vansai
Repo is now only for Kodi Matrix addons (python 3 only), necessary to new MQ9 skin.
(2020-05-14, 18:56)Wanilton Wrote: [ -> ]@vansai
Hi @
Wanilton
Is Kodi 19 Matrix safe now for daily use? Is it stable? I am currently on 18.6.
Hi Wanilton
I understand but why these updates are asked in AEON MQ8 with leia ?
No test are possible before asking ?
What can we do ?
Installing pyton 3 (but how ?)
Uninstall Brasil repository ? But what consequences ?
It´s no possible install python 3 in Leia. You need only remove our repo. Don´t have any consequences.
(2020-05-11, 09:11)Cinephile Wrote: [ -> ]Then you’re better off nuking your installation and start over.
Nuke what?
Nuke Kodi? All of my tests to date
have been on nuked and freshly installed versions of Kodi Leia.
Nuke the Operating System? lolno. I'm not going wipe an otherwise perfectly working OS and start over from scratch just for a kodi skin.
In that case, I'll just pick a different skin.
(2020-05-21, 00:14)nSpectre Wrote: [ -> ] (2020-05-11, 09:11)Cinephile Wrote: [ -> ]Then you’re better off nuking your installation and start over.
Nuke what?
Nuke Kodi? All of my tests to date have been on nuked and freshly installed versions of Kodi Leia.
Clearly others aren’t having the same issue so it’s not skin-related.
I love the rain weather effects on this skin. Is there any way to permanently activate a weather detail regardless of the forecast? Lol
Wanilton
I realised the other day that some artwork including clear logo and disc art are not being exported during a library backup. Is that because MQ8 uses a skin helper add-on for these specific files? Is there a way to make local copies of the cached images in this case?
why in the information of a movie only sell sdr or and 8 bits when the movie is hdr 10 bits?
Cinephile, I need to check, long time don´t use more MQ8, only MQ9.
diegocuarti, because it´s based in the filename, need info there, something like moviename.bluray.hdr.10bit.mkv
Thanks @
Wanilton
It would be appreciated if you let me know.
(2020-05-29, 14:04)Wanilton Wrote: [ -> ][font][font]@Cinephile, necesito verificar, mucho tiempo no use más MQ8, solo MQ9. [/font][/font]
[font][font]@ "diegocuarti", porque está basado en el nombre del archivo, necesita información allí, algo como moviename.bluray.hdr.10bit.mkv[/font][/font]
but can it be solved or not?
