(2016-06-19, 13:29)fritsch Wrote: [ -> ]Quote:10:37:02 41.596378 T:140398538233600 ERROR: ## LibreELEC Addon ## oe::download_file(http://milhouse.libreelec.tv/builds/mast...481b3d.tar, /storage/.kodi/temp/update_file) ## ERROR: (HTTPError())
10:37:02 41.598064 T:140398538233600 ERROR: Traceback (most recent call last):
File "/home/neil/projects/LibreELEC.tv/build.LibreELEC-Generic.x86_64-8.0-devel/LibreELEC-settings-168c183/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/oe.py", line 284, in download_file
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
File "/usr/lib/python2.7/urllib2.py", line 437, in open
File "/usr/lib/python2.7/urllib2.py", line 550, in http_response
File "/usr/lib/python2.7/urllib2.py", line 475, in error
File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain
File "/usr/lib/python2.7/urllib2.py", line 558, in http_error_default
HTTPError: HTTP Error 404: Not Found
That's a wait for network issue.
Yes Milhouse solved
I attached to the same post logs for you
Quote:Jun 18 23:03:53 LibreELEC kernel: [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "HDMI-A-1"
Jun 18 23:03:54 LibreELEC kernel: had: snd_intelhad_open: HDMI cable plugged-out
This is from your boot config txt:
Quote:drm_kms_helper.edid_firmware=HDMI-A-1:edid/edid.bin
Try:
Quote:drm_kms_helper.edid_firmware=HDMI-A-1:edid/edid.bin video=HDMI-A-1:1920x1080@50D
So just appending the video= additionally, don't forget the last D it's not a typo
Ok i will follow oe custom guide and append line with your mod
Thank you as always for your support
fritsch line appended
http://sprunge.us/ccLH
Now if the screen keeps black after syslinux i don't see libreelec kodi logo but after 10 second kodi gui is loaded!!!!
(In log still see hdmi plugged out)
You are a God!
Test it for some days, please.
Is there a better way to force 1080p50Hz as via autostart.sh? It seems that his is causing my chromebox to display a black screen after resuming from suspend.
New LibreELEC.tv Krypton build #0619:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Sun Jun 19 21:21:42 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160619212021-#0619-gc6c222d [Build #0619]
Based on tip of
LibreELEC.tv master (c6c222dc,
changelog) and tip of
XBMC master (08ec69b1,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (cdd1643c, ahead +28)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (0a099728, +19), inputstream.smoothstream (99b9c3c3, +1), peripheral.joystick (2db8029e), pvr.argustv (e536f32e, +1), pvr.demo (01c68c88, +1), pvr.dvblink (5f9872ca, +1), pvr.dvbviewer (35902f5d, +1), pvr.filmon (efd379b8, +1), pvr.hdhomerun (a71e816d, +1), pvr.hts (ac2e3be6, +5), pvr.iptvsimple (1ea1f36e, +1), pvr.mediaportal.tvserver (369b0189, +1), pvr.mythtv (9141c6fc, +1), pvr.nextpvr (7ed3111c, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1, +1), pvr.stalker (acba9f12, +1), pvr.vbox (b24c3cac, +1), pvr.vdr.vnsi (5d5bb64e, +2), pvr.vuplus (c988f849, +1), pvr.wmc (ef4cf3b1, +1)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: binary-addon: inputstream.rtmp
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:432: build: start using .libreelec-unpack
- Include [env] PR:433: libreelec: use build project directory for ccache
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
- Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- Bump lirc to 0.9.4
Build Details:
- LibreELEC.tv:
- imagemagick: update version (PR:463, 1 commit, 1 file changed)
- lirc: update to 0.9.4 (PR:449, 4 commits, 18 files changed)
- XBMC:
- Updated Hungarian strings for XBMC and Confluence (PR:3, 2 commits, 2 files changed)
- [EPG] Misc cleanup & fix for async epg events not respecting epg lingertime (PR:9997, 6 commits, 5 files changed)
- [depends] jpeg lib isn't used anymore (PR:10002, 1 commit, 1 file changed)
- [depends] rtmpdump commit version fa8646d (PR:9996, 1 commit, 1 file changed)
- Move AudioDSP Sources (PR:9994, 7 commits, 41 files changed)
- Fix 1000 warnings (PR:9857, 1 commit, 13 files changed)
- Fix RPi settings xml after settings shuffle (PR:10003, 1 commit, 1 file changed)
