Hello,
Can someone tell me how I can do an Update Library ?
I'm using the movie database scraper.
After adding a file Ibiza.mkv the scraper is taking the wrong movie.
So I added a Ibiza.nfo file like explained here
https://kodi.wiki/view/NFO_files#Parsing_nfo
But I don't find how to update the library to force kodi using the nfo file.
tweetysat
Movies, Submenu Files, Press C above your Movies Sources, change content, now choose Local Information Only in Choose Infomation Provider.
Press ok, scan again. Or press i above the item to load nfo to Kodi database.
Hi all,
Having a problem with Studio Icons Coloured addon not updating and failing, any ideas? Also, can the Artist slideshow artwork problem be fixed?
Hello,
I need some help with the upnext addon. The addon developer directed me here, because I'm using it with this skin.
There are some videos that doesn't have any end credit and when the upnext addon notification pops up the screen is dimmed and I can hardly watch the end of the show.
So I would like to watch the last 30 sec with the nextup pop-up but without the screen fading. How can I achieve that?
Thank you.
(2020-01-07, 10:04)mind12 Wrote: [ -> ]Hello,
Thank you.
It's easy. Search the MQ8 folder for these four xml files: script-upnext-stillwatching, script-upnext-stillwatching-simple, script-upnext-upnext, script-upnext-upnext-simple. Open it with Notepade ++ and search for with code.
<control type="image">
<left>0</left>
<top>0</top>
<width>1920</width>
<height>1080</height>
<texture>black.png</texture>
<colordiffuse>a4303030</colordiffuse>
<include>animation_fade</include>
</control>
and replace
<!-- <control type="image">
<left>0</left>
<top>0</top>
<width>1920</width>
</control> -->
(2019-03-02, 22:31)MarcosQui Wrote: [ -> ]
skin is awesome!
thx
is there any way to disable the "window popup funtion"?
when i watch TV or play a video, and i go to the main menu at the same time, the video plays in the upper left window. Thats cool. But after a few seconds that mini window pops up at the middle of the screen and hides the menu. so i have to close that unwanted pop-up at least 20 times a day, which is annoying.
beside of that the skin is just perfect. Help plz
So I must be really dumb.
I've read everything here and cannot figure out how to get Concerts into the Concerts submenu.
Things I have done.
Created a smart playlist called Concerts that's identified by path.
But I can't get the concerts folder to immediately reference that playlist.
I have to navigate back a couple of folders then back through videos -> playlists.
In the same vein, I cannot figure out how to exclude the concerts from the movie menu.
HALP PLS!
(2020-01-05, 16:16)Wanilton Wrote: [ -> ]About artist slideshow, get or revert to previous version script, edit addon.xml, rename version number to 3.0.0, will return to work fine...it´s one way to fix easily.
Can anyone point me to a Artist Slideshow 2.x package zip? I didn't see anything other than MASTER (or New Version -- Newer) on the GIT and no packages published.
Thanks,
Brian
(2020-01-09, 17:17)moejoe Wrote: [ -> ] (2019-03-02, 22:31)MarcosQui Wrote: [ -> ]
skin is awesome!
thx
Have one option to turn off, in skin settings, main menu, disable the option
(2020-01-13, 13:59)Korzic Wrote: [ -> ]So I must be really dumb.
Things I have done.
HALP PLS!
To turn off use the Customize Main Menu option (submenu available in the Settings item). Use replace function, choose None, and done, excluded.
