(2019-03-18, 19:53)Wanilton Wrote: [ -> ] (2019-03-18, 16:37)suisse Wrote: [ -> ]First of all, great skin, really fantastic work!
I have one question, and I feel it might be just due to being first time on any Aeon skin... (sorry in advance)
But what exactly are those Flexible Widgets about ?
I ran accidentally into this when pressing the up arrow in a main menu item.
I played around there, saw widgets (e.g. Recently added movies) being added to the background screen area.
But I somehow got stuck and could not erase those again. For sure I overlooked something in this concept.
Ended in having the provided "factory reset of skin" in skin settings to be done. (A real great final rescue knob!)
Also I read something on "Fast Change". But I am unsure what this does or how.
Before playing around again. Is there any short explanation on how to use all of this ?
I also feel this one might become a potential "problem" if some of my family members accidentally run into this flexible widget picker...
So another dumb question, I am sure. But is there somewhere a "disable flexible widget" setting ?
Actually even better would be a "disable modification of flexible widget".
Once I will understand the feature I could properly set it up and then prevent family members of
accidentally creating a mess. I know from other skins there are kiosk modes. But those tend to block away quite a lot at once ...
Appear items above the main menu when choosing widget, with info and shortcuts. After choose one widget, the correct way to reopen widget selector is to click enter in widget button, see the image
The only way for disabling flexible widgets is using kiosk modes.
Wanilton is this still the case? I am using kiosk mode but flexible widgets are still enabled for pages with no widgets. Settings as below.
mrx777
When active the option kiosk here, the widget button turns off.
(2020-06-04, 14:20)falexandru Wrote: [ -> ]Thank you for help. It is posibile to install debrid on MQ8 ?
Never used, sorry I don´t know.
(2020-06-04, 15:30)DAVEYBROTHERS Wrote: [ -> ]Hello,
I am having a problem with aeon mq8 2.9.0.
Once in ten when kodi is started, the skin resets, causing me to lose all of my settings.
Many Thanks
Hello,
no one has any idea what could be bugging?
@ "diegocuarti" Debe
editar los nombres de archivo de las películas, incluido .hdr. y .10bit. trabajar. Espero que esté más claro ahora. Nombre de
archivo anterior
movie.bluray.mkv
después de cambiar el nombre de archivo
movie.bluray.10bit.hdr.mkv
Necesita volver a crear su biblioteca, porque cambia el nombre de arch
Hola de nuevo, les daré un ejemplo de cómo lo hago.
película descargada: Top Gun (1986) [UHDRemux 2160p HEVC DD 5,1 Esp True-HD Atmos 7,1 Eng Subs] .mkv
película de renombre:Top Gun (1986) [UHDRemux 10 Bit.HDR DD 5,1 Esp True-HD Atmos 7,1 Eng Subs] .mkv
en el reconocido puse una manera u otra siempre me dan la misma,
He tratado de poner una imagen de lo que parece a mí, pero no sé cómo insertar imágenes aquí, pero yo siempre conseguir SDR 8 bits.
película de renombre: Top Gun (1986) [UHDRemux 10 Bit.HDR DD 5,1 Esp True -HD Atmos 7,1 Eng Subs] .mkv
tratado de poner una imagen de lo que parece a mí, pero no sé cómo insertar imágenes aquí, pero siempre obtengo SDR 8 bits
diegocuarti
.10bit. no 10 Bit or .10bit -> need have one dot before and after bit
.hdr. no .hdr or .HDR -> need have one dot before and after hdr word
So
Top Gun (1986) [UHDRemux.10bit.hdr.DD 5.1 Esp True-HD Atmos 7.1 Eng Subs].mkv
Please post only in english here.
(2020-06-08, 13:40)Wanilton Wrote: [ -> ]@ "diegocuarti"
.10bit. no 10 Bit o .10bit -> necesita tener un punto antes y después de bit
.hdr. no .hdr o .HDR -> necesita tener un punto antes y después de la palabra hdr
So
Top Gun (1986) [UHDRemux.10bit.hdr.DD 5.1 Esp True-HD Atmos 7.1 Eng Subs] .mkv
Por favor, publique solo en inglés aquí.
Lo siento, será que cuando se usa el traductor, se traduce al español
So
Thank you very much for your help, I have already achieved it, I need you to check the audio, whether it is dts, dolby etc.
going back to the theme of the covers.
What would be the example of renaming a movie so that the lower part like the image appears.
As much as I rename, I only get something like 4K, HDR, but I'm missing things
(2020-06-08, 13:40)Wanilton Wrote: [ -> ][font][font]@ "diegocuarti" [/font][/font]
[font][font].10bit. [/font][font]no 10 Bit o .10bit -> necesita tener un punto antes y después de bit [/font][/font]
[font][font].hdr. [/font][font]no .hdr o .HDR -> necesita tener un punto antes y después de la palabra hdr [/font][/font]
[font][font]So [/font][/font]
[font][font]Top Gun (1986) [UHDRemux.10bit.hdr.DD 5.1 Esp True-HD Atmos 7.1 Eng Subs] .mkv [/font][/font]
[font][font]Por favor, publique solo en inglés aquí.[/font][/font]
excuse me for continuing to insist but as you have renamed the movie in the image so that all the information that appears in the lower part appears
I don't understand what is your problem ? In my memory, the first one is the studio and doesn't depend of file name.
Studio flag is based in info available in the database, skin compares studio name in the database with the studio image art filename in resource.images.studios.white, if equal, show the image. The Original MQ skin, need only one studio to compare. Scrapers Kodi get only one studio to insert in the Kodi database, but other external metadata tools (ember, emby, mediaelch), get more values, so when to compare multiple values with one single image, don´t show the flag.
Don´t show the flag, when don´t have a studio name in the database or have multiple values, or respective studio image art available in the resource.images.studios.white or when compare fail.
(2020-06-11, 14:18)Jacques56 Wrote: [ -> ][font][font]No entiendo cual es tu problema? [/font][font]En mi memoria, el primero es el estudio y no depende del nombre del archivo.[/font][/font]
what information provider do you use?
No matter how much I change p`roveedro and renown the movie I do not get more information in it
look at the bottom part, information is missing, in that you have put, it has everything
(2020-06-11, 15:58)diegocuarti Wrote: [ -> ] (2020-06-11, 14:18)Jacques56 Wrote: [ -> ][font][font]No entiendo cual es tu problema? [/font][/font][font][font]En mi memoria, el primero es el estudio y no depende del nombre del archivo.[/font][/font]
[font][font]¿Qué proveedor de información utiliza? [/font][/font]
[font][font]No importa cuánto cambie p`roveedro y renombre la película, no obtengo más información, [/font][/font]
[font][font]mira la parte inferior, falta información, en eso lo has puesto, tiene todo[/font][/font]
[font][font]lo que quiero es que me informen si la película es de 4k hdr o sdr, para indicar el audio, vamos a toda la información que les llegue[/font][/font]
(2020-06-11, 15:58)diegocuarti Wrote: [ -> ] (2020-06-11, 14:18)Jacques56 Wrote: [ -> ][font][font]No entiendo cual es tu problema? [/font][font]En mi memoria, el primero es el estudio y no depende del nombre del archivo.[/font][/font]
For movies I use themoviedb
Studio flag is not present very often. Only sometime
