Hi Wanilton,
I don't know how and why… Since yesterday the Music Player Show me only the cover from the Folder and no more the cover in the Tag from the file… All my Music Comes with the Album pic from ITunes. Stored are all files in a Folder like M:\3 Sampler\Top 100\Sia - Move your body.flac. Shown while playing is the Pic from M:\3 Sampler\Folder.jpg. I can delete this jpg but anwhy this pic is shown...
All the Pics from Sia are stored in M:\6 Informations\SIA\Move your Body\Folder.jpg
I don't Change anything in the meanwhile…
Hope you can help me...
Uwe
If I try to modify these zip files (unzip-modify icon-zip compress): "https://drive.google.com/drive/folders/1qdnk3SseAvSpT6PVXit7AFwl7q8RYDbi?usp=sharing" if I try to install them, it says the installation has failed.
You need install add-on by add-on, no single zip file. Extract zip file, or get add-on one by one.
Kodi 18.2 on Nvidia Shield, Skin Mq8 2.90
If you pause the movie or press OSD in the Player button and then click on Media Information, no text of the plot and the actor appears. But sometimes it does not work. Is there any attitude?
The down picture yellow frame need install ? (use Kodi 18.2 & MQ 8 - 2.9.0)
Thank you!
(2019-05-30, 22:41)Wanilton Wrote: [ -> ]È necessario installare il componente aggiuntivo per add-on, nessun singolo file zip. Estrai il file zip o ottieni un componente aggiuntivo uno per uno.
io dont' understand......help please
Hi @
Wanilton
If a film is already tagged as HDR then I should not have to add that it is "10 bit". HDR = 10bit. That should be automatically set or the 8 bit/10 bit tag should default to blank. It should not default to "8 bit".
vicius80
Inside our drive, have a few add-ons, you need download each addon and install via zip file option in Kodi. Its no possible install multiples add-ons in one single zip file.
Any idea why skin is failing to install?
Windows 10 Laptop, new Kodi 18.2 nightly install, also happened on Kodi 18.2
Log is here:- https//paste.kodi.tv/cubitinoku
(2019-05-31, 14:22)E net Wrote: [ -> ]Hi @Wanilton
Well, technically HDR is not always 10 bit. Dolby Vision is 12 bit HDR. Nonetheless HDR is never 8bit. 8 bit is SDR.
So yes: a default mapping of SDR=8bit and HDR=10bit would be correct in almost every case. And 10bit SDR is not very common... and if you have such a source, you could always tag it as such.
And if we take into consideration, that Kodi currently cannot playback DV-content, HDR=10bit would always be corret in a Kodi environment.
I support your request, as I would not have to double tag all my HDR-movies with HDR and 10bit tags, if the HDR-tagging would be enough to also show the 10bit icon.
(2019-05-31, 14:43)Jeffers24 Wrote: [ -> ]Any idea why skin is failing to install?
Skin doesn't have any dependency, only need to have Kodi 18.2 or 18.3 (nightly).
