(2021-04-08, 23:50)Wanilton Wrote: [ -> ]MQ8 is one skin only for use with Kodi Leia. The skin continues available via the Kodi Leia repository.
MQ9 will be matrix compatible.
Exist one mod available MQ8 to use with Kodi Leia by latts9923.
Yes but aeon mq8 has many problems with Kodi 18 leia because of the use of same repository for both. Mq8 and mq9.
You put in this repository scripts which work with python 2 and python 3!
You should create separate repositories as kodi does.
I know Latts have multiples repo, one for use with Kodi Leia another to Matrix.
MQ9 uses one repo only for use with Kodi Matrix 19 or Kodi 20 N*.
(2021-04-21, 21:51)Wanilton Wrote: [ -> ]I know Latts have multiples repo, one for use with Kodi Leia another to Matrix.
So I don't understand why this error python message?
And so many error update I had never before.
Can you be clear?
This repository is for what kind of aeon MQx version please?
8 or 9?
Python 2 or 3?
After reseting my skin, I have artist slide show error message again when listening music
And python errors come each time I want to use widget in TV shows.
Or this one?
Jacques56
MarcosQui repo was deprecated, is old and Marcos doesn´t use more.
Brasil repo, you need to get the new repo in our drive, and update, you are using one old repo too (deprecated).
The repo is only for Kodi Matrix, and all inside is python 3 compatible.
(2021-04-22, 18:31)Wanilton Wrote: [ -> ]@Jacques56
But what I need is only the up to date repo for Kodi 18 and mq8
You have a link?
(2021-04-23, 02:01)Wanilton Wrote: [ -> ]@Jacques56
Check the link to latts repo, here.
Thanks for the link but I already have this latts repo.
It doesn't solve my problems.
And I don't know if (and how) the xml file and resources directory must be used ?
Running aeon mq8 on Vero 4k, using Kodi 18.9
Is there a way to to disable the osd on pause in aeon mq 8?
I was sure this was a skin setting somewhere but for the life of me, I can't find it.
In Matrix this is apparently under
CHANGE PAUSE SCREEN" in SKIN SETTINGS > GENERAL SETTINGS.
But this does not appear to be the case for Leia.
(2021-07-02, 21:53)Temujin Wrote: [ -> ]Running aeon mq8 on Vero 4k, using Kodi 18.9
Temujin
With the video playing, press M, in OSD item, press enter, last item in the settings list, press enter 3x to Hidden Mode.
(2021-07-03, 03:50)Wanilton Wrote: [ -> ] (2021-07-02, 21:53)Temujin Wrote: [ -> ]Running aeon mq8 on Vero 4k, using Kodi 18.9
@Temujin
Thank you, exactly what I was looking for.
So whenever a video starts playing, the subtitle download selection comes on, whether there are local subtitles available or not. This is very annoying. Isn't there any way to disable this?
Do I really have to use .HDR. to get HDR tags to show up? I have HDR in the file name of everything, but I don't use dots/dashes. I know this is an even stupider second part to this question, but do other skins require the .HDR. too to get HDR to show up? I JUST started using HDR, so I don't have a lot of files to fix, but just want to confirm that I HAVE to do this. Or, does it work differently after I update to Matrix or something?
(2021-08-08, 12:43)offshade Wrote: [ -> ]So whenever a video starts playing, the subtitle download selection comes on, whether there are local subtitles available or not. This is very annoying. Isn't there any way to disable this?
offshade
Please your log, it´s don´t happens here.
(2021-08-09, 22:48)tential Wrote: [ -> ]Do I really have to use .HDR. to get HDR tags to show up? I have HDR in the file name of everything, but I don't use dots/dashes. I know this is an even stupider second part to this question, but do other skins require the .HDR. too to get HDR to show up? I JUST started using HDR, so I don't have a lot of files to fix, but just want to confirm that I HAVE to do this. Or, does it work differently after I update to Matrix or something?
tential
Yes, it´s necessary for now, the skin needs to use the filename to appear the respective flag.
The good news, available one pull request to solve it - Kodi 20 Nexus (work in progress).
Detect, store and process the type of HDR in a video file,
check here;
