2016-04-29, 15:14
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187
2016-04-29, 15:45
(2016-04-29, 15:01)sunnyfunny Wrote: [ -> ](2016-04-29, 13:32)b0mb Wrote: [ -> ]here is my log of GUI crash that happens with all builds after 21.04.
http://sprunge.us/WZEU
Same Problem on my NUC3700
@millhouse
can you switch back to Kernel which is used in builds before 21.04?
No, better to fix the problems by moving forwards than backwards.
2016-04-29, 17:23
(2016-04-29, 07:14)fritsch Wrote: [ -> ]Quote:[ 2.057769] Hardware name: Shuttle Inc. XH61V/FH61V, BIOS 1.05 05/03/2013
[ 2.057771] Workqueue: events output_poll_execute
[ 2.057773] 0000000000000000 ffffffff812b6f16 ffff880119f57b98 0000000000000000
[ 2.057774] ffffffff8103a756 0000000000000000 ffff880119f57bf0 0000000000000000
[ 2.057775] 000000000000003c ffff8800d0c54e08 0000000000000001 ffffffff8103a7b5
[ 2.057775] Call Trace:
[ 2.057778] [<ffffffff812b6f16>] ? dump_stack+0x5a/0x6f
[ 2.057780] [<ffffffff8103a756>] ? __warn+0xc8/0xe1
[ 2.057781] [<ffffffff8103a7b5>] ? warn_slowpath_fmt+0x46/0x4e
[ 2.057783] [<ffffffff81848087>] ? _raw_spin_lock_irqsave+0xe/0x29
[ 2.057784] [<ffffffff81378fed>] ? drm_wait_one_vblank+0x123/0x13c
[ 2.057786] [<ffffffff810636ce>] ? wake_up_atomic_t+0x1f/0x1f
[ 2.057788] [<ffffffff814e01e7>] ? ironlake_crtc_enable+0xac9/0xb90
[ 2.057789] [<ffffffff814c56d7>] ? hsw_write64+0x5/0x5
[ 2.057790] [<ffffffff814dddbb>] ? intel_atomic_commit+0x5c2/0x101c
[ 2.057792] [<ffffffff8138ae6c>] ? drm_atomic_check_only+0x273/0x52a
[ 2.057794] [<ffffffff8137127d>] ? restore_fbdev_mode+0x109/0x223
[ 2.057795] [<ffffffff81372a3d>] ? drm_fb_helper_restore_fbdev_mode_unlocked+0x2b/0x5e
[ 2.057796] [<ffffffff81372aa6>] ? drm_fb_helper_set_par+0x36/0x41
[ 2.057797] [<ffffffff81372a0a>] ? drm_fb_helper_hotplug_event+0xab/0xb3
[ 2.057798] [<ffffffff81368cc1>] ? output_poll_execute+0x12b/0x15a
[ 2.057800] [<ffffffff8104b188>] ? process_one_work+0x139/0x1d4
[ 2.057801] [<ffffffff8104b6d3>] ? worker_thread+0x1d3/0x29e
[ 2.057802] [<ffffffff8104b500>] ? rescuer_thread+0x2b6/0x2b6
[ 2.057803] [<ffffffff8104f1ff>] ? kthread+0x95/0x9d
[ 2.057804] [<ffffffff81848382>] ? ret_from_fork+0x22/0x40
[ 2.057805] [<ffffffff8104f16a>] ? init_completion+0x1d/0x1d
[ 2.057808] ---[ end trace 8421c749f3f31a64 ]---
Kernel bug with your hardware. Post your Xorg.0.log please.
Here is Xorg.0.log - http://pastebin.com/thaAyeCg
Please let me know if you need anything else!
2016-04-29, 18:10
(2016-04-26, 01:46)Milhouse Wrote: [ -> ](2016-04-25, 22:01)M4tt0 Wrote: [ -> ]Unfortunately, no success with any of the above builds. Am using a Logitech K400r wireless USB keyboard. Never had issues with that so far...