- [addons] package size metadata (PR:9971, 6 commits, 14 files changed)
- [aml] Make CEGLNativeTypeAmlogic compatible with Amlogic S905 SoC (PR:10005, 1 commit, 1 file changed)
- [xbmc][fix] Fix dll hooking for VS 2015 update 3 as there's some changes incoming (PR:10009, 1 commit, 1 file changed)
- [addons] Preserve strings which are not string ids in enum lvalues (PR:8271, 1 commit, 1 file changed)
- inputstream.mpd:
- pvr.argustv:
- [lang] updated language files from Transifex (e536f32e)
- pvr.demo:
- [lang] updated language files from Transifex (01c68c88)
- pvr.dvblink:
- [lang] updated language files from Transifex (5f9872ca)
- pvr.dvbviewer:
- [lang] updated language files from Transifex (35902f5d)
- pvr.filmon:
- [lang] updated language files from Transifex (efd379b8)
- pvr.hdhomerun:
- [lang] updated language files from Transifex (a71e816d)
- pvr.hts:
- HTSP v25 additions (PR:230, 4 commits, 8 files changed)
- [lang] updated language files from Transifex (8d710909)
- pvr.iptvsimple:
- [lang] updated language files from Transifex (1ea1f36e)
- pvr.mediaportal.tvserver:
- [lang] updated language files from Transifex (369b0189)
- pvr.mythtv:
- [lang] updated language files from Transifex (9141c6fc)
- pvr.nextpvr:
- [lang] automatic syntax corrections for the en_GB language file (c38311ae)
- [lang] updated language files from Transifex (7ed3111c)
- pvr.pctv:
- [lang] updated language files from Transifex (12d8baf1)
- pvr.stalker:
- [lang] updated language files from Transifex (acba9f12)
- pvr.vbox:
- [lang] updated language files from Transifex (b24c3cac)
- pvr.vdr.vnsi:
- [lang] automatic syntax corrections for the en_GB language file (4f7c5d19)
- [lang] updated language files from Transifex (5d5bb64e)
- pvr.vuplus:
- [lang] updated language files from Transifex (c988f849)
- pvr.wmc:
- [lang] updated language files from Transifex (ef4cf3b1)
"libreELEC settings" - "system" is blank from #0610 to last build, #0609 is OK. is that normal?
(2016-06-20, 00:26)john.cord Wrote: [ -> ]Is there a better way to force 1080p50Hz as via autostart.sh? It seems that his is causing my chromebox to display a black screen after resuming from suspend.
See what I suggested to Roby77 - this will force kms to 50 hz. And additionally you can use an xorg.conf with the 50 hz mode as Preferred Mode.
I just hooked up a 15 year old USB Soundblaster LIve, and it worked out of the box hahaha. I hooked it up to my Odroid C2. Love this!!
(2016-06-19, 17:06)fritsch Wrote: [ -> ]Test it for some days, please.
Yes i will do, thank you again
I opened a bug on freedesktop about it
(2016-06-20, 08:27)fritsch Wrote: [ -> ] (2016-06-20, 00:26)john.cord Wrote: [ -> ]Is there a better way to force 1080p50Hz as via autostart.sh? It seems that his is causing my chromebox to display a black screen after resuming from suspend.
I did this but after wake up from suspend the used mode is 60Hz. With this changes Kodi shows 50Hz in the Menue but used mode is 60Hz.
(2016-06-20, 08:22)startv Wrote: [ -> ]"libreELEC settings" - "system" is blank from #0610 to last build, #0609 is OK. is that normal?
No, not normal. If you'd posted your debug log that would help.
It's probably due to a corrupted (or now incompatible) setting of some kind - hard to say without a log. Try deleting the settings and restarting:
rm /storage/.kodi/userdata/addon_data/service.libreelec.settings/oe_settings.xml
systemctl restart kodi
You'll then need to reconfigure anything you had configured in the Settings add-on (hostname etc.)
(2016-06-20, 12:08)john.cord Wrote: [ -> ] (2016-06-20, 08:27)fritsch Wrote: [ -> ] (2016-06-20, 00:26)john.cord Wrote: [ -> ]Is there a better way to force 1080p50Hz as via autostart.sh? It seems that his is causing my chromebox to display a black screen after resuming from suspend.
Show me your xorg.conf. Remember: Suspend is pure luck and nothing in kodi makes it work correctly.
Was
PR:9731 removed in yesterdays build due to issues or was it just forgotten? If it was forgotten could it be added back to future nightlies?
