(2019-03-08, 18:44)Wanilton Wrote: [ -> ] (2019-03-08, 16:54)Arkel Wrote: [ -> ]Hello,
I would like to use the background of a predefined menu (like concert or others) for a personal menu. Is this possible ? I am on android shield TV.
I also noticed, when I disable the smart submenu, it appears anyway when you have not created a submenu. normal running ?
Great work, love your skin !
Sorry for my english, my french is better
Default backgrounds you find in skin.aeonmq8, backgrounds folder.
About smart submenu, I send the info to Marcos check, thanks for report.
I found the backgrounds, works fine, thanks for your help.
But I have another problem with Artist Slideshow, Aeon MQ 8 may not be the problem. it's more of a question about your general knowledge of kodi I think.
If in the settings of ASS I choose Audiodb for images, I have images but only two. If i choose fanart.tv (as i prefer) i have 'no images for this artist' each time, even though I have a personal API key. I'm doing something wrong ?
Thanks again.
First, thanks for the great skin. Some notes, in tv there should be no animated disc in tv info and no disc menu entry in osd settings. Is there an option to change the library views like list, banner, wall and others?
(2019-03-10, 11:02)jespermart Wrote: [ -> ] (2019-03-03, 21:40)Wanilton Wrote: [ -> ] (2019-03-03, 21:31)halidri Wrote: [ -> ]Hi, realy nice work, looks great!
But i have some problems/issues
1. my extrafanarts will not shown, i have they in a subfolder (extrafanart) in the moviefolder. With Kodi 17.6 and MQ7 does it work.
2. With my collections i have the problem, it shows all fanarts from movies inside, but here i want only ONE collection fanart.
3. (screenshot) I use use tvtunes (TV Melodies is not an alternative), because it's important for me and there is no other way for me to play it correctly. It works good, but when browse to my collections, it plays nothing, when i go INTO my collections, it works.
With Kodi 17.6 and MQ7 does it works also in this case, i mean when i only browse in all my movies and stop at a collection, not need to go inside a collection.
4. (screenshot) In all my movies i have only the two flags_default, How can i delete this, this looks very ugly. I don't know what is missed.
With Kodi 17.6 and MQ7 does it works correctly and had never this problems before.
1. Something in your side, was tested a lot.
2. Customize in main menu area choose folder with your multi images.
3, Support was removed, tv tunes was banned
4. ... dots are used for show 10 bit and HDR flags, need have in filename .hdr. and .10bit for appear, will appear 3 dots if don't exist info. It's no possible remove.
Where do I find the coloured icons used in the last picture?
Need to install a few add-ons, in our plans submit to the official repo soon. At this moment, we have a provisory repo available in
our forum, only to share new themes and add-ons (colored flags). After installing the add-ons, only need to configure the resource images in the skin settings area, icons and images item.
(2019-03-10, 12:14)Arkel Wrote: [ -> ] (2019-03-08, 18:44)Wanilton Wrote: [ -> ] (2019-03-08, 16:54)Arkel Wrote: [ -> ]Hello,
Thanks again.
Arkel
I have local arts, and configure script Artist Slideshow to use local and remote arts. When don´t find a use one default art (fallback).
If you provide the artist name, its easy to verify if have online arts or check 2 services if exist arts available.
(2019-03-10, 14:36)Wanilton Wrote: [ -> ]Need to install a few add-ons, in our plans submit to the official repo soon. At this moment, we have a provisory repo available in our forum, only to share new themes and add-ons (colored flags). After installing the add-ons, only need to configure the resource images in the skin settings area, icons and images item.
Are there available in white style too?
If white style is default style, anyway, is there an addon with an higher number of studio icons (in may cases, the studio icon is not displayed) then the default one?
(2019-03-10, 03:02)Wanilton Wrote: [ -> ]@Jumpy73
Have one issue, will be fixed in next release, but work with a few weather icon addon, try with HD animated and will see.
Yes, confirm it works with HD animated in my environment too. It not works with monstr icon set too
Anyway I like outline HD because total white and stylized (in my opinion better with the Black&White theme
(2019-03-10, 03:02)Wanilton Wrote: [ -> ]Check if you have .bluray in your movie filename. Here work ok.
I have never had this info in filename while I used previous versions of Kodi (since kodi 16) and Skins (default skins and AEON MQi previous releases) and the flag style on the media case always appeared in the right way before
(2019-03-07, 12:29)MarcosQui Wrote: [ -> ]Also in the next build I will include a flag selector so that the user can activate or deactivate the media flags they want. Hide the HDR or 10bit flags for example.
Just for my understanding... are the 2 media flags which we are speaking about used for only those informations (HDR the 1st one and 10 bits the 2nd one) or can display other info for movies with resolution lower than 4k?
If so, what are the possible alternative?
More in general, if a flag is not available the slot in the media bar could be hidden. In such a way the user would never have empty slots in media bar
(2019-03-10, 17:38)Jumpy73 Wrote: [ -> ] (2019-03-10, 14:36)Wanilton Wrote: [ -> ]Need to install a few add-ons, in our plans submit to the official repo soon. At this moment, we have a provisory repo available in our forum, only to share new themes and add-ons (colored flags). After installing the add-ons, only need to configure the resource images in the skin settings area, icons and images item.
Yes, its internal white studios, but you are free for use any other via skin settings, icons and images, choose another or create a new one, will work fine.
(2019-03-10, 18:09)Jumpy73 Wrote: [ -> ] (2019-03-07, 12:29)MarcosQui Wrote: [ -> ]Also in the next build I will include a flag selector so that the user can activate or deactivate the media flags they want. Hide the HDR or 10bit flags for example.
MarcosQui answer your question in this post
https://forum.kodi.tv/showthread.php?tid...pid2831060
(2019-03-10, 19:59)Wanilton Wrote: [ -> ] (2019-03-10, 18:09)Jumpy73 Wrote: [ -> ] (2019-03-07, 12:29)MarcosQui Wrote: [ -> ]Also in the next build I will include a flag selector so that the user can activate or deactivate the media flags they want. Hide the HDR or 10bit flags for example.
"Also in the next build I will include a flag selector so that the user can activate or deactivate the media flags they want. Hide the HDR or 10bit flags for example."
this is what MarcosQui says into the post you linked.
I didn't find the answer to my question...
If so, what are the possible alternative?"
thanks for always giving us support
Its only appear when have items HDR and 10bit. Nothing more.
In case the new skin code has been modified and the feature removed, I need to modify the file names of all my media library in order to have the flag style displayed on the media case?
Tks and regards
I've made a new menu for 4K using the MQ8/Customise Main Menu displaying a Video Node to a certain folder on my network. How do I get the artwork to show on the widgets/on the below page? The only way I can get the artwork to show is selecting "I" for information.
