2021-01-16, 21:38
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136
2021-01-19, 21:23
(2020-12-31, 08:03)NoxUser Wrote: [ -> ]One way of testing is to click "unwatched" on an episode, then click "watched" and click the Trakt addon to manually send the update. It'll never add the new play. Does this have something to do with how Trakt requires a premium account to reset progress on a TV show for new watchthroughs? I don't want to reset progress (I know it keeps previous play counts) I just want to add new plays. So I doubt this is the reason but may as well mention it. As it is right now, I have to manually add new plays.
So you unwatch -> then watch and send it to trakt. It was 1 watch before you did anything and is now 1 watch again. So there is no change. Unfortunatly the kodi database only tracks amount of plays (1,2,3,4,...) and date of last watch.
(2021-01-16, 07:54)melons2 Wrote: [ -> ]Is this going to be updated for Matrix?
It has been in matrix for months, not sure why your asking.
2021-01-20, 13:15
Hi
after upgrading to Kodi 19 (RC1), I've noticed an issue with Trakt addon version 3.3.2.
By starting the addon, it tries to load my Kodi movie-selection for synchronization and freezes in that task.
This issue is present on severeal systems, after switching from Kodi Leia to Kodi 19 RC1 (Win 10 PC, Libreelec PC, FireTV 4k).
Any chance to get this fixed?
2021-01-20, 17:38
(2021-01-20, 13:15)guenzelsen Wrote: [ -> ]Hi
Thank f*** someone is having this issue too. Just updated to the latest libreelec nightly with kodi 19rc and the issue you describe is also occurring for me. Hangs at the movies from kodi sync (thought it was something wrong my end, too many bleedin addons disabled on update and had to be manually updated. Trakt still hung, so I wiped the system, a fresh install and the trakt addon hangs
2021-01-20, 21:29
Post your logs, might get it fixed
2021-01-20, 22:42
Here we go:
kodi.log
kodi.log
2021-01-21, 00:18
(2021-01-20, 21:29)docwra Wrote: [ -> ]Post your logs, might get it fixed
Hopefully this might be of help
https://paste.kodi.tv/udohukugov.kodi
Need to fix bleedin youtube it looks like too.
2021-01-21, 15:28
(2021-01-21, 00:18)lusephur Wrote: [ -> ](2021-01-20, 21:29)docwra Wrote: [ -> ]Post your logs, might get it fixed
Right, looks like it was a fault caused by me.
I started from scratch, including adding hdd sources
rescraped using the new scrapers and it looks like trakt info is updating and saying whats watched and whats not, will see how if this changes the issue I had earlier after i've updated everything.
Edit: Ignore all that. the addon itself, while it still scrobbles as you watch, will hang on the "loading movies from kodi" bit during Synchronize Movies.
2021-01-22, 23:18
(2021-01-21, 15:28)lusephur Wrote: [ -> ](2021-01-21, 00:18)lusephur Wrote: [ -> ](2021-01-20, 21:29)docwra Wrote: [ -> ]Post your logs, might get it fixed
I wonder if the movie issue has to do with the information scraper? (currently on matrix and using The Movie Database Python scaper.) I really do not want to have to rescrape all my movies again. I thought having a nfo file (created by kodi when exporting library to separate files) in each folder would safe me having to correct any issues further down the line. (I don't know if you can force a scrape to bulk ignore local nfo files, if you can, please point me to it.)
I removed my movie source, and had kodi rescan for new content (tv programmes.) when finished a few minutes later the trakt addon did it's thing and synced my progress on what local files have been watched as per trakt.
2021-01-23, 10:58
(2021-01-22, 23:18)lusephur Wrote: [ -> ](2021-01-21, 15:28)lusephur Wrote: [ -> ](2021-01-21, 00:18)lusephur Wrote: [ -> ]Hopefully this might be of help
Me again.
My new favourite bit of code is
find . -type f -name "*.nfo" -delete
removed all the old .nfo files
removed movie source, readded movie source and selected MovieDB Python scraper.
Let it run for a bit, stopped it.
And successfully ran the trakt addon, no more getting stuck on the synchronize movies bit at the start.
2021-01-23, 20:08
Well, seems that this non-working behavior is declared as normal from trakt-addon devs.
https://github.com/trakt/script.trakt/issues/527
Ok for me. I will simply use another method of syncing my media
2021-01-24, 12:48
(2021-01-23, 20:08)guenzelsen Wrote: [ -> ]Well, seems that this non-working behavior is declared as normal from trakt-addon devs.
That would refer to the unique code error in your database. Remove all pre-matrix nfo's a scan again. (Yes, it's a pain, but you'll be able to correct some overlooked errors in your media collection that you may not realise you have.)
2021-01-25, 11:36
So I shall delete 6000-7000 nfo's, which are optimized with additional information, descriptions etc..?
This will for sure not happen!
99.5% of my nfo's have a unique ID.
This is NOT new requirement with Kodi 19. This was introduced with Kodi 17 already.
What about the couple of files, which do not have a unique ID, because they are not listed in IMDB, TMDB...?
Matrix can handle this easily without any issue.
Trakt do not have a fallback-solution for these cases (anymore)?
But as mentioned....if this is declared as wanted behaviour by the dev's I will just simply walk away from this addon. That's ok. It is for free, so I cannot and will not complain.
2021-01-25, 17:06
(2021-01-25, 11:36)guenzelsen Wrote: [ -> ]So I shall delete 6000-7000 nfo's, which are optimized with additional information, descriptions etc..?
Short answer, yes delete them. and rescan. I can assure you you will have errors in your existing filenames (6000-7000 files all being perfectly names for a scanner is, while not exactly impossible, is highly improbable.)
You can catch which shows or movies are not matching be looking at your log in tmp. (use search query "won't be added to library")
2021-01-25, 18:48
I can assure you, every single nfo in my collection is in perfect condition.
There is not a single file, which is not added to my library.
Everything is managed in Ember Media Manager since many years.
