Hi Jeroen
First of all I would like to say thank you very much for making such a great skin available to us, I would also like to say thank you for taking the time to reply.
I can follow everything you are saying and have done exactly what you instructed previous to your reply. I did make a new entry to the Refocus's
Includes.xml to reference the "ViewsVideoCaseWrap.xml" and considering there is no "ViewsVideoCaseWrap.xml" in the Refocus 720 folder this makes things easy as there is nothing to overwrite so I just simply copy it over . The view id for the "ViewsVideoCaseWrap.xml" is 543 which again is a bonus as the Refocus's MyVideonav.xml =
<views>50,51,52,521,522,53,531,54,541,57,571,574,575,576,592</views>
So I simply add the 543 to the list and add <include file="ViewsVideoCaseWrap.xml" /> to the Refocus's "MyVideoNav.xml"....but thats where the simple stops. Not trying to blow sunshine up your butt but all your xml's are logically laid out so even a noob like me can make sense of them. As an example in your "MyVideonav.xml" There are logically laid out headings such as:
<!---TRIGGER------>
<!---LIST------>
<!---landscape--->
Which of course lets you know what the relevant section refers to, but the other "Videonav.xml" (no disrespect to the other coder) it is all over
the map. Although I can locate where the View ID is referenced, it doesn't appear to have a logical beginning or end....at least not in my limited knowledge. Here is the pastebin of that Videonav.xml:
http://pastebin.com/TjbfCE1k
It's where that view begins and ends is where I am stuck. I do understand that the other xml uses "control type = radiobuttons" whereas Refocus uses groups but I think I can figure that piece out. Its where the view begins and ends that I can't get a handle on. I have tried multiple copy and pastes trying to insert that view into a pre existing Refocus view but without knowing the correct starting and end point for View ID 543 and short of copying the entire contents of the Videonav.xml and pasting it into the ReFocus's "MyVideoNav.xml" I have had no luck in getting this view to appear in Refocus.
I would greatly appreciate a nudge in the right direction...Thanks again in advance for any guidance.
~Metal~
