2013-02-16, 00:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
2013-02-16, 00:46
wooohoooo compiling now, thanks a lot.
EDIT: nope, still not working for me.
Here the cygwin compiled version of 465 from today.
http://www.mediafire.com/?jgjfwvbeo9i6azj
2013-02-16, 11:31
Hi!
I got the same Problem, when i started my HTPC, boblight started and is connected to XBMC, but it doesn´t work! When i´m going back to win7, i must close the start.bat and open Arduino+Strg+Shift+M=RGB Check,after that i open the start.bat and xbmc, then it works!
I have changed the Port manually from Port 3 to Port 1 but no effect!
What can i do?
Is there any other possibility?
What can i do?
2013-02-16, 15:32
(2013-02-16, 11:31)mannyrivera Wrote: [ -> ]Hi!
What can i do?
Ok, it's working, thx. Is there any other simpler way to make it work and is there any way to enable options like saturation and others?
2013-02-16, 15:39
(2013-02-16, 15:32)umbur Wrote: [ -> ](2013-02-16, 11:31)mannyrivera Wrote: [ -> ]Hi!
What can i do?
It´s working? when you start your HTPC with Autostart XBMC and start.bat or you must open arduino etc.?
2013-02-16, 16:02
(2013-02-16, 15:39)mannyrivera Wrote: [ -> ](2013-02-16, 15:32)umbur Wrote: [ -> ](2013-02-16, 11:31)mannyrivera Wrote: [ -> ]Hi!
What can i do?
No. I turned on Arduino and pressed ctrl+shift+m, then closed Arduino and turned on start.bat from Boblight. Then it's working.
How can I turn off LEDs when I close application? After I close it still shines.
2013-02-16, 17:05
When i closed arduino the LEDs are off the Same with the Start.bat only RGB test!
My Problem is the Start i got xbmc and Auto.bat as autostart but boblight doesn't work! Only Manuel
2013-02-19, 17:35
hello to everyone,
i know that i am probably asking something that has been asked many times before, but i just can find a simple - easy answer.
can you please tell me what is the easiest - value for money, way to add 'ambilight' to my xbmc? (a list of things i am going to need?)
i have read the previous pages and the latest one i found was this
http://forum.xbmc.org/showthread.php?tid...pid1274108.
but as the guys mention, it is not the best solution (for some reason).
i would like to have a led stripe and not that led balls (they seem pretty ugly)
sorry for asking (probably) an often question again.
2013-02-19, 18:01
I think the cheapest and best way is to go with adalight, you got 25 to 150 individual controlled leds. So the ambilight is very crisp.
http://learn.adafruit.com/adalight-diy-a...v-lighting
Most of the other solutions only got 4 to 8 channels so you got 8 different color zone. I think thats a bumper.
I ordered these parts from different shops (everything from adafruit except the led strand) and you can use the adalight tutorial:
Arudino Uno
2,1/5,5 mm DC Jack Socket Connector
WS2801 Led Strand
Some Wires
5V 2A PSU
I used this led strand (it costs the half from the adafruit one and you got 50 instead of 25 leds)
http://www.aliexpress.com/item/12mm-WS28...02558.html
cheers
regnets
Arudino Uno
WS2801 Led Strand
Some Wires
5V 2A PSU
cheers
regnets
2013-02-19, 20:47
these led strands are the most ugly thing i have seen. i don't want a Christmas tree behind my tv. this is why i want led stripes.. any suggestions for that?
how about this?
https://www.adafruit.com/products/1138
thanks for the help
how about this?
thanks for the help
2013-02-19, 21:07
You know you are supposed to put the LEDs behind the TV right?
Just get strips with WS2801 chips.
And dont expect them too look as good as the LED pixels.
2013-02-20, 07:15
(2013-02-19, 20:47)TeDeV Wrote: [ -> ]these led strands are the most ugly thing i have seen. i don't want a Christmas tree behind my tv. this is why i want led stripes.. any suggestions for that?I used these. http://adafruit.com/products/306
how about this?
thanks for the help
2013-02-20, 09:15
how about this?
thanks for the help
As Teko said, they are behind the tv, i am not able to see mine...
For an 40" TV you need about 3 Meters, so the led strip from adafruit costs you 120 US Dollar.
If ist must be an led strip, than you can use those:
http://www.aliexpress.com/item/free-ship...08150.html
They also use the ws2801 strip and so they are fully compatible with the adalight tutorial.
cheers
regnets
2013-02-20, 09:19
Is there anyway to tell what revision of boblightd I am using? Ive tried looking in the openelec boblightd addon directory, launching boblightd from the command line and watching the output and and adding a --help switch to the boblightd command (which I think has the same effect as just issuing the boblight command with no switchws) but I havent seens any mention of revision numbers.
Thanks in advance.
Thanks in advance.
2013-02-20, 09:31
ok guys, since the price difference is at least the double price, will i be able to cover my 40'' TV with the one regnets suggested?
(http://www.aliexpress.com/item/12mm-WS28...02558.html)
i will try to find a way to make them look acceptable. (yes yes i know it is going to be behind the TV, but still
and how many pixels should be placed on each side? ( i guess as much as i can fit)
thanks again for your help