Now that you mention *USB* keyboard (rather than just "keyboard", which I assumed to mean on-screen keyboard - my bad), has this ever worked correctly with any earlier version of OpenELEC?
As far as I'm aware, OpenELEC has very limited OS localisation support, and this limited support hasn't really changed in LibreELEC.
There is a localisation change in Kodi in #0418 (PR9550, which isn't actually working as intended due to *ELEC's limited localisation support), but this change shouldn't have any effect on your USB keyboard.
@Milhouse: Gee, probably tested 10 different version until I arrived at the result.
The "wrong keyboard layout" problem for my external USB keyboard started with your OpenELEC (that is correct: OPEN) tesbuild 7.0 #1119. Debug log
All of your earlier OE builds in the "old" thread have another problem though. My USB keyboard does not work AT ALL. Debug log of latest version with this sympton here (OE 7.0 #1117).
This is contrasting my experience with my working production system which runs on the same HTPC, just from the internal SSD instead and does not have these problems.
Which leaves me to speculate that this might(!) be some kind of USB problem: On the test system external USB keyboard and USB HDD are attached (as the test system runs from there), whereas on the production system only the external USB keyboard is attached (as it runs from the internal SSD). Upstream problem with x-server? But any thoughts and advice appreciated.
2016-04-29, 18:31
I have to say running the latest build from the 28th on my chromebox and it's running like a champ. No issues that I have seen so far.
***Clearly I should not have said that as in the movie just had a black screen dropout. Will see if I can duplicate.
2016-04-29, 22:56
Just tested #0429
Seems no more gpu crash on bsw
Edit : nevermind still gpu crash
http://sprunge.us/CiBa
http://sprunge.us/bPiO
And also
A
- Left key of remote act as right key
- using addon like audio profile switcher to change audio profile (tv to avr passthrough) corrupts video (choppy, slowly, corrupted)
Log : http://sprunge.us/bZVB
And also
A
2016-04-29, 23:07
2016-04-29, 23:09
He has a fully different issue. He is running Ubuntu ... and keyboard layout change is OS dependend. Kodi's setting (not the OE settings setting) has no influence there.
2016-04-29, 23:19
Asked on his thread: The symptoms are exactly the same. Are you referring to differences in the underlying structures between an LE build and the Ubuntu version, fritsch?
2016-04-29, 23:35
2016-04-30, 00:20
(2016-04-29, 18:10)M4tt0 Wrote: [ -> ]@Milhouse: Gee, probably tested 10 different version until I arrived at the result.
Thanks for digging. In build #1119 there is an xorg server bump (deferred from the previous build due to issues - see #1117 for the commit). However since this issue dates back to these OpenELEC 7.0 builds, you should find you have this same problem in the latest OE 7.0 Beta 2 and LibreELEC 7.0 release builds - can you confirm?
Assuming this problem is present in these release builds, it should then be reported upstream.
Edit: OK just seen your last post. Good, good.
2016-04-30, 00:22
(2016-04-29, 22:56)Roby77 Wrote: [ -> ]And also
A
Yes, it's PR9656. I've pulled the build, will upload #0429b shortly.
