Hi, first of all I recently switched to Aeon MQ8 (from Xonfluence) and I am thrilled. And now I have a question. I noticed that on main screen, in the TV Shows section, when I look at recently added episodes or any other widget that displays a list of episodes (posters) the posters used are the season ones. Not a bad idea until there is a show that does not have a season poster available (like most recent season 8 of Homeland) and I get an ugly gray box. Is there a way to default to main show poster instead of a season one? Or should it be that if the season poster is not found then the show's one is used?
Cheers
EDIT:
I worked it out, the Season Poster was not set correctly i.e. it was set empty. The trick is to set it to none, then the skin will default to Series Poster.
Hi, I have two questions
1. Where can i hide/show buttons in players - i'd like to hide volume + and - buttons. In MQ7 skin was possible to modify all buttons in the player
2. Where is option "update kodi version" in thi skin - i can't find it
Cheers
Hi, I have one more questions, I have to Nvidia Shields, both with Kodi 18.5 setup identically, both with Aeon MQ8 skins. I am using a TV Show - Next Aired add-on on both. It's configured to show as a widget.
The TV Guide on both Shields work OK. On one Shield I get correct number of next episodes showing in the widget, on the other one is missing (Strike Back). Any idea why? Is there a setting somewhere that may hide a show/episode from showing up in the widget?
Cheers
hi i am trying this skin on leai with windows 10, when i try and add my movie collection the art work does not come up correctly i have tried different scrappers and find i have to do it manually but this did not happen in aeon nox i am using artwork beef thanks for any advice
(2020-01-14, 01:59)Wanilton Wrote: [ -> ] (2020-01-09, 17:17)moejoe Wrote: [ -> ] (2019-03-02, 22:31)MarcosQui Wrote: [ -> ]
skin is awesome!
thx
is there any way to disable the "window popup funtion"?
when i watch TV or play a video, and i go to the main menu at the same time, the video plays in the upper left window. Thats cool. But after a few seconds that mini window pops up at the middle of the screen and hides the menu. so i have to close that unwanted pop-up at least 20 times a day, which is annoying.
beside of that the skin is just perfect. Help plz
Have one option to turn off, in skin settings, main menu, disable the option
Tanks buddy! Cant wait for kodi 19 and aeon mq 9
Marco,
I'm having problems getting the disc art to work in music. NFO and Album Cover are being read locally, but not the discart.png. They are in the album folder. Is there a setting I'm missing?
I was asking in the past to @
Wanilton to help with the correction of the tvshow cast on home screen when using playlists but still not got an answer.
Finally I could find a solution by my self. As the public version of this skin will most probably not be updated anymore here my fix:
In the "IncludeVariables.xml" file change the line from:
xml:
<value condition="String.StartsWith(Container(9000).ListItem.Property(widgets),tvshow)">plugin://script.skin.helper.service/?action=getcast&tvshow=$INFO[Container(510).ListItem.Title]&downloadthumbs=true</value>
to:
xml:
<value condition="String.StartsWith(Container(510).ListItem.DbType,tvshow)">plugin://script.skin.helper.service/?action=getcast&tvshow=$INFO[Container(510).ListItem.Title]&downloadthumbs=true</value>
If you missed the unwatched quantity on tvshow using playlists see my other fixes on post
#1252
Greets
Bite
Very noob question, i'm sorry, i'm new on kodi.
I create an extra menu voice called "animation" for my animation movies. I created a smart playlist etc etc and it works perfect. But what i cannot fix anymore (LOL) is the flexible widget. I mean, i set sort as latest added tvshow under animation menù, and under tv show menù i set animation movies.
But now, clicking arrow up i cannot see the flexible widget itself. Only the tvshow or animation preview. How can i fix it?
Sry for my english, i hope you understand my trouble ahaha. It's a stupid minor problem i know.
Dear Forum,
I switched from MQ7 to MQ8.
Under MQ7, I had the corresponding number of movies for each of my playlists displayed.
I inserted my playlist like this:
Settings -> Customise Main Menu - Presets -> Replace This Menu With -> Video Playlist
Unfortunately, I don't see the number of movies in my playlists the way I had with MQ7.
Can I still change something or do I have to try another way?
Thanks for your help and tips
Tanker
Dear Forum,
<a href="https://www.bilder-upload.eu/bild-16c546-1583664968.jpg.html" target="_blank"><img src="https://www.bilder-upload.eu/thumb/16c546-1583664968.jpg" border="1" alt="Bilder-Upload.eu - share DEINE Bilder" /></a>
Tanker
Dear Forum,
https://www.bilder-upload.eu/bild-16c546...8.jpg.html
Tanker
Dear Forum,
Tanker
Sorry Admin
but I couldn't edit my posting, so please delete the previous ones...
