Full Version: LibreELEC Testbuilds for x86_64 (Kodi 17.0)
New LibreELEC.tv Krypton build #0831: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.2 #1 SMP Wed Aug 31 21:05:52 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160831210440-#0831-gec9cf07 [Build #0831]
Based on tip of LibreELEC.tv master (ec9cf077, changelog) and tip of XBMC master (f39d849f, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (62b8520c, ahead +15)
  • Includes latest libnfs master (fac3a954, ahead +34)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (20c47221, +2), inputstream.rtmp (9c05b8dd), inputstream.smoothstream (b63ecbb4), peripheral.joystick (88d4aab0, +28), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (3c39bd0c, +7), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (bb9c0b10, +10), pvr.vbox (2750c92a), pvr.vdr.vnsi (40c45dc9), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Includes commits from xbmc/master, ahead +5 (FernetMenta)
  • Exclude [env] kodi-999.99-PR10309.patch: Merged upstream
  • Exclude [env] kodi-999.99-Revert-PR10247.patch: Not required
  • Exclude [env] libcec-PR208.patch: Merged upstream
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: ffmpeg: Bump to 3.1.3-Krypton-Beta3 (e9002c3)
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
  • Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
  • Include [pkg] PR:50: Update to peripheral API v1.1.0: Add function to save button maps (peripheral.joystick)
  • Include [pkg] PR:404: VAAPI / VDPAU: Add deinterlacing methods to processInfo (kodi)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:10339: VideoPlayer: fix and cleanup deinterlacing methods
  • Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
Build Highlights:
  1. peripheral.joystick updates
Build Details:
  1. LibreELEC.tv:
    • connman: fix DNS ordering (PR:681, 1 commit, 1 file changed)
    • kodi: Temporarily revert PR10247 for Kodi 17 beta1 due to OOM (PR:683, 1 commit, 1 file changed)
  2. XBMC:
    • DVDAudioCodecPassthrough: Fix memory leak after (PR:10367, 1 commit, 1 file changed)
    • Peripheral API v1.1.0: Fix mapping D-pad on RPi for some controllers (PR:10364, 5 commits, 31 files changed)
    • Break out joystick improvements from #10364 (PR:10371, 5 commits, 10 files changed)
  3. peripheral.joystick:
    • [udev] Fix rumble effect failing to play second time (88d4aab0)
  4. Additional commits/pull requests/changes not yet merged upstream:
(2016-08-31, 21:46)fritsch Wrote: [ -> ]Not really possible, but hey ...
No intel driver update between 0825 and 0830 ?
No ... nothing, besides a memleak fix only affecting passthrough. You use passthrough?
(2016-09-01, 08:45)fritsch Wrote: [ -> ]No ... nothing, besides a memleak fix only affecting passthrough. You use passthrough?
No, don't use passthrough.
Anyway, It's work like a charm now.
I'm waiting now an update on audiodsp with Libreelec. Currently, Libreelec use audiodsp 0.0.3 Version and Wisler (the developer of audiodsp) tell me that there is an update to this add-on.
Milhouse, Fritsch, it is possible to update this add-on ?
Thx Smile
Hello.
at the moment netradio-streams seems to be broken, i am using passtrough, advanced setting 48khz because of Pioneer receiver.
it is working with build #0825
does anyone got this problem too?
do i miss somthing?
thank's
(2016-09-01, 11:47)Repo1st Wrote: [ -> ]Hello.
do i miss somthing?
thank's
Nobody knows without a debug log. See note #9 in the first post.
Thank's
it was just a question, netradiostreams (tunein, ares project, shoutcast2) are working or are they known as broken.
i know you can't help without a log.
So, after trying everything else. Last working build for me is:
http://milhouse.libreelec.tv/builds/mast...cef50d.tar
It seems that something from the #0828 build and on has made video playback not work for me anymore.
