Apologies if this has been asked before, a search came up empty.
I'm having a slight problem with Kodi profiles. I live with three other people for whom I have created their own profiles in Kodi. Mine is the master profile. If my roommates watch a show, it also scrobbles to my own Trakt profile. The strange thing is that in their Kodi profile nobody has ever activated Trakt through the PIN. It appears as if the settings of the Trakt addon are not being properly separated in the user profile settings. Please see
the (large) log file. I'm not sure where the incorrect scrobbles occur, but I'm sure they're in there somewhere.
(2015-09-27, 09:49)burekas Wrote: [ -> ]Hi,
Where is the "Trakt" category which was in addition the context menu for Movies/TV Shows library items?
(For rating, Set Watched etc..)
I'm using the last version: Trakt 3.0.5~Beta1
EDIT: I realized that you separated it to a different add-on. Why? It wasn't like this before.
These are new with Kodi 15 and a neat way to customize your context menu and not every addon spamming it with things you don't want there.
(2015-09-29, 00:17)burekas Wrote: [ -> ]Hi,
Is there any known problem with the synchronization since yesterday?
I'm launching the add-on but the synchronization stuck or quit suddenly, also the rate dialog isn't shown up after watching or manually rating.
Was on a trip the last days, so I'm not sure, but I read trakt had problems due to facebook being down and the facebook api slowing down everything. Might be fixed by now?
(2015-09-29, 15:02)danik56 Wrote: [ -> ]I have configured the add-on and entered the PIN that was provided via the web page, but after the authentication completion message was issued, the account userid is still not present , This problem only seems to happen with devices running version 14.2 with OPENELEC.
You might want to read the first post at least.
(2015-09-29, 16:03)Anthirian Wrote: [ -> ]Apologies if this has been asked before, a search came up empty.
I'm having a slight problem with Kodi profiles. I live with three other people for whom I have created their own profiles in Kodi. Mine is the master profile. If my roommates watch a show, it also scrobbles to my own Trakt profile. The strange thing is that in their Kodi profile nobody has ever activated Trakt through the PIN. It appears as if the settings of the Trakt addon are not being properly separated in the user profile settings. Please see the (large) log file. I'm not sure where the incorrect scrobbles occur, but I'm sure they're in there somewhere.
Likely connected with this:
http://forum.kodi.tv/showthread.php?tid=239543
Razze
It looks like it's back to works good.
Any chance of implementing the synchronization of the trakt lists to Kodi tags?
I loved that feature in the old plugin. Extremely usefull. The tag system in Kodi is extremely un-user-friendly to use. So I was just adding what I want tagged in Kodi to trakt lists, and voila - after trakt sync, I can filter in Kodi by tags. With a huge library it was indispensable.
Where I can get trakt beta version?!
I've fixed the date on TVDB and triggered a refresh on Trakt.
I updated a few of my tv shows for a better quality.
Then I wanted to force a trakt update to notice it keeps stuck on 1%.
After some searching I found the issue could be because of the date added or watched is between a certain year like year 2000.
I checked my mysql db and found a few entry's in date added with the year 2000.
Anyone know a fast way to edit the date added to something else with a mysql command ?
update movie
set dateAdded = 2000
where dateAdded = 200
This is untested. But that should essentially work. It will change every dateAdded value from 200 to 2000
Also check the first post for info on that problem
Hmm,
I must have read it wrong then,
I only got some entry's with year 2000 and not 200.
Will try to delete all trakt info including settings and reinstall to see if that fixed it.
If not I will create a ticket on github with a provided debug.
My movie watch list does not sync with kodi. Movies tagged as watched in trakt.tv are not marked as watched in kodi. I have enabled mark movies from trakt history as watched in kodi.
I also noticed when i tried to manually sync trakt, trakt stuck at 73%.
I have enable debuggin in kodi and trakt.
here are my log files.
http://pastebin.com/KyE3qByS
what can i do to ensure my marked movies in trakt as watched in kodi?
