(2015-07-18, 18:02)burekas Wrote: [ -> ] (2015-07-17, 20:43)Razze Wrote: [ -> ] (2015-07-17, 17:25)burekas Wrote: [ -> ]Kodi Debug (Enable) , Trakt Debug (Enable)
- It configured on 75% of video watchin to enable rating.
- The option of rating Movies is 'On' (also scrobbles)
- Also "Added watched movies to Trakt" is 'On'.
- I jumped in times for reaching the end of the video just for the debug (Didn't watch actually all the video)
Log file: Movies (Bug: No rating automatically after watching and no update to Trakt site)
http://xbmclogs.com/pfe4h9zx9
Log file: TV-Shows (Working good - There is no bug)
http://xbmclogs.com/pa40ugeyk
Just to mention there is different scrappers between TV-Shows library to the Movies library.
Hoping it will help now.
Can you try the latest version from here?
https://github.com/Razzeee/script.trakt/tree/dev
That should fix it, please let me know.
Still the same
I uninstalled trakt and removed all the folders manually.
Then Installed the Beta version. But there is no difference.
See Log files with the Beta version 3.0.4 of Trakt:
http://xbmclogs.com/pqoyubbld
* I also tried this with other scrapper. The same bug.
http://xbmclogs.com/p5hh7ntwk
What could be the reason?
Well thats a follow up error I should have seen coming, shame on me
Can you try the latest version of the dev branch again?
(2015-07-19, 01:59)Razze Wrote: [ -> ] (2015-07-18, 18:02)burekas Wrote: [ -> ] (2015-07-17, 20:43)Razze Wrote: [ -> ]Can you try the latest version from here?
Still the same
Sorry, but it's still the same
See the new log files with the Beta version 3.0.4 of Trakt:
http://xbmclogs.com/pivizkag9
http://xbmclogs.com/pi4ka8umc
* By the way, there is another bug, with the authorization.
After each new fresh install of Trakt addon, I need to make a new authorization.
I'm doing all the process with the code from pin/999 etc.
I get "Authorization Complete", but after I'm going back to the settings it doesn't show my user.
Sometimes it take twice or several times until it actually works (between each time I'm generating a new code.
But first we need to solve the first problem.
(2015-07-19, 18:44)Razze Wrote: [ -> ] (2015-07-19, 17:34)burekas Wrote: [ -> ] (2015-07-19, 01:59)Razze Wrote: [ -> ]Well thats a follow up error I should have seen coming, shame on me
Have another try!
Download and install again but still the same.
http://xbmclogs.com/pxcrn6x34
http://xbmclogs.com/pp66f8kd8
What is the problem there?
* Log for the authorization issue, I have to put a code again and again even if it told me it's OK (Just after restart kodi I succeeded)
http://xbmclogs.com/pckku0cza
(2015-07-19, 21:52)burekas Wrote: [ -> ] (2015-07-19, 18:44)Razze Wrote: [ -> ] (2015-07-19, 17:34)burekas Wrote: [ -> ]Sorry, but it's still the same
Have another try!
Well havent slept much and I'm trying to save code
So please try again for the first case
(2015-07-20, 00:12)burekas Wrote: [ -> ] (2015-07-19, 22:24)Razze Wrote: [ -> ] (2015-07-19, 21:52)burekas Wrote: [ -> ]Download and install again but still the same.
Still the same :\
http://xbmclogs.com/p1btk8x44
Thats a follow up error that should be fixed now.
The problem is that I don't want to install the addon your using to get this error, so I can't test it.
(2015-07-20, 01:14)Razze Wrote: [ -> ] (2015-07-20, 00:12)burekas Wrote: [ -> ] (2015-07-19, 22:24)Razze Wrote: [ -> ]Well havent slept much and I'm trying to save code
Still the same :\
OK
Just tell me when to download it and I will test it again.
And what is the meaning of "follow up error", do you know the reason of the bug?
(2015-07-20, 08:11)burekas Wrote: [ -> ] (2015-07-20, 01:14)Razze Wrote: [ -> ] (2015-07-20, 00:12)burekas Wrote: [ -> ]Still the same :\
OK
You can download it again.
Follow up mean, I fixed the previous bug, but there was another one that came up that previously didn't happen. As the code didn't got so far before.
(2015-07-20, 20:10)burekas Wrote: [ -> ]Still the same with Movies
http://xbmclogs.com/pghyoa6vg
(TV shows working good)
Can you please create a ticket on github on that topic, as stated in the first post? Thanks
Is the add-on Isengard compatible cause im not able to sync anything i just get check logs error?
Yes it is compatible,
Did you check if you got the latest version ?
And also entered your pin ?
Hello,
Could you consider reverting the new login screen instructions? That is just awful:
- it does not fit at all with the Kodi theme. I mean, Kodi colors are mostly black and blue, your screen is like white and red, the buttons are completely different...
- if the media library is being scanned, your pop up make the progress bar disappear. Afterwards, it is just impossible to exit Kodi.
- the field where you are supposed to write your PIN is not visible when the text is translated to French.
- that does not seem to work properly: I already have a PIN used on other installations, and using it does not work (it says wrong PIN). And yes, I triple-checked what I was writing. I tried to use a copy of a very recent backup of ~/.kodi/userdata/addon_data/script.trakt, and it works.
Thanks a lot.
(2015-07-22, 19:22)TRaSH Wrote: [ -> ]Yes it is compatible,
Tried everything even installing Beta from Dev branch.. Kodi just keeps given me check logs, when i try entering my pin it also gives me an error.. but i have found out that i cant install dateutil through kodi repo its gone?? Help is much appreciated
