you should already see the update in our repo...
Just as a note. Then arduino code also contains some rgb flash which you need to remove
well the arduino code i use doesn't do that fyi...
(2013-01-19, 10:13)Memphiz Wrote: [ -> ]well the arduino code i use doesn't do that fyi...
Did you modded your LEDStream.pde already then?
When i started my Arduino project i need to remove
this piece of code from LEDStream.pde
Only thing i'm still looking for is to dimm the leds when movie is in PAUSE.
Hey,
i hope someone can help me here.
I have an ATV1 with OpenELEC installed. The problem with that distro is that the file system is read-only.
So i had to make my own build to add manually the required libs to /usr/lib/
Now i have these files in /usr/lib/:
-rw-r--r-- 1 root root 2074404 Jan 19 04:59 libboblight.a
-rw-r--r-- 1 root root 985 Jan 19 04:59 libboblight.la
-rw-r--r-- 1 root root 1101839 Jan 19 04:59 libboblight.so
-rw-r--r-- 1 root root 1101839 Jan 19 04:59 libboblight.so.0
-rw-r--r-- 1 root root 1101839 Jan 19 04:59 libboblight.so.0.0.0
But when i start my ATV, it still says that the addon requires some libs. Are there more to add?
Or maybe there are missing some other needed libs in OpenELEC?! Can someone tell me all libs the addon needs and where they have to be?
You need to run ldconfig afterwads i guess ... but on openelec it should already be working imo - maybe the oe forum has some more help on that.
The pde i use on my selfbuilt arduino clone is that one (without RGB flash):
http://pastebin.com/cK4CuBqA
Not sure if i modified it - can't remember...
You can just install the boblightd add-on from the openelec repo from within openelec and all is working. The boblight.conf is also writable so no problems there either.
So, unless you want to build the stuff yourself, just add the add-on and you're good to go.
(2013-01-19, 13:58)flash4ever Wrote: [ -> ]Hey,
It's running very nice now for me. What would be cool is:
Moodlight including presets
Fade lights when pausing video
Do you have any features planned ?
Thanks for the work you all put in
Hello, i have a boblight windows7 working just fine exept a new bug in frodo rc3,boblight starting and working just fine but when i push stop i get "script failed
cript,xbmc,boblight''.Then i have to restart xbmc to get it working again.Any thoughts?
log after error massage,
http://pastebin.com/gZnFYNTN
thnx.
Hi to all XBMC members.
I am running Openelec 2.0+Xbmc v11 Eden on my Acer Aspire Revo 3700.
All working superb - even controlling XBMC via Logitech Harmony 650.
But I have one problem - I would like to use amBX with XBMC.
I followed the instructions posted here:
http://wiki.openelec.tv/index.php?title=...:boblightd
But the problem is I do not know what /dev/tty amBX is getting from openelec. The default output doesnt work.
Can you please help me get this going ?
I got my ambilight setup over the weekend and wrote a little python script to generate the boblight config file.
It starts at bottom middle of screen and can be configured to go clockwise/anti clockwise. It can calculate adalight prefix and also determine if there is a gap in center bottom for a stand.
Just change settings at the top and the script will do the rest.
Maybe someone will find it useful so here it is.
https://gist.github.com/4671346
Is There any solution to the lights still on after stopping playback?[/align]
(2013-01-31, 10:10)skydancer Wrote: [ -> ]Is There any solution to the lights still on after stopping playback?[/align]
I have that issue too with frodo ,I think now that the full release is out we will get a fix.
I still have the error script issue but it appears more rare now.
