I don't think there is an option for this in the gui: slow down the scrolling speed for descriptions in various menus. Probably editing a xml or json file... How can I achieve this?
Everything is perfect but two things are unexpected:
1.Widget cannot set in customerized page setting. It is very confused to set Widget in smart tool.
2.No function can turn off smart tool, it is kind of noise for fresh user(most of my friends)
In my ignorance I did a test and it seems to work AeonMQ 8 2.9.0 with Kodi Matrix.
By editing the
"addon.xml" script, specifically line # 4:
<import addon = "xbmc.gui" version = "5.15.0" />
[align=initial !important] [/align]
So guys .... will this work on Kodi (19) Matrix ??
For the moment it works, I haven't explored all the features.
The skin installs but is missing all changes in the skin engine...it´s don´t turn the skin-compatible, only allows install.
Here the list the skin changes in Kodi Matrix:
https://forum.kodi.tv/showthread.php?tid=343076
MQ9 will come and is native for Kodi matrix 19.0
Thank you for the confirmation.
(2021-02-22, 23:11)Wanilton Wrote: [ -> ]The skin installs but is missing all changes in the skin engine...it´s don´t turn the skin-compatible, only allows install.
So Wanilton ... does MQ8 support, or does MQ8 NOT support, Kodi Matrix ??
StoneT
Only using MQ8 mod by latts9923, or wait to use MQ9.
Wanilton
Thanks for the clear response - much appreciated
So for MQ9 - when will that be available ?
Wanilton - As a follow-up, would you say we are still in Alpha stage ( with Matrix just being released and all), Beta, or RC?
And @
latts9923, just curious if you've taken a peak under the hood? (option for left/center menu; continue with main page weather, etc [hell, it might not need much more than a few views] - and please, with all the views, I beg you continue to include Poster Lite view (simple, logo, classic - like a sleak, old school muscle car!)
RonnieG3
There is no ETA. Work in progress.
The current version works ok but needs more work and yes continue in alpha.
(2021-02-26, 03:05)Wanilton Wrote: [ -> ]@RonnieG3
AWESOME!! Thanks for the quick update Wanilton. As much as we all want to play in Marcos' garden, I think we all can appreciate this build has quite a few core/central changes. Again - really appreciate the update, brother!
MarcosQui, Hi your build look so great and silk, I have been a user of Titan skin since inception however, lately the skin MOD is not actively supported by the developer so I am considering changing to another skin that support smart short cut for instance emby media or plex addons which Titan provides for. My server system is hosted by embymedia
https://emby.media/ which allows users to create several notes that interface with Kodi through bespoke embyforkodi addon
https://emby.media/community/index.php?/...-for-kodi/. The addon is integrated into Titan skin.
Sideload: You can add
http://kodi.emby.media
Appreciate if you will consider integrating the EmbyforKodi addon into your skin, I believe it will take the skin into another space of reality for users.
