(2016-11-28, 06:17)lrusak Wrote: [ -> ]You can run the "createlog" command via ssh, then the zip will appear in /storage/logfiles
createlog worked just fine.
I got the log but how do get it to you? Tried to send you a private msg with the zip but don't see any file attach option in PM as well. Is there any specific thing we do for attaching file?
-S
Upload log to drop box, Google Drive or the likes, post like in your pm
(2016-11-28, 08:17)Milhouse Wrote: [ -> ]Can any other AMD RX4x0 users confirm the current state of play with this hardware, is HDMI sound working or not?
I don't have exactly that device but I see another issue playing video with
ATI Radeon card. This is the one I have:
VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] (prog-if 00 [VGA controller])
Subsystem: PC Partner Limited / Sapphire Technology Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] (Radeon HD 6450 1 GB DDR3)
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at fe9c0000 (64-bit, non-prefetchable) [size=128K]
I/O ports at c000 [size=256]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Legacy Endpoint, MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [150] Advanced Error Reporting
Kernel driver in use: radeon
I can hear the sound but no video at all - player starts, sound comes out but it get stuck on the same screen. Is it another issue or I'm doing something wrong/stupid?
-San
(2016-11-28, 21:13)sw4y Wrote: [ -> ] (2016-11-28, 20:54)aatoledano Wrote: [ -> ]I have an strange problem. Samba is enabled and I can browse Samba from Kodi, but I am unable to browse the libreelec folders from my PC (windows 10) with \\<libreelec IP>. So I wasn't able to browse the update folder and update libreelec. Thank god I could use WinSCP to upload the file, maybe this should be explained on the tutorials as a third alternative.
Had the same problem - this helped me out
https://forum.libreelec.tv/thread-1252.html
Problems with Samba started with version #1018 I guess, at least I first had problems since that version.
Will give it a try, thanks!
Are there known issues currently with screensavers? Here's a debug log with my attempt at using the Solarwinds screensaver:
http://sprunge.us/MFaE
I just get a black screen.
New LibreELEC.tv Krypton build #1128:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.11 #1 SMP Mon Nov 28 21:06:15 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161128210447-#1128-g4d4fe5d [Build #1128]
# Kodi version
(17.0-BETA6 Git:17.0-beta5-e92818a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (4d4fe5db,
changelog) and tip of
XBMC master (c5d944c1,
- Includes latest kodi-platform master (c8188d82)
- Includes latest kodi-theme-Estuary-next master (0d13ac4d)
- Includes latest libcec master (209884d6, ahead +60)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (7f57246b, +2), inputstream.rtmp (55437ac7, +2), peripheral.joystick (d09e0c60, +26), pvr.argustv (7d3bdba7, +2), pvr.demo (9ebc62c6, +2), pvr.dvblink (42207a03, +2), pvr.dvbviewer (2449df9a, +2), pvr.filmon (f3c57b88, +2), pvr.hdhomerun (ef45d3f7, +5), pvr.hts (4f406f4c, +6), pvr.iptvsimple (d69778ea, +3), pvr.mediaportal.tvserver (8ba6a797, +18), pvr.mythtv (b22cfa0e, +10), pvr.nextpvr (fe85f2a3, +2), pvr.njoy (3a322763, +2), pvr.octonet (8549a31c), pvr.pctv (e829beb1, +2), pvr.stalker (fd800fdb, +2), pvr.vbox (3dc55507, +32), pvr.vdr.vnsi (4b06d83e, +4), pvr.vuplus (d2c54427, +2), pvr.wmc (bffb41d4, +2)
- Exclude [env] kodi-999.01-build-lirc-for-rpi.patch: merged upstream
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.6-Krypton-Beta6
- Include [env] patch: fix LE PR:768 after Kodi PR:10973
- Include [env] patch: kodi-binary-addons: pvr.octonet initial package
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: visualization.shadertoy: update to 1.1.4
- Include [env] patch: merged upstream
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:768: kodi use cmake
- Include [env] PR:805: merge /usr like it's 2012
- Include [env] PR:951: samba: fix allocation/size on disk issues reported by Windows 8.x+
- Include [env] PR:968: busybox: add getedid script
- Include [env] PR:994: kodi-binary-addons: inputstream.adaptive replaces inputstream.mpd and inputstream.smoothstream
- Include [env] PR:997: xorg-server: add Synaptics driver if using evdev
- Include [pkg] patch: i965: Add some APL and KBL SKU strings (mesa)
