2016-09-25, 21:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187
2016-09-25, 22:30
New LibreELEC.tv Krypton build #0925: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (b0a1a38a, changelog) and tip of XBMC master (d51d4ae9, changelog) with the following modifications:
# uname -a
Linux NUC 4.7.5 #1 SMP Sun Sep 25 21:05:04 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160925210348-#0925-gb0a1a38 [Build #0925]
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (048e7737, ahead +59)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (c5ee8acd), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780, +3), pvr.demo (01c68c88), pvr.dvblink (e842db92, +4), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c1402545, +3), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (42c91b1c), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3, +7), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7, +4), pvr.vbox (4962419b, +2), pvr.vdr.vnsi (dd95edef, +2), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] kodi-100.17-dbupgrade-dynamic-splash-message.patch: use upstream alternative
- Exclude [env] kodi-999.99-PR10345.patch: closed upstream, no longer required
- Exclude [env] kodi-999.99-PR10501.patch: merged upstream
- Exclude [env] kodi-999.99-PR10502.patch: merged upstream
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Exclude [env] pvr.dvblink-0001-PR54.patch: merged upstream
- Include [env] b903500b: RBP: Enable CONFIG_SND_BCM2708_SOC_ALLO_PIANO_DAC=m
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
- Include [env] patch: ffmpeg: update to ffmpeg-3.1.3-Krypton-Beta3-2
- Include [env] PR:752: linux: extra options for Baytrail and 32-bit EFI
- Include [env] PR:760: rework cmake build system and adjust build variables
- Include [env] PR:763: bcm2835: simplify
- Include [env] PR:765: linux: update to linux-4.7.5
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:30: enable samba at wizard (LibreELEC-settings)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10445: require click action to activate slider controls
- Include [pkg] PR:10527: increase property and variable ranges for skins
- Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
- Include [pkg] PR:10544: [pvr] attempt to fix crashing and general failure in ChannelExists()
- Include [pkg] PR:10560: splash text improvements
- Minors
- LibreELEC.tv:
- peripheral-joystick: bump to abff316 (PR:766, 1 commit, 1 file changed)
- XBMC:
- [cmake/win32] Bump minimum CMake version to 3.6 (PR:10396, 5 commits, 3 files changed)
- [estuary] check if fanart pack is selected (PR:10556, 1 commit, 6 files changed)
- settings: provide descriptions for color management settings (PR:10296, 2 commits, 1 file changed)
- [paplayer] remove no more needed virtual CAEChannelInfo GetChannelInfo() (PR:10559, 1 commit, 3 files changed)
- [epg] fix mouse focus (PR:10558, 1 commit, 1 file changed)
- Add possibility to get information from both .nfo and scraper (PR:10259, 1 commit, 5 files changed)
- [paplayer] fix codec deinit for audio decoder add-on (was never called) (PR:10557, 1 commit, 4 files changed)
- Some improvements (PR:10522, 5 commits, 5 files changed)
- Add "userrating" so Player.GetItem can return user rating value for currently playing song (#10561) (d51d4ae9)
- pvr.vbox:
2016-09-26, 03:07
When I try to do the update for these versions through the Libreelec menu it does not work. It downloads but never installs.
Is the installation of these test updates disabled?
2016-09-26, 03:33
(2016-09-26, 03:07)artur9 Wrote: [ -> ]When I try to do the update for these versions through the Libreelec menu it does not work. It downloads but never installs.
No, include your debug log.
2016-09-26, 13:00
Quote:Does your audio work (along with suspend to RAM) without your custom xorg.conf and with the older driver?
No, i dont get the audio with my custom xorg.conf... i suspect an edid option that i use which is not available with old driver, here my xorg.conf (which works with new driver )
GNU nano 2.5.3 File: /storage/.config/xorg.conf
Section "Device"
Identifier "nvidia0"
Driver "nvidia"
Option "DynamicTwinView" "False"
Option "NoFlip" "false"
Option "NoLogo" "true"
Option "ConnectToAcpid" "0"
Option "ModeValidation" "NoVesaModes, NoXServerModes"
Option "HWCursor" "false"
# To put Xorg in debug mode change "false" to "true" in the l$
Option "ModeDebug" "true"
# To use a local edid.bin file uncomment the 4 lines below (chan$#
Option "ConnectedMonitor" "DFP-0"
# Option "CustomEDID" "DFP-0:/storage/.config/edid.bin"#
Option "IgnoreEDID" "true"
# Option "UseEDID" "false"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 26.0 - 81.0
VertRefresh 24.0 - 75.0
Option "DPMS" "false"
#1920x1080p @ 50Hz (EIA/CEA-861B
ModeLine "1920x1080@50" 148.500 1920 2448 2492 2640 1080
ModeLine "1920x1080@50" 148.500 1920 2448 2492 2640 1080 1084$
# 1920x1080p @ 60Hz
ModeLine "1920x1080@60" 148.500 1920 2008 2052 2200 1080 1084$
# 1920x1080p @ 24Hz (EIA/CEA-861B)
ModeLine "1920x1080@24" 74.250 1920 2558 2602 2750 1080 1084 $
# 1920x1080p @ 23.976Hz (EIA/CEA-861B)
ModeLine "[email protected]" 74.175 1920 2558 2602 2750 1080 1$
# 1920x1080p @ 59.94Hz (EIA/CEA-861B)
ModeLine "[email protected]" 148.350 1920 2008 2052 2200 1080 1$
# 1920x1080p @ 25Hz (EIA/CEA-861B)
ModeLine "1920x1080@25" 74.250 1920 2448 2492 2640 1080 1084 $
# 1920x1080p @ 29.97Hz (EIA/CEA-861B)
ModeLine "[email protected]" 74.175 1920 2008 2052 2200 1080 10$
# 1920x1080p @ 30Hz (EIA/CEA-861B)
ModeLine "1920x1080@30" 74.250 1920 2008 2052 2200 1080 1084 $
Option "UseEDIDFreqs" "False"
Option "ExactModeTimingsDVI" "True"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nvidia0"
Monitor "Monitor0"
# Option "ColorRange" "Full"
# Option "ColorRange" "Limited"
# Option "ColorSpace" "YCbCr444"
# Option "ColorSpace" "RGB"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1920x1080@50" "1920x1080@60" "1920x1080@24" "1920x$ EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
2016-09-26, 16:17
(2016-09-26, 13:00)bibi Wrote: [ -> ]Quote:Does your audio work (along with suspend to RAM) without your custom xorg.conf and with the older driver?
