Not playing in 3D if you name the filename with .3D.SBS for SBS for example?
(2015-10-11, 01:36)hdmkv Wrote: [ -> ]Not playing in 3D if you name the filename with .3D.SBS for SBS for example?
This is how my 3D movies play on RPi2 build #1009. These are full SBS (3840x1080) or full TAB (1920x2160). I have checked it on two Sony 1080p TVs, Samsung 4K TV and Epson 5020UBe. I have checked at least 4 different builds after 0916. I haven't had much luck with 3D ISOs also.
http://i.imgur.com/svWwPsF.jpg
(2015-10-11, 02:36)wesk05 Wrote: [ -> ]This is how my 3D movies play on RPi2 build #1009. These are full SBS (3840x1080) or full TAB (1920x2160). I have checked it on two Sony 1080p TVs, Samsung 4K TV and Epson 5020UBe. I have checked at least 4 different builds after 0916. I haven't had much luck with 3D ISOs also.
Can you post a full
debug log (wiki) in the
RPi testbuild thread?
A sample file may also be required if not obvious what is wrong from your debug log (I'll let popcornmix ask for that).
What do you think about realtek 1195 boxes based, as ew902 for example?
(2015-10-11, 10:09)langostino Wrote: [ -> ]What do you think about realtek 1195 boxes based, as ew902 for example?
Its OK.
You need to mount the Network drive with a script(password protected drives works)
You can get a cheap Realtek M-195 and flash the firmware with a Eweat firmware.
The Himedia picture quality is much better than the Realtek.
(2015-10-11, 12:17)movie78 Wrote: [ -> ] (2015-10-11, 10:09)langostino Wrote: [ -> ]What do you think about realtek 1195 boxes based, as ew902 for example?
Its OK.
And what do you think about rk3368 and amlogic s812 video quality compared to Himedia q5 (hisilicon doc)
Im using now a Raspberry Pi 2 with OpenElec 5.95.5.
How can I play MVC ISOs?
MVC MKVs works without problems but I cant make a mkv with a specific movie at 99% an error occurs and thats all.
I tried to rip it to a iso on pc and than use MakeMKV, let MakeMKV rip the bluray, but always the same error at the end.
(2015-10-11, 17:54)Kendos Wrote: [ -> ]Hi,
Pi2 running openelec 5.95.5 can play mkv mvc 3d files ripped by makemkv.
The latest development builds can also play 3d iso.
In makemkv you need to manually select the mvc file to rip with the main file.
I will try the latesst builds.
I did it in makemkv but at 99% an error occurs and the mkv file is gone.
It only does happen with a movie, all others are working great.
EDIT:
With the latest build mvc 3d iso works without a problem.
Yea the pi2 is great, it can do everything.
I still can't find a better replacement, that has more power and memory, and still can do all the pi2 can do.
(2015-10-11, 16:41)langostino Wrote: [ -> ] (2015-10-11, 12:17)movie78 Wrote: [ -> ] (2015-10-11, 10:09)langostino Wrote: [ -> ]What do you think about realtek 1195 boxes based, as ew902 for example?
Its OK.
3D playback picture quality ratings.
1-Himedia Q5 (picture setting is available)
2-VidOn box (picture setting is available)
3-RealTek M-1195 (No picture setting)
(2015-10-11, 19:33)Mylo75 Wrote: [ -> ]Yea the pi2 is great, it can do everything.
With latest builds, Pi2/Kodi is crashing after 3D ISO playback, or UI isn't coming back (no signal reported by display) after stopping playback. I've tried builds #1009 and #1010. Going to try first build with ISO support (#0916) tonight when I have some time.
Re: PQ, I'd rate the players as follows for now:
1. Pi2
2. Q5
3. X6
(2015-10-11, 21:08)hdmkv Wrote: [ -> ] (2015-10-11, 19:33)Mylo75 Wrote: [ -> ]Yea the pi2 is great, it can do everything.
With latest builds, Pi2/Kodi is crashing after 3D ISO playback, or UI isn't coming back (no signal reported by display) after stopping playback. I'be tried builds #1009 and #1010. Going to try first build with ISO support (#0916) tonight when I have some time.
Yep - they've found a number of 3D ISO bugs. The latest should be fixed in the next build.
Thanks... also, don't think chapter support for ISO (only tried 3D so far) has been added yet as well.
