i can't go there, when i'm on key "9" and if press "UP" i goto "IP" button... mystery...
tried that too on appletv.. it just never worked for me
You can't select that mystery backspace button. You must use backspace key on keyboard or when using remote, one of the key must be programmed as backspace key (send same command as regular keyboard).
It's not intended to be a mystery button though
It should be possible to select it by pressing <right> when the textfield is focused, but apparently that's not functioning properly. Will have a look at it.
thank you,
Jeroen
please, keep us informed about this one
The keyboard navigation mapping was a total mess
I'm surprised this problem didn't surface before!
Anyway, I uploaded a quick fix
here, drop it in the 720p folder. It will be in the next release too.
You can get to the backspace button by pressing up while at the top row, or down from the bottom row.
that's a quick fix of a problem!
thank you, all works flawlessly!
Jeroen, two questions/suggestions:
1.
Would you consider darkening the font on all the white panels ?
Since they now are light grey it's hard to read whats on the panel.
2.
Could you add a buffering progress for the osd ? Like the one JezzX uses in all his skins. Instead of just a static "Buffering..." label ?
I'm not to sure if this is already possible and I've missed it. But, is it possible to have a fanart "overlay" for the main menu's like it does with movie view etc?
The-Boxhead Wrote:Jeroen, two questions/suggestions:
1.
Maybe a bit, but I think there's a pretty high contrast. I certainly don't consider it a light grey.
Quote:Could you add a buffering progress for the osd ? Like the one JezzX uses in all his skins. Instead of just a static "Buffering..." label ?
Sure that sounds good.
DPickles Wrote:I'm not to sure if this is already possible and I've missed it. But, is it possible to have a fanart "overlay" for the main menu's like it does with movie view etc?
No there's no option for that sorry.
Jeroen,
I mentioned earlier about not being able to get rid of the info footer within The Big Picture addon.
Rygrath mentioned hitting OK or Enter on the remote, but nothing happens when I do that. In fact, nothing happens when any button is pressed on the remote (aside from hitting back or the big green OSD button).
As I said before, this is not something I can control through the skin. The add-on itself would have to provide that functionality.
Jeroen Wrote:As I said before, this is not something I can control through the skin. The add-on itself would have to provide that functionality.
I'm such a dolt. I must have overlooked that post. Thanks!
Sranshaft made a very nice
reFocus skin for the
PseudoTV script. I really like the video OSD he did for that and as I was working on the OSD anyway I asked if I could port that over to reFocus.
I think it's working out nicely, I like how it will contrast better with the controls and how it brings some of the blue elements over from the UI.
Functionally the idea is to make the OSD have "tabs". So when watching LiveTV you can press on right to switch from currently playing information to upcoming TV programs (if that's possible anyway). When playing local content it could show some more detailed information on what's playing.
Quote:I'm not to sure if this is already possible and I've missed it. But, is it possible to have a fanart "overlay" for the main menu's like it does with movie view etc?
Jeroen Wrote:No there's no option for that sorry.
That's a shame. Thought that it would "unify" the skin. As some fanart just doesn't fit right. Thanks for the reply though
Jeroen Wrote:Sranshaft made a very nice reFocus skin for the PseudoTV script. I really like the video OSD he did for that and as I was working on the OSD anyway I asked if I could port that over to reFocus.
That's pretty, I really like that. Very sleek.