- Include [pkg] PR:39: use prettyname_regex to show shortname in update menu (service.libreelec.settings)
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
Build Highlights:
- New Chorus2 web interface
- Added pvr.octonet (Digital Devices Octopus NET Client) add-on
- Added Synaptics touchpad driver
Build Details:
- LibreELEC.tv:
- packages/linux-drivers/wetekdvb: Update to wetekdvb-20161127 (PR:993, 1 commit, 1 file changed)
- XBMC:
- New default webinterface Chorus2 (PR:10989, 2 commits, 115 files changed)
- Fix GetFilter SQL for music artists, albums and songs nodes (PR:10974, 1 commit, 3 files changed)
- Song Info Dialog contributors in control list (PR:10951, 1 commit, 4 files changed)
- Fix processing of Performer/TMCL/TIPL Tag values (PR:10994, 1 commit, 4 files changed)
- [Estouchy] Song Info Dialog contributors in control list (PR:11005, 1 commit, 1 file changed)
- [estuary] sync (PR:11002, 1 commit, 107 files changed)
- [listprovider] Refresh list when job was not finished (PR:10957, 1 commit, 4 files changed)
- [DirectoryNodes] override GetChildType() for Episode DirectoryNodes (PR:11007, 1 commit, 2 files changed)
- kodi-theme-Estuary:
- inputstream.adaptive:
- fix debian packaging (PR:2, 1 commit, 7 files changed)
- cleanup (1ac4f839)
- pvr.hts:
- 3.4.10. Adpated to pvr addon api 5.2.1 (3.4.9 was just to ake it compile again). (PR:251, 1 commit, 7 files changed)
- Added: [env] patch: kodi-binary-addons: pvr.octonet initial package
- Added: [env] PR:997: xorg-server: add Synaptics driver if using evdev
(2016-11-28, 23:56)_matt_ Wrote: [ -> ]Are there known issues currently with screensavers? Here's a debug log with my attempt at using the Solarwinds screensaver:
The problem is with the addon and the way it is packaged/built for Linux in the Team Kodi repository (ie. this is not a LibreELEC issue):
15:46:32.022 T:140715961202816 DEBUG: ADDON: Dll Initializing - Solarwinds
15:46:32.022 T:140715961202816 ERROR: ADDON: Could not locate screensaver.rsxs.solarwinds.so.1.3.0
It should be reported to the add-on maintainer.
The following will fix it, al least temporarily until any future add-on update breaks it again:
cd /storage/.kodi/addons/screensaver.rsxs.solarwinds
mv screensaver.rsxs.solarwinds.so screensaver.rsxs.solarwinds.so.1.3.0
(2016-11-29, 00:45)Milhouse Wrote: [ -> ] (2016-11-28, 23:56)_matt_ Wrote: [ -> ]Are there known issues currently with screensavers? Here's a debug log with my attempt at using the Solarwinds screensaver:
We package this add-on so it's probably our issue. Not sure if we are installing symlinks or not (not sure of that's needed).
(2016-11-29, 00:49)lrusak Wrote: [ -> ]We package this add-on so it's probably our issue. Not sure if we are installing symlinks or not (not sure of that's needed).
Ah, I thought it was coming from the Team Kodi repo - my bad. And thanks.
Weekly kernel 4.9-rc7 test build #1128x:
Generic
Note: Still waiting for an updated 340.xx nvidia-legacy driver, so don't use this build on nvidia-legacy hardware.
You can confirm your Nvidia driver with:
dmesg | grep "NVIDIA UNIX"
If the reported version is 340.98 then you're using the legacy driver and will want to avoid #1128x.
(2016-11-29, 00:49)lrusak Wrote: [ -> ] (2016-11-29, 00:45)Milhouse Wrote: [ -> ] (2016-11-28, 23:56)_matt_ Wrote: [ -> ]Are there known issues currently with screensavers? Here's a debug log with my attempt at using the Solarwinds screensaver:
I tried the ShaderToy screensaver as well. It causes a restart of Kodi every time I try to preview it. Same issue?
http://sprunge.us/QdCY
Upload your crashlog (see note #4, first post)
(2016-11-29, 05:28)_matt_ Wrote: [ -> ]Sorry, Milhouse. Here it is (hopefully): http://sprunge.us/AZXe
Thanks. What version of the screensaver.shadertoy add-on are you using? I suspect the version in the repo may be incompatible, and the last version I uploaded on 1 April certainly is, so it could just be crashing due to some binary incompatibility.
I've uploaded a new version of screensaver.shadertoy
here - please install this new #1128 version and see if it works any better.
If it continues to crash, install this debug-enabled
build #1128y as this will provide a more informative crashlog.
If you also plan on using visualization.shadertoy be aware that this add-on crashes (
crashlog) quite regularly and as there's no way to report issues to the developer my advice is just don't use it.
