2014-05-12, 10:05
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
2014-05-14, 21:00
Hi guys,
I just finished setting up Boblight with my Lightpack (from lightpack.tv) on XBMCbuntu (Gotham release build). As a complete linux noob it took me quite a while. I got instructions from multiple sources, so I decided to write my own little tutorial and merge them all together so all the info is in one place. Hopefully this'll help some people down the road
http://runcoderepeat.com/setting-up-ligh...xbmcbuntu/
2014-05-14, 21:54
Wouldn't the xbmc wiki be the logical place for that tutorial?
2014-05-15, 00:08
(2014-05-14, 21:00)fearsomesteve Wrote: [ -> ]Hi guys,
It's called lightpack not lightbox. Reading through it now
2014-05-31, 12:23
2014-06-04, 23:52
Hello,
I have a problem with boblight when I run it on the tv screen appears delicate lag. Image laggy best you can see it at a football match. what could be wrong in the configuration file?
this is my config file:
openelec
arduino uno
video
openelec
[global]
interface 127.0.0.1
port 19333
[device]
name AmbiLight
type momo
output /dev/ttyACM0
channels 696
prefix 41 64 61 00 E7 B2
interval 40000
rate 460800
debug off
delayafteropen 1000000
threadpriority 99
[color]
name red
rgb FF0000
gamma 1.1
adjust 0.40
blacklevel 0.0
[color]
name green
rgb 00FF00
gamma 1.1
adjust 0.40
blacklevel 0.0
[color]
name blue
rgb 0000FF
gamma 1.2
adjust 0.40
blacklevel 0.0
# Bottom Start
[light]
name start1
color red AmbiLight 1
color green AmbiLight 2
color blue AmbiLight 3
hscan 48 49.3
vscan 97 98
arduino uno
#include <FastSPI_LED2.h>
#define NUM_LEDS 232
#define DATA_PIN 6
// If its's too bright with all the LEDS you can skip every nth led
#define EVERY_NTH 1
CRGB leds[NUM_LEDS];
// specified under `rate` in the `[device]` section of /etc/boblight.conf
#define serialRate 460800
// boblightd sends a prefix (defined in /etc/boblight.conf) before sending the pixel data
uint8_t prefix[] = {0x41, 0x64, 0x61, 0x00, 0xE7, 0xB2,};
void setup()
// sanity check delay - allows reprogramming if accidently blowing power w/leds
delay(2000);
LEDS.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
Serial.begin(serialRate);
// Start with all LEDs off
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB));
// set all the LEDs to white
for(int i = 0; i < NUM_LEDS; i++) {leds[i].r = 255; leds[i].g = 255; leds[i].b = 255;}
LEDS.show();
delay(1000);
// set all the LEDs to red
for(int i = 0; i < NUM_LEDS; i++) {leds[i].r = 255; leds[i].g = 0; leds[i].b = 0;}
LEDS.show();
delay(1000);
// set all the LEDs to green
for(int i = 0; i < NUM_LEDS; i++) {leds[i].r = 0; leds[i].g = 255; leds[i].b = 0;}
LEDS.show();
delay(200);
// set all the LEDs to blue
for(int i = 0; i < NUM_LEDS; i++) {leds[i].r = 0; leds[i].g = 0; leds[i].b = 255;}
LEDS.show();
delay(1000);
// Set all LEDs off
for(int i = 0; i < NUM_LEDS; i++) {leds[i].r = 0; leds[i].g = 0; leds[i].b = 0;}
LEDS.show();
void loop() {
// wait until we see the prefix
for(int i = 0; i < sizeof prefix; ++i) {
waitLoop: while (!Serial.available()) ;;
// look for the next byte in the sequence if we see the one we want
if(prefix[i] == Serial.read()) continue;
// otherwise, start over
i = 0;
goto waitLoop;
// read the transmitted data
for (int iLed = 0; iLed < NUM_LEDS; iLed++) {
byte r, g, b;
while(!Serial.available());
r = Serial.read();
g = Serial.read();
b = Serial.read();
if(!(iLed % EVERY_NTH)) {
leds[iLed].r = r;
leds[iLed].g = g;
leds[iLed].b = b;
LEDS.show();
video
2014-06-24, 18:22
Hello,
i wan't to ask for help. I have a mac mini with xbmc and i want to install the boblight for my karatelight. It's no problem to install the addon but there is always a error because its missing some files. I read this post but i don't know where i have to put this config file.
please help me.
regards peter
Mac mini
OS X Maverick
XBMC 13.1
Aeon MQ 5
Dreambox 8000 PVR
please help me.
regards peter
Mac mini
OS X Maverick
XBMC 13.1
Aeon MQ 5
Dreambox 8000 PVR
2014-06-26, 05:58
Have search/Google'd but can't find any good resources:
Has anyone setup the boblightd client on a separate/dedicated machine?
My boblight setup: WS2801 LEDs + Teensy Arduino and Zotac HTPC.
My scenario: my AV receiver & HTPC are in a separate room from the TV. I only have spare network connections in both rooms and would like to run XBMC on the HTPC [required for lossless audio] and the boblight client on a separate (network-connected) machine by the TV.
I'm looking at either running RaspBMC and just using it for the client or trying a lightweight install of Arch Linux and figuring out the boblight client install on the Raspberry Pi.
Any other options/methods?
2014-06-27, 10:57
I too have a lightpack..but i am using MX2 box (http://matricom.net/products/g-box-midnight-mx2/). It comes with Android+XBMC. But the community have developed its own XBMC version (openelec). It will be great if you can guide me on making lightpack work with this box. I used the prismatik apk+android but there is a problem as prismatik will do ambi light only if the video is played using SW decoding, which is not possible with HD movies as its resource hungry.
2014-06-27, 15:26
(2014-06-26, 05:58)BluechipJ Wrote: [ -> ]Have search/Google'd but can't find any good resources:
Hi Bluechip,
I put it on Raspbian and it works very good:
http://forum.xbmc.org/showthread.php?tid=188201
2014-07-10, 20:50
guys is there a way to map a key from my windows pc remote,to enable/disable Boblight?or even to bring addon setings like b\B key from keyboard does.
2014-07-10, 22:03
Map a key to 'b'
2014-07-10, 22:10
since it is not possible to have lights during audio playback
would it be possible to create that when xbmc plays music, the boblight addon randomly changes colors to the beat of the music. or to some preset colors
the bobdroid android app can do this
2014-07-11, 02:29
(2014-07-10, 20:50)wolfgr Wrote: [ -> ]guys is there a way to map a key from my windows pc remote,to enable/disable Boblight?or even to bring addon setings like b\B key from keyboard does.
You can start stop it with a remote or keyboard using a jsonrpc command, see
http://forum.xbmc.org/showthread.php?tid...pid1624387
See here for creating a toggle script to switch between on and off (its for audio but same principal)
http://forum.xbmc.org/showthread.php?tid...pid1750578
(2014-07-10, 22:10)spambus Wrote: [ -> ]since it is not possible to have lights during audio playback
What OS are you using? You can have bovlight during music playback with Linux via boblight-X11
2014-07-11, 14:49
(2014-07-11, 02:29)teeedubb Wrote: [ -> ](2014-07-10, 20:50)wolfgr Wrote: [ -> ]guys is there a way to map a key from my windows pc remote,to enable/disable Boblight?or even to bring addon setings like b\B key from keyboard does.
thanx teeebub got it workin,thnx.A little offtopic question,what command like"RunScript" can i use to play a file from library,using a mapped remote button?Is there a list of commands somewhere?
