Ditto! That was unexpected now and amazingly fast! Think I'll stick with MVC MKV's though. Please don't abandon support for 3D MKV's
Quote:[3d] Make MVC a valid 3D filename tag (7237707f)
[3d] Automatically enable 3D for ssif (53fd3071)
popcornmix, re: 3D filename tag, continue to use
.3D.SBS.mkv for MakeMKV rips of 3D BD's? And, for ISO's, just
moviename (year).iso?
(2015-09-17, 03:26)hdmkv Wrote: [ -> ]popcornmix, re: 3D filename tag, continue to use .3D.SBS.mkv for MakeMKV rips of 3D BD's? And, for ISO's, just moviename (year).iso?
The existing 3D tags are still fine for MVC. In addition you can now include "3D" and "MVC" in the filename to signal 3D.
(MVC is just another alternative to SBS or TAB, and doesn't affect the video playback).
You can use these tags on iso files, but as the .ssif file is easy to detect, we enable that automatically.
ISO is now supported in Pi's latest build.
(2015-09-17, 13:21)hdmkv Wrote: [ -> ]ISO is now supported in Pi's latest build.
Popcornmix meant "mvc iso" instead of "mkv iso"? and this only for raspberry pi 2?
(2015-09-17, 01:55)popcornmix Wrote: [ -> ]Latest Milhouse build has early mkv iso support.
Do you mean support for detecting MVC-3D tags in MKV containers? As described here:
http://forum.kodi.tv/showthread.php?tid=227862
Does this also mean that you will probably be adding detection of "Mpeg4-MVC-3D" tags for Blu-ray 3D video files/ISOs too soon?
Don't know; will let popcornmix reply. I understood it as 3D ISO now plays back as frame-packed 3D (with filename having MVC in it or not), along with 3D MVC MKV (MakeMKV's rip of a 3D BD), which was already supported (with filename having 3D.SBS or now MVC).
(2015-09-17, 13:52)RockerC Wrote: [ -> ]Do you mean support for detecting MVC-3D tags in MKV containers? As described here: http://forum.kodi.tv/showthread.php?tid=227862
No, that was a typo. The build supports playing 3D MVC from an iso container. No change to mkv tag reading (that would need ffmpeg support and I haven't looked into that).
Suppose a new RPi3 comes out and support HD Audio the RPi will be the Ultimate Kodi Media player (for Me).
What's the use of MVC-3D tags?
MVC streams are detected at ffmpeg stream level...
(2015-09-17, 17:30)popcornmix Wrote: [ -> ] (2015-09-17, 13:52)RockerC Wrote: [ -> ]Do you mean support for detecting MVC-3D tags in MKV containers? As described here: http://forum.kodi.tv/showthread.php?tid=227862
Nice job guys (also for zidoo and kodi devs)
Might this translate in a further stadium to have kodi native support for 3d iso?
(2015-09-17, 17:42)Koying Wrote: [ -> ]What's the use of MVC-3D tags?
I think that is too late for setting the stereoscopic flags (used in skin, or for switching GUI to 3D mode when starting playback).
