(2020-07-03, 21:28)Wanilton Wrote: [ -> ] (2020-07-03, 20:11)zwat Wrote: [ -> ]I did something stupid again and updated ubuntu and kodi. had mq8 working on kodi alpha, but after update the skin got disabled. is there any tweaking I can do to get it up and running again? would rather have a unstable mq8 than the 4 skins that are available. can't wait for mq9
Kodi team changed xbmc.gui 5.14.0 to 5.15.0, so previous Leia skins don´t install more. Edit the addon.xml file in skin.aeonmq8 folder, so that it calls for xbmc.gui 5.15.0 then install from zip. It won't magically fix anything in the skin, just allow Kodi to enable it.
Thanks for that tip! Worked a treat on my end for the latest alpha. Obviously a lot of addons aren't working due to the python3 upgrade but nice to start testing!
Firstly, a massive thank you to the developers for this outstanding piece of work. To those who criticise, it is worth remembering that you spent no time developing this skin, no time maintaining it and you did not purchase it, so please cut those who did the work some slack....
And now to my question - with advance apologies for the obvious repitition - How, exactly, should I name my Movie and TV episode files in order to use the media flags (particularly audio) in this skin? As examples I currently name Movie files as: Avengers - Endgame.2019.4k.hdr.10bit.mkv and TV episodes as: Hanna.S02E01.mkv. Do I need to add anything to file names to get audio elements such as Atmos, DTS, etc?
MBE4645
In the filename needs
.atmos. or .atmos-
.dts-x. or .dts.x. or.dtsx. or .dts-x- or .dts.x- or .dtsx-
(2020-08-16, 21:40)MBE4645 Wrote: [ -> ] (2020-08-16, 15:01)Wanilton Wrote: [ -> ]@MBE4645
.atmos. or .atmos-
Thank you
Again thank you. Managed to get all audio media flags to display correctly now with one exception: DD+. Appreciate any advice/guidance on this.
Good morning
I ask if this version of Skin can be installed in ZDMC
(Kodi version 18.4 for Zidoo)
Sincerely thank you
Hello all, does anybody know how to disable for me unwanted/unused (rewind, forward...) buttons in the player menu?
I have watched some instructing video on the YT, but it was for MQ7. While pausing video there was shown a "Customize this menu" button among other control buttons, but in MQ8 version I do not have this button for customising menu.
Thank you.
PeterX
Yes, was removed the option to customize the buttons in MQ8.
Wanilton,
Can you tell me what copy properties to storage in customize main menu is used for?
rocko
Yes, think you customize one default item or create a new item and customize all in the main menu. Now you have one way to save all customization in one particular item (copy to storage), and after use the item saved in other place (menu or submenu place), it´s one way to reorder the customized item saved previously with all included.
Sorry for late reply been gone for a few days.
I am not very smart in this area, can you give me an example of how to use copy to storage, I still don't understand.
hello
i have a trouble, when lcu lyric installed my navigation become jerky
there a fix ?
merci
Hello @
Wanilton
Thanks for your work.
Please ask if there is an option to add the flag of the film's country of origin (in this case for example U.S.A.) where I put the red arrows. (like ACE2)
if this is possible, how can I do?
thank you very much
(2020-09-11, 12:36)rossomike1966 Wrote: [ -> ]Hello @Wanilton
thank you very much
I think you have the feature using the mod version by Latts9923.
In the Aeon MQ9, Marcos implemented the flag by default, equal ACE2 skin.
