(2016-09-19, 20:57)Milhouse Wrote: [ -> ]Then it sounds like your PC is booting perfectly, but kodi.bin is crashing for some reason.
Knowing the exact build when this problem started would help a great deal, so if you're able to work forwards from #0909 until you hit the first non-working build that would be great.
Also, can you ssh in to your box while it is running #0918 and paste the following:
dmesg | pastebinit
journalctl | pastebinit
cat /storage/.kodi/temp/kodi.log | pastebinit
If you haven't enabled ssh then you'll need to do this in the GUI while using #0909.
Milhouse,
Will do the above just not sure how to do it.
I will put the latest update on then what ?
If you can give me steps to do a log i will.
Regards Wayne.
Edit,
Milhouse,
I put a fresh install of (Krypton) v7.90.005 ALPHA and then your latest update ( 23 ) and now the box boots fine... very strange.
Thanks for all your help.
Regards Wayne.
Edit 2,
Spoke to soon now stuck on Kodi splash screen.
I think i will just go back to Kodi alpha.
Regards Wayne.
@jacko05
step 1: Activate ssh in the GUI (LibreELEC Settings -> services -> activate ssh)
step 2: Update to the latest alpha release #0923
step 3: Connect to your box with ssh (
http://kodi.wiki/view/SSH)
step 4: Paste the commands in the console one by one. After each command you'll get a link in the console (e.g.
http://sprunge.us/XYZ)
step 5: Post the links from all three commands in the forum.
I hope i could help.
Milhouse I'm getting the same segfault error, looks like i'll just have to wait for the final release. Thanks again for your help.
Should any DVD ISO navigation / playback issues be reported here or should I open a ticket at the bug tracker? I'm having issues using the Avia Home Theater Calibration disc, it has been working well in at least Kodi 15. I noticed that MPEG2 hardware acceleration is now allowed for ISO sources but disabling it didn't help.
(2016-09-24, 20:42)Boulder Wrote: [ -> ]Should any DVD ISO navigation / playback issues be reported here or should I open a ticket at the bug tracker? I'm having issues using the Avia Home Theater Calibration disc, it has been working well in at least Kodi 15. I noticed that MPEG2 hardware acceleration is now allowed for ISO sources but disabling it didn't help.
A debug log might reveal something.
Milhouse
i mean the second increase range for variables. I will test the new release with the fix. Thanks for fast answer.
New LibreELEC.tv Krypton build #0924:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.5 #1 SMP Sat Sep 24 21:05:33 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160924210416-#0924-g8a3b79d [Build #0924]
Based on tip of
LibreELEC.tv master (8a3b79d2,
changelog) and tip of
XBMC master (75547872,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (048e7737, ahead +59)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (c5ee8acd), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165, +2), pvr.argustv (87cb6780, +3), pvr.demo (01c68c88), pvr.dvblink (e842db92, +4), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c1402545, +3), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (42c91b1c), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3, +7), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7, +4), pvr.vbox (2750c92a), pvr.vdr.vnsi (dd95edef, +2), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] kodi-100.17-dbupgrade-dynamic-splash-message.patch: use upstream alternative
- Exclude [env] kodi-999.99-PR10345.patch: closed upstream, no longer required
- Exclude [env] kodi-999.99-PR10501.patch: merged upstream
- Exclude [env] kodi-999.99-PR10502.patch: merged upstream
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Exclude [env] pvr.dvblink-0001-PR54.patch: merged upstream
- Include [env] b903500b: RBP: Enable CONFIG_SND_BCM2708_SOC_ALLO_PIANO_DAC=m
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
- Include [env] patch: ffmpeg: update to ffmpeg-3.1.3-Krypton-Beta3-2
- Include [env] PR:752: linux: extra options for Baytrail and 32-bit EFI
- Include [env] PR:760: rework cmake build system and adjust build variables
- Include [env] PR:763: bcm2835: simplify
- Include [env] PR:765: linux: update to linux-4.7.5
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:30: enable samba at wizard (LibreELEC-settings)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10445: require click action to activate slider controls
- Include [pkg] PR:10527: increase property and variable ranges for skins
- Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
Build Highlights:
- New 4.7.5 kernel
- ffmpeg: update to ffmpeg-3.1.3-Krypton-Beta3-2
- Revert PVR database fix due to crashing
- Partial fix for samba always enabled (still shows enabled in GUI, but services will be stopped - fixed tomorrow PR:30)
Build Details:
- XBMC:
- [droid] disable libcec, libusb (PR:10227, 1 commit, 2 files changed)
- Revert "[osx/readme] - remove KODI_HOME bits from readme (not needed … (PR:10550, 1 commit, 1 file changed)
- Revert "Fix potential SQL constraint integrity violation in the PVR database" (PR:10551, 1 commit, 2 files changed)
- VideoPlayer: fix wav playback on win32 (PR:10552, 1 commit, 1 file changed)
- Fix some format warnings (PR:10549, 1 commit, 3 files changed)
- Bump game.controller.default to v1.0.3 (PR:10555, 1 commit, 1 file changed)
- FFmpeg: Bump to version 3.1.3-Krypton-Beta3-2 (PR:10548, 1 commit, 1 file changed)
- [mention-bot] Correct typo (e5f5951b)
- Added: [env] patch: ffmpeg: update to ffmpeg-3.1.3-Krypton-Beta3-2
- Added: [env] PR:765: linux: update to linux-4.7.5
- Added: [pkg] PR:10527: increase property and variable ranges for skins
- Added: [pkg] PR:10543: [platform] - add unique hardware identifier as info label
Just jnstalled latest build, and i get an issue with "suspend to ram", which doesnt work anylore.
I have a intel dual core with an nvidia card 520.
When i try to suspend, it freeze on a black screen and i need to do a hard reboot...
How could i get a useful log in this kind of situation ?
Bibi
Hello. The build #0924 work fine.
(2016-09-25, 09:55)bibi Wrote: [ -> ]Hi,
Bibi
What version were you using before? It's unlikely the latest build broke your standby (unless there's a bug in the 4.7.5 kernel), but one of the dozens of builds over the last few months is responsible (presumably you never tried these) - build
#0523b is known to break standby for users with old nvidia cards (after bumping the nvidia video driver).
Try the change in
http://forum.kodi.tv/showthread.php?tid=...pid2379108 - that's the only solution I have.
It did work !
I used latest stable Librelec.
Its gonna be time to change my hardware soon, hope zen/kabylake will be out soon (or a pi 4 ?) with good drivers.
Bibi
It did work !
Edi : Well not so much. With my custom xorg and legacy driver,i get no sound. With latest driver, suspend to tam doesnt work.
Bibi