Logs (build #0901):
DMESG http://sprunge.us/IjiQ
KODI http://sprunge.us/FUJO
(2016-09-01, 13:00)Repo1st Wrote: [ -> ]Thank's
Well no, they're not "known broken" but a log might give a clue whether it's an add-on issue or not. Without further evidence to the contrary we can only assume it's an add-on issue, in which case ask the add-on maintainers.
(2016-09-01, 12:38)Milhouse Wrote: [ -> ]
do i miss somthing?
thank's
@Repo1st can you test builds #0826 and then #0827 and tell me which one has problems. Post your debug log if you identify the first build that isn't working.
New LibreELEC.tv Krypton build #0901: Generic
# uname -a
Linux NUC 4.7.2 #1 SMP Thu Sep 1 21:04:10 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160901210254-#0901-gd416dad [Build #0901]
Based on tip of LibreELEC.tv master (d416dad6, changelog) and tip of XBMC master (f39d849f, changelog) with the following modifications: Build Highlights:
  1. [cmake] fix sse detection
Build Details:
  1. LibreELEC.tv:
    • init: Add upgrade check to avoid incompatible upgrades [RFC,WIP] (PR:535, 1 commit, 1 file changed)
  2. peripheral.joystick:
    • Update to peripheral API v1.1.0: Add function to save button maps (PR:50, 5 commits, 14 files changed)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:10372: [cmake] fix sse detection
I'm having a problem with 3840x2160 content - the GUI displays fine at 60hz or 50hz, but 24p content results in a blank screen (can still hear audio) with my new TV reporting that the refresh rate is out of range. Confirmed the same just by trying to change the refresh rate of the GUI.
I initially thought the problem to be my amp (Sony DN-1050) as it can only handle the passthrough at 8 bit - 60hz/50hz. Sony say "Supports YUV 4:2:0 / 8 bit format only" and the other 4k/UHD modes "Supports 8 bit format only"
http://helpguide.sony.net/ha/strdn10585/...42768.html
I've posted as such about this, but after a bit of experimentation I've noticed that when I boot into the Windows 10 half of my dual boot HTPC (Geforce GTX 1070) then I have no trouble displaying all modes at the required refresh rates so obviously the passthrough is working fine.
The other strange anomoly is that if I plug the HDMI directly into the TV then Libreelec can also display the modes correctly (I'm running your August 30th build at the moment Millhouse). In both cases the refresh rates are selectable in the video options, so LE is picking them up, albeit incorrectly it would seem when plugged in via the Sony amp.
I've recently upgraded both the graphics card and my TV (Samsung 65KU6400U) at the same time, all was working with my previous card (GTX 980) and 1080p TV (also a Samsung), but that was on OpenElec - I've just moved over due to the graphics driver issue (and enjoying Libreelec, thanks for your hard work!).
So I don't know if there's a problem with the handshaking in Libreelec or something in the Nvidia driver? I've had a mess around creating a custom xorg.conf, but to be honest it's been a long long time since I last had to do that, so I'm really needing pointed in the right direction!
Cheers.
edit: I've installed Kodi 17 Beta 1 for Windows and all files playback at the correct refresh rate. Is there anything else I can do to this Libreelec install without wiping and starting from scratch (don't really want to lose all my bookmarks and on my programmes).
(2016-09-02, 07:02)Milhouse Wrote: [ -> ]
do i miss somthing?
thank's
Hello,
Build #0827 and up is not working.
thanks
http://sprunge.us/SdRS
(2016-09-02, 10:27)Repo1st Wrote: [ -> ]Hello,
thanks
Thanks, I've added a comment on PR10236.
Unfortunately your log shows nothing of interest, you're supposed to reproduce the issue before posting the log.
@Milhouse or @fritsch did you see my issue?
Seems like either the 8bit patch or the ffmpeg bump in http://forum.kodi.tv/showthread.php?tid=...pid2403575 caused some problem with my NUC.
No one else with NUC have issues with builds from #0828 and later?
