2011-01-10, 23:14
All I was looking at doing was adding support for the extrafanart folder for tv shows. But couldn't find exactly where the fanart images are displayed.
supertom44 Wrote:All I was looking at doing was adding support for the extrafanart folder for tv shows. But couldn't find exactly where the fanart images are displayed.
Jeroen Wrote:...
I'll give you a sneak peek of the PVR though
Now, this is early and it won't be completely purple like that!
The programs are colored based on the genre/category of the show, but I guess my tuner isn't fancy enough to pull in the genre information or something so everything shows up the same color.
DuMbGuM Wrote:I've been having a problem not sure if it's been mentioned but it hasn't been fixed in the updates.
From the ReFocus settings menu, if I go to 'homescreen' I can then set a custom slideshow.
Problem is, if I select a couple of 1920x1080 .jpgs and return to the homescreen, sometimes it shows a crossfade effect between changing images, but some random times it just cuts straight to the next image without a fade.
Is there a way to fix this? I tried using .bmp images too to see if there was any difference. It seems to happen with the regular fanart slideshow too.
I tried playing with it's settings in IncludesAnimations.xml but the changes I made didn't fix it, really annoying!
DuMbGuM Wrote:Any possible solution for this please? :o
tungmeister Wrote:The bug with the audio options dialogue seems to be caused by using audio pass through. At a guess I'd say the issue is because the dialogue tries to focus on the volume control which is disabled when using pass through resulting in nothing in the dialogue being focused.
<window id="123">
<defaultcontrol>[color=red]5[/color]</defaultcontrol>
<include>dialogOpen</include>
Sranshaft Wrote:
IamLegend Wrote:
mstef Wrote:
HDV2 Wrote:
IamLegend Wrote:
Jeroen Wrote:
mortstar Wrote:I don't know if it is a limitation of XBMC but it's really useful to actually limit the number of channels shown (so that it doesn't turn in to a wall of information) and instead show other relevant information such as programme synopsis for the currently selected show, programme credits (if available from the EPG source), genre etc.It's not a limitation of XBMC as far as I know, and I do intend to put program information in there. It's just that anything I add besides the program title hangs XBMC for me. I might have to look into updating my XBMC build first.
Quote:Note: In updates I have seen a much nicer 'time marker' rather than the two green arrows - is a time marker possible in XBMC?I don't think so but I'm not completely sure.
BigDaddyRal Wrote:As me, my girlfriend, and various friends use the system and not all are as savvy as me, I'd really like an updated Video Info page. I love this:At some point there will be some changes to the video info screen, but it won't be too drastic (thinking about moving some of the menu functionality into the main screen area). I'd like to keep the poster it's current size though so the menu will probably stay where it is.
But would like to see the poster with it, like this:
Quote:I'd also really love to see library totals. Any implementation would be good but this version ain't bad:Library totals will be added at some point.
Quote:On a number of the views including the following one and the full screen fanart view with the grey plot bar at the bottom, I would love to have the poster:Don't think that's going to happen, sorry. I'm not too crazy about filling up the screen with multiple image types, which is why I made the option to switch between them through the alternate viewtypes.
Quote:I also love these alternate homescreens:Some sort of alternate homescreen will be added somewhere along the 0.9 series. It's put on hold at the moment as I want to concentrate on getting the PVR done first.
Quote:Finally, the four most important to me:Something like this may be added, but probably on an alternate homescreen only.
1) I really, really, want the ability to add at least 3 custom links to the front page so I can have direct links to XBMCFlix add-on, PowerDVD (launcher favorite), and Google Chrome (launcher favorite).
Quote:2) The ability to assign a single fanart image to each homescreen menu item.Both not likely, sorry.
3) Something akin to "Press down to view Trailer" on the various movie views.
Quote:4) Implementation of the Next Aired add-on inside of the TV views that show when the next episode will air (Like the Paper Street Soap Company skin is planning:I haven't looked into what is needed for something like that, but if that's possible then I'm definitely interested in adding it.
http://forum.xbmc.org/showpost.php?p=684...tcount=302).
Quote:Again, you rock. Love this skin and appreciate your hard work.No problem, thanks for the kind words
Jeroen Wrote:It's not a limitation of XBMC as far as I know, and I do intend to put program information in there. It's just that anything I add besides the program title hangs XBMC for me. I might have to look into updating my XBMC build first.
Sranshaft Wrote:Try resizing your images in the database folder to 720p. I whipped u a quick program to do it for me and it's working fine now. I can even quickly browse with fanart on without any lag.
DuMbGuM Wrote:Thanks this works, shame there's no smooth way to view the slideshow at 1080.
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: view_ListPrograms
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: view_ThumbList
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: videoLibPageLabels
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: amtIgnore
10:40:14 T:872 M:996069376 WARNING: Previous line repeats 2 times.
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: fade_Busy
10:40:14 T:872 M:996069376 WARNING: Previous line repeats 1 times.
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: amtAllow
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: focus_PosterSlideOverlay
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: Heading
10:40:14 T:872 M:996069376 WARNING: Previous line repeats 3 times.
10:40:14 T:872 M:996069376 WARNING: Skin has invalid include: typeFlag
Jeroen Wrote:I wouldn't worry about it. Those are just references to includes that have been removed at some point. I'll have to do some code cleaning for those to go away, but they won't cause any problems.
