(2016-10-09, 21:08)Superbert Wrote: [ -> ]Hi Milhouse,
i have an audio problem.
With my Zotac ci520 Intel Core i3-4020Y there is no DTS passthrough, only DD51.
With my Zotac ci321 Intel 2961Y there is no problem with DTS.
I used build #1008.
Not entirely sure why that should be, can you provide a debug log (as described in note #9 of the first post)?
Which is the last build with working DTS on the ci520?
That is the problem, i don´t exatly know this.
The last build i remember was le 7.0.2
I will test your build out and post the results.
New LibreELEC.tv Krypton build #1009:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.1 #1 SMP Sun Oct 9 21:06:05 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161009210447-#1009-g5661f32 [Build #1009]
Based on tip of
LibreELEC.tv master (5661f325,
changelog) and tip of
XBMC master (8344d702,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (2edbd147, ahead +61)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (b45f98ff, +8), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (e842db92), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (57b546a3, +2), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] PR:759: linux: update to linux-4.8.1
- Include [env] PR:792: scripts/build: use MinSizeRel cmake build type
- Include [env] PR:796: scripts/build: cleanup
- Include [env] PR:800: xf86-video-intel: enable dri3 and make it default
- Include [env] PR:807: Network: smb & ntfs config mods
- Include [env] PR:810: path: remove regex dependency when processing packages
- Include [env] PR:812: libdrm: update to libdrm-2.4.71
- Include [env] PR:813: scripts/build: no need to setup toolchain twice and before really building
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Revert [env] PR:793: projects/*/options: disable lcdproc for all projects except Generic/Virtual (Reverted until add-on available)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
- Include [pkg] PR:10572: [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro
- Include [pkg] PR:10641: [video] fix NFO parsing of <namedseason>'s
- Include [pkg] PR:10658: support reusing of CFile::m_pFile
- Include [pkg] PR:10663: [guilib] make onclick override conditional. Fallback to default actio…
Build Highlights:
- New 4.8.1 kernel
- VideoPlayer sync and seek updates
- libnfs 1.11.0
Build Details:
- LibreELEC.tv:
- tigervnc: add icon, port setting (PR:819, 1 commit, 4 files changed)
- imx6 updates (PR:822, 4 commits, 5 files changed)
- RTL8812AU: remove debug ouput (PR:823, 1 commit, 1 file changed)
- revert "imx6/kodi: update advancedsettings.xml" (PR:824, 1 commit, 1 file changed)
- RTL8812AU: fix patch file permission (PR:825, 1 commit, 1 file changed)
- XBMC:
- [doxygen] update python listitem documentation (PR:10662, 1 commit, 1 file changed)
- X11, osx: yield to main loop after input action has been handled (PR:10664, 2 commits, 2 files changed)
- fix encrypted DVD playback fixes #16965 (PR:10667, 1 commit, 1 file changed)
- aarch64 build support (PR:10659, 25 commits, 52 files changed)
- VideoPlayer: fix general synchronize, often resulted in global timeout (PR:10668, 1 commit, 6 files changed)
- [VTB/GLES] - release CVBuffer after it actually has been rendered (PR:10652, 1 commit, 4 files changed)
- [cmake] get_filename_component(... PATH) is deprecated. Use DIRECTORY instead (PR:10660, 1 commit, 10 files changed)
- AE: Explicitely check for DTS for making settings invisible (PR:10666, 1 commit, 2 files changed)
- [xbmc][cleanup] Remove hardcoded bitness from CSysInfo (PR:10637, 1 commit, 1 file changed)
- Revert "X11, osx: yield to main loop after input action has been handled" (PR:10671, 1 commit, 2 files changed)
- VideoPlayer: fix subsequent seeks (PR:10665, 4 commits, 3 files changed)
- libnfs:
- Added: [pkg] PR:10663: [guilib] make onclick override conditional. Fallback to default actio…
So, i tested from #0801 on. No one of the versions can play dts on my ci520.
(2016-10-09, 23:57)Superbert Wrote: [ -> ]So, i tested from #0801 on. No one of the versions can play dts on my ci520.
Good, at least it's not a kernel 4.8.x issue.
There's plenty more builds available, keep scrolling down. You could also try an official release build, eg. 7.0.2, and see if that works for you - if that doesn't work then it's either a core bug (debug log please), your hardware doesn't support it (debug log please) or something else fundamentally wrong (debug log please).
Are you sure everything is configured identically to your ci321? Same audio/video/system settings, AVR/TV hardware etc.?
The debug log might help.
I tested 7.0.2. DTS works.
The ci520 is identically configured to the ci321.
edit: i also tested it with the first build #416...no dts
(2016-10-10, 00:28)Superbert Wrote: [ -> ]I tested 7.0.2. DTS works.
7.0.2 dates from 28 June 2016 and uses the 4.4.13 kernel with Kodi 16.1.
The closest equivalent of these test builds would be #0416 (4.4.7 kernel) although even that is based on Kodi 17 Alpha1.
Knowing the build when your DTS "broke" would provide some clue where to look. As would the debug log from #1009.
sorry for my edit...
Exactly from the first version #416 DTS broke on ci520.
Debug log, or no problem.
with #1009 for me at the end of the video just stops at the last frame instead of closing it and going to library. #1008 works as expected.
debug:
http://sprunge.us/XgAR
thank you
(2016-10-10, 01:03)Milhouse Wrote: [ -> ]Debug log, or no problem.
Most likely sync playback related as always.
(2016-10-10, 06:56)nuc-LE Wrote: [ -> ]with #1009 for me at the end of the video just stops at the last frame instead of closing it and going to library. #1008 works as expected.
debug: http://sprunge.us/XgAR
thank you
Thanks, I can reproduce on LibreELEC #1009 with NUC and ION2 and latest Kodi master on Ubuntu with Radeon (but not on RPi with either OMX or MMAL): play a video (in my case 720p h264, DD2.0, no passthrough, 1:36:08 long), seek to 1:36:00 and wait for the video to play out - it hangs at the end.
It seems to be due to PR10668 - without this PR there is no hang. Will post a comment on github.
Edit: This issue should be fixed in the next build.
Use # 1009
There are problems with the Seeking, the Seeking is finished according to the display and then the video jumps to the right place, and then is played in the slowmotion mode for a few seconds, likewise loses Kodi partly with the Seeding the sound and the video must first stop and again to be started
(2016-10-10, 08:10)Milhouse Wrote: [ -> ] (2016-10-10, 06:56)nuc-LE Wrote: [ -> ]with #1009 for me at the end of the video just stops at the last frame instead of closing it and going to library. #1008 works as expected.
thank you
thanks, I will test next build but looks like you guys are on top of things and very quick!
