works skin for kodi matrix, try too install it and half error.
fuorigioco1981
Choose one image file, for the OK button to turn On.
diegocuarti
No, the default skin is only for use with the Kodi 18.9 Leia.
Have one skin mod by latts9923 to work in
Matrix.
(2021-01-02, 22:12)Wanilton Wrote: [ -> ]@fuorigioco1981
@diegocuarti
Have one skin mod by latts9923 to work in Matrix.
the ok button is greyed out! can't go on to choose any image!
fuorigioco1981
Do you press enter in External Storage to opened and show the files?
(2021-01-03, 14:26)Wanilton Wrote: [ -> ]@fuorigioco1981
Iam on nvidia shield there is no enter. the ok button can't be pressed!
I edited Userdata\aeonmq8\settings.xml so that 'Movies' would only be sourced from the Movies folder in my Favorites, rather than the default setting of any folder labelled 'Movies'. This was to exclude my Home Movies, which I want to have as a seperate Main Menu item.
Although this filter works, 'Movies' now just shows a simple list - all the info, fanart etc, has gone, and Info cannot be called up by an 'I' keystroke.
What else do I need to change to restore these?
Grateful for any advice.
The code I changed in settings.xml was
<setting id="menu1.path" type="string">ActivateWindow(Videos,[file location]/,return)</setting>
My only source folders for this are 'Movies' and 'Home Movies'. None have any NFO files.
The view for 'TV Shows' remains OK.
robbie599
You have customize the main menu for creating or replace the items, don´t change the code, it´s no necessary.
(2021-01-06, 22:14)Wanilton Wrote: [ -> ]@robbie599
Thanks! Appologies for being exceptionally dim, but I can't see how to do this. Very grateful if you could elaborate.
Use script favourite,
http://mirrors.xbmc.org/addons/leia/scri...-7.1.3.zip
Now using the context menu, add the item to favourite.
Customize the main menu is one option available in the Settings submenu.
Use the replace function to change one empty or Default items to your favorites.
(2021-01-08, 14:34)Wanilton Wrote: [ -> ]Use script favourite,
Brilliant! Thanks!
It's (sort of) easy when you know how!
Hi, I'm just curious about the following, is it possible to modify the .path setting of any of the predefined menu items (lets say movies)? I want to keep all of its properties and just modify its action to show a playlist. If I use the replace function I get the desired action to work but I lose all the original movie settings (backgrouns etc). Using an empty item doesn't help either... Thanks in advance!
hello I would like to know if this skin manages widgets like on aura for example?
bonjour je voudrais savoir si ce skin gère les widget comme sur aura par exemple ?
(2021-01-06, 09:58)fuorigioco1981 Wrote: [ -> ] (2021-01-03, 14:26)Wanilton Wrote: [ -> ]@fuorigioco1981
Wanilton all ok now! you were right to press "enter"!
in aeonmq8 without multimod can we have watched flag icon in right list?or anywhere else?i would prefer right list!