2016-04-30, 01:00
New LibreELEC.tv Krypton build #0429b: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (ac8e298b, changelog) and tip of XBMC master (b6ddce80, changelog) with the following modifications:
# uname -a
Linux LibreELEC 4.6.0-rc5 #1 SMP Fri Apr 29 23:27:52 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160429232628-#0429b-gac8e298 [Build #0429b]
- Includes FernetMenta "VideoPlayer" patches
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (b3c41060, ahead +15)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (5cf12e83), adsp.biquad.filters (af575f3d), adsp.freesurround (6dc533be), asplib (da66f517), inputstream.mpd (2cb2eab2, +2), inputstream.smoothstream (cf95a976, +8), peripheral.joystick (76b7c40a), pvr.argustv (3a4eccd4, +5), pvr.demo (f4950d3d, +1), pvr.dvblink (41a62b12, +1), pvr.dvbviewer (735477e2, +3), pvr.filmon (0b906770, +1), pvr.hdhomerun (9b511856, +2), pvr.hts (8929c220, +4), pvr.iptvsimple (373b525d, +1), pvr.mediaportal.tvserver (4723f6de, +1), pvr.mythtv (11b70a50, +1), pvr.nextpvr (fa13c7d0, +1), pvr.njoy (aea0b8ab, +1), pvr.pctv (fc80e0f7, +2), pvr.stalker (c1d8ee73, +2), pvr.vbox (31748578, +1), pvr.vdr.vnsi (090ef7e1, +6), pvr.vuplus (ec652b92, +1), pvr.wmc (b1d7a40a, +1)
- Includes commits from xbmc/master, ahead +6 (FernetMenta)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Drop repo hack (not needed after PR9642)
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:200: switch to using libinput exclusively (x86 / Generic only)
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: kodi: use 2 buffers by default - matches disabled triple buffers
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9696: [xbmc/xbmc] [skin] save skin settings early on exit
- Revert [pkg] PR:9656: [OSX] Fix non working apple remote / universal ir remote / harmony (Reason: breaks LEFT/RIGHT)
- NOTE: DVD playback remains temporarily disabled
- #0429b: Reverted Apple remote change - breaks MCE remotes
- LibreELEC.tv:
- Linux update to 4.6 (PR:183, 11 commits, 45 files changed)
- LibreELEC addon repository: change to xml.gz (PR:175, 1 commit, 1 file changed)
- WeTek_Core/WeTek_Play: fix new cec driver patch (PR:230, 1 commit, 2 files changed)
- system-tools: initial add-on (PR:232, 27 commits, 47 files changed)
- network-tools: initial add-on (PR:233, 17 commits, 23 files changed)
- dvb-tools: initial add-on (PR:234, 6 commits, 13 files changed)
- multimedia-tools: initial add-on (PR:235, 8 commits, 15 files changed)
- fixes and picks from seo (PR:247, 3 commits, 2 files changed)
- projects/WeTek*: Fix build with Kodi 17 (PR:256, 2 commits, 4 files changed)
- tvheadend xmltv fix (PR:255, 2 commits, 2 files changed)
- rpi-tools: move depends to rpi-tools-depends (PR:236, 1 commit, 3 files changed)
- Python: fix build by including $ROOT (PR:261, 1 commit, 1 file changed)
- XBMC:
- [doxygen] add code guidelines (PR:9687, 1 commit, 6 files changed)
- cmake: Handle ENABLE_VAAPI and ENABLE_VDPAU both being disabled correctly (PR:9693, 2 commits, 2 files changed)
- [OSX] Fix non working apple remote / universal ir remote / harmony (PR:9656, 4 commits, 5 files changed)
- [pvr] - make running instance aware of changed settings (PR:9707, 1 commit, 2 files changed)
- [cmake] Cosmetics (PR:9711, 2 commits, 4 files changed)
- [cmake][linux] Insert PulseAudio block into kodi-standalone (PR:9709, 1 commit, 1 file changed)
- pvr.argustv:
- Dependencies are not needed from brew/apt-get (PR:55, 1 commit, 1 file changed)
- pvr.hdhomerun:
- Dependencies are not needed from brew/apt-get (PR:24, 1 commit, 1 file changed)
- pvr.pctv:
- Dependencies are not needed from brew/apt-get (PR:37, 1 commit, 1 file changed)
- pvr.stalker:
- Dependencies are not needed from brew/apt-get (PR:59, 1 commit, 1 file changed)
- Reverted: [pkg] PR:9656: [OSX] Fix non working apple remote / universal ir remote / harmony (Reason: breaks LEFT/RIGHT)
2016-04-30, 01:52
Anyone that reported problems adding shortcuts that were not being saved after a reboot, can you confirm if this problem is still present in build #0428 and later? Hopefully it's fixed now.
2016-04-30, 05:22
I'm having very little success
http://sprunge.us/NOiR
This lockup occurred while watching a Myth recording
I'm having lockups generally very often with the last few builds
