Full Version: LibreELEC Testbuilds for x86_64 (Kodi 17.0)
New LibreELEC.tv Krypton build #0618: Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Sat Jun 18 21:27:51 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160618212631-#0618-gf481b3d [Build #0618]
Based on tip of LibreELEC.tv master (f481b3d2, changelog) and tip of XBMC master (7a3b106e, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (cdd1643c, ahead +28)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (77af35f9, +18), inputstream.smoothstream (99b9c3c3, +1), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
  • Includes commits from xbmc/master, ahead +5 (FernetMenta)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: binary-addon: inputstream.rtmp
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:432: build: start using .libreelec-unpack
  • Include [env] PR:433: libreelec: use build project directory for ccache
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
  • Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
  • Revert [pkg] PR:9999: [CHG] Settings - Library: groupings (reason: breaks newclock5)
Build Highlights:
  1. inputstream.mpd updates
  2. No lirc bump in this build
Build Details:
  1. LibreELEC.tv:
    • chromium: enable build from clean (PR:460, 1 commit, 1 file changed)
    • hyperion: update to d2f4725 (PR:446, 3 commits, 6 files changed)
    • mono: create addon (PR:404, 5 commits, 14 files changed)
  2. XBMC:
    • [depends] remove libmodplug as it's now a binary add-on (PR:9995, 1 commit, 2 files changed)
    • [lang] handle disabled language addons in migration (PR:9969, 1 commit, 2 files changed)
    • Fix misc compiler warnings. (PR:9998, 1 commit, 4 files changed)
    • [CHG] Settings - Library: groupings (PR:9999, 2 commits, 2 files changed)
  3. inputstream.mpd:
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Reverted: [pkg] PR:9999: [CHG] Settings - Library: groupings (reason: breaks newclock5)
Tried to update 617>618 using your built in addon ...no luck
(Click on build but it doesn't install)
(2016-06-18, 23:48)Roby77 Wrote: [ -> ]Tried to update 617>618 using your built in addon ...no luck
Need a debug log.
(2016-06-18, 23:40)Milhouse Wrote: [ -> ]Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
Why?
OK I've traced this error to the Generic releases.json file - it's updated now and you should be able to update after rebooting (to ensure you've downloaded the new releases.json file).
(2016-06-18, 22:16)Milhouse Wrote: [ -> ]
(2016-06-18, 19:31)CandyLuv Wrote: [ -> ]Also is there an addon for "Official releases".
The forked version is the only option for now.
OK I understand.
I Tried installing the fork v0.0.5 and I can go into configuration but when trying to launch I'm getting error "LIBREELEC DEV UPDATE ERROR
Check the log for more information"
The Openelec version still works so not sure what's causing my problem with this one.
Any additional help will be greatly appreaciated
(2016-06-19, 02:16)Milhouse Wrote: [ -> ]
Worked well for me, thank you!
(2016-06-19, 03:10)CandyLuv Wrote: [ -> ]Hi,
OK I understand.
Not sure. I don't support either version of this add-on, so a separate thread might be an idea where you can then discuss the issue(s) in more detail, providing your log etc. (as per the error message etc.).
Although once we have the update via Settings add-on working reliably, there will be less demand for the Dev Update add-on.
(2016-06-19, 01:20)qp9013625 Wrote: [ -> ]
Why?
Cause we want Audio in Sync and have a default buffer level of 2 set. No need that the driver renders as many frames as it wants at an undefined time.
@Milhouse downgraded to 0617 and tried again still no luck, kodi log uploader also crashed so if you want i can share only log via dropbox
Ok this is the log
http://sprunge.us/fQFU
@fritsch did you see my xorg log ?
http://forum.kodi.tv/showthread.php?tid=...pid2360520
(2016-06-19, 10:25)Roby77 Wrote: [ -> ]@Milhouse downgraded to 0617 and tried again still no luck, kodi log uploader also crashed so if you want i can share only log via dropbox
Ok this is the log
Argh. releases.json updated again. Please reboot and try again - should work this time.
Yes works! Thank you
Could be useful like oe/libre dev update a pop up that confirm update was installed
Ok this is the log
No - was unreadable for me. I asked you to use sprunge instead.
Quote:10:37:02 41.596378 T:140398538233600 ERROR: ## LibreELEC Addon ## oe::download_file(http://milhouse.libreelec.tv/builds/mast...481b3d.tar, /storage/.kodi/temp/update_file) ## ERROR: (HTTPError())
10:37:02 41.598064 T:140398538233600 ERROR: Traceback (most recent call last):
File "/home/neil/projects/LibreELEC.tv/build.LibreELEC-Generic.x86_64-8.0-devel/LibreELEC-settings-168c183/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/oe.py", line 284, in download_file
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
File "/usr/lib/python2.7/urllib2.py", line 437, in open
File "/usr/lib/python2.7/urllib2.py", line 550, in http_response
File "/usr/lib/python2.7/urllib2.py", line 475, in error
File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain
File "/usr/lib/python2.7/urllib2.py", line 558, in http_error_default
HTTPError: HTTP Error 404: Not Found
That's a wait for network issue.
(2016-06-19, 13:29)fritsch Wrote: [ -> ]
Ok this is the log
These are uploaded to sprunge
