1968
When you'll really notice the difference is when you have not removed the background...like this.
Thanks for explaining. The white square only appeared while playing a music file and/or for a specific music viz setting?
Eladios
I just tested the Artwork Helper art setting, and it is displaying all the fanart for the Movie. Do you have the fanart named fanart.jpg, fanart1.jpg, etc. and placed in the Movie folder?
MB1968
You bet! The problem appeared in music viz two updates back when I removed the diffuse image for disc art from all the layouts.