That's why I asked if you had audio *without* your custom xorg.conf - ie. is your custom xorg.conf causing the problem?
I'd suggest starting from scratch with your custom xorg.conf, changing/adding only what is required.
2016-09-26, 20:51
2016-09-26, 22:29
Yep,will try when im back from holydays ?.
Another thing i noticed : when your are in tv guide, if you press exit you dont go back ln home screen, you have to go on channel list then press exit. Dont know if its a desired fonctionnality or an issue...
Thanks Milhouse for your work !
2016-09-26, 22:32
(2016-09-26, 20:51)Buzzzzer Wrote: [ -> ]Maybe you know, what your patch fixed it and upload or PR it into master ?
Not with any certainty - there have been too many changes. One possibility would be PR10400, added in #0904 and #0905 (it took a couple of attempts to get it right).
Try the recently released 7.90.006 - this approximates to build #0916.
The last build you tested, 7.90.005, approximates to build #0821.
You could test with #0903 and then #0905 - if the stutter is present in #0903 but not in #0905 then PR10400 is the likely fix.
Otherwise if you really wanted to, you could work it out by trying each build from about #0815 until the stutter disappears.
As for uploading into master... no need.
2016-09-26, 22:37
(2016-09-26, 22:29)bibi Wrote: [ -> ]Another thing i noticed : when your are in tv guide, if you press exit you dont go back ln home screen, you have to go on channel list then press exit. Dont know if its a desired fonctionnality or an issue...
Assuming this is with stock Estuary best to check/post in the Estuary issues thread.
2016-09-26, 22:57
(2016-09-26, 22:32)Milhouse Wrote: [ -> ]006 I tested before writing here. Same issue.(2016-09-26, 20:51)Buzzzzer Wrote: [ -> ]Maybe you know, what your patch fixed it and upload or PR it into master ?
On 911 and later include 925 all ok.
Tomorrow I will test all. Tnx.
2016-09-27, 03:00
New LibreELEC.tv Krypton build #0926: Generic
Based on tip of LibreELEC.tv master (e726b1a3, changelog) and tip of XBMC master (a3ba702f, changelog) with the following modifications:
# uname -a
Linux NUC 4.7.5 #1 SMP Mon Sep 26 22:13:39 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160926214715-#0926-ge726b1a [Build #0926]
- Includes latest addons: inputstream.mpd (c5ee8acd), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780, +3), pvr.demo (01c68c88), pvr.dvblink (e842db92, +4), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30, +4), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (845479b6, +10), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3, +7), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd, +8), pvr.vdr.vnsi (dd95edef, +2), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Include [env] PR:770: xf86-video-nvidia-legacy: update to xf86-video-nvidia-legacy-340.98
- xf86-video-nvidia-legacy: update to 340.98
- Various PVR add-on fixes
- LibreELEC.tv:
- XBMC:
- [depends] Bump openssl to 1.0.2j (PR:10565, 1 commit, 1 file changed)
- pvr.hts:
- Drop duplicate "script: make" from .travis.yml (PR:243, 1 commit, 1 file changed)
- pvr.mediaportal.tvserver:
- Various fixes for Coverity reported issues (PR:47, 10 commits, 16 files changed)
- pvr.vbox:
- Don't add a guide programme if the title is "String format is not supported" (PR:135, 1 commit, 3 files changed)
- Fix a bunch of assorted CLion warnings (PR:136, 1 commit, 5 files changed)
- Don't query channel streaming status in IsRealTimeStream() (PR:140, 1 commit, 1 file changed)
- Support channel icons from the backend again (PR:143, 1 commit, 1 file changed)
- Don't access global setting variables directly (PR:142, 1 commit, 1 file changed)
- bump version to 3.5.0 (c966c5fd)
- Added: [env] PR:770: xf86-video-nvidia-legacy: update to xf86-video-nvidia-legacy-340.98
2016-09-27, 03:27
This weeks 4.8-rc8 kernel release, #0926x: Generic
As usual, this build swaps the Chris Wilson patch for the 4K patch. It does not include the LSPCON patch. It is built with gcc-6.2 (regular builds are with gcc-5.4). In all other respects, same as #0926.
2016-09-27, 19:34
I tried to update version 0806 to version 0926 on a Chromebox. The update failed, reporting that a partition was too small.
What is the best approach to update to 0926. I probably need to do a clean install, but I haven't seen any full installs for the Milhouse builds.
Recommendations?
Recommendations?
