hello for two days my discart no longer appears an idea why?
hello I installed to see the ace 2 skin and I have the discarts that appear, I have not been able to see them in aeron mq8 for a few days
(2021-04-07, 08:43)eric777 Wrote: [ -> ]hello I installed to see the ace 2 skin and I have the discarts that appear, I have not been able to see them in aeron mq8 for a few days
I reinstalled everything from scratch, no errors but there is no way to make the disk and logo reappear
Suggestions accepted!
to put it simply, those who use Aeron MQ 8 Or the mod you have the discart or not? THANKS.
MQ8 is not available anymore I needed to reinstall everything and I can't get the skin anymore. Any Help?
MQ8 is one skin only for use with Kodi Leia. The skin continues available via the Kodi Leia repository.
MQ9 will be matrix compatible.
Exist one
mod available MQ8 to use with Kodi Leia by latts9923.
(2021-04-08, 23:50)Wanilton Wrote: [ -> ]MQ8 is one skin only for use with Kodi Leia. The skin continues available via the Kodi Leia repository.
Exist one mod available MQ8 to use with Kodi Leia by latts9923.
I have been using Kodi Leia on two different devices with Aeon MQ8 for a very long time and for 8 days on both devices I no longer have discart them whereas before I had them, I specify on both devices it's the same, why ? I haven't changed anything for weeks.
(2021-04-09, 09:11)eric777 Wrote: [ -> ] (2021-04-08, 23:50)Wanilton Wrote: [ -> ]MQ8 is one skin only for use with Kodi Leia. The skin continues available via the Kodi Leia repository.
Same situation
Wanilton you can confirm that there is a problem now with version lea and MQ8 On the discart which no longer appears as well as the multimod version of latts9923 on leia as well.
Bonjour à tous
j'espère que je suis au bon endroit (novice) sans avoir a
ma question est yat il un moyen pour que sur kodi mq8 peut prendre automatiquement dans le dossier de chacun de mes films (+ de 5000) le discart en locale sans avoir à le rentrer
avant je passais par TMDb mais trop problème dans la disparitions des films et des séries que j'avais créé, c'est dommage car en "liste basse" les discarts et les logos que je n'avais même pas les téléchargements s'affichait sans problème.
Mais vu que je ne pouvais plus continuer un scrapper sur TMDb je me suis mit en NFO avec tinyMediaManager. j'ai créer une partie de mes nfo qui sont dans le dossier de mes films (un dossier par film) je me retrouve donc avec pleins de fichiers supplémentaires dans mes dossier dont: film-disc.png, film-discart.png Disc. png et Discart.png
- faut-il renseigner l'emplacement du discart dans le nfo?
- ya t'il un réglage dans kodi?
- faut-il un addon en plus?
je ne me vois pas paramétrer tous mes discart pour chacun de mes films surtout que j'utile kodi sur 9 appareils différents
Si qu'un à la solution je suis preneur sachant que je novice, Merci d'avance
(2021-04-10, 15:34)denislamalice94 Wrote: [ -> ]Bonjour à tous
Bonjour,
Tu as du remarquer que ce forum est en anglais ?
Je doute donc qu'on te réponde.
En ce qui concerne les nfo, je ne les utilise pas. The moviedb fonctionne correctement pour moi.
Wanilton how to add temperature CPU?
Hello, I have a little problem with the skin.
In movies, main window, I can't see Director, Writer and Studio. When I go at the info window, I see perfectly these fields.
Which is the problem?
Thanks in advance.
Hello!
First sorry for my bad english ...
I am trying to install the modification of the MQ8 skin in the nvidia shield :
here
On windwos I can do it but in the nvidia shield I do not know where the directory to copy these files is located ...
Any help?
Thank you!
One more question please
(I can't edit my previous msg):
What is the best tagged name profil? I renaming my files like this but I whant the maximum tags for a maximum info:
name.10bit.HDR.atmos
thank you!
