Should we be able to push this over an existing OE beta?
Nevermind, saw in the RPI thread you can.
I will try tomorrow...
Did you already add your 16-235 patch ?
ops i searched using 16-235 keyword
thank you!
Installed #0416 and working great out of the box so to speak.
But I have come across a puzzler.
After installing a few addons and customising appearance, audio no longer works.
None of the audio settings have changed in any way and I can't see how any of the addons (mainly video) could have an effect.
Not something I have come across before and wondered if this kind of thing has been seen before elsewhere.
Generic versions Can be used with a NUC I assume? (Read something about RPi)
Sent from my iPad
(2016-04-17, 04:18)Bluesmanuk Wrote: [ -> ]Installed #0416 and working great out of the box so to speak.
We also cannot - as we have no crystal balls and cannot see your
Debug Log without you posting it.
16/04 build seems to break ARGUS TV PVR Client:
Quote:07:31:26 21.839180 T:140276106520320 ERROR: UpdateAddons - failed to create add-on ARGUS TV client, status = 1
Downgraded to 14/04 build and it seems to work fine again. Can get full debug log if needed
(2016-04-17, 08:55)fritsch Wrote: [ -> ] (2016-04-17, 04:18)Bluesmanuk Wrote: [ -> ]Installed #0416 and working great out of the box so to speak.
We also cannot - as we have no crystal balls and cannot see your Debug Log without you posting it.
I wasn't asking for anybody to have a crystal ball.
Just making a basic enquiry to see if it may be a common problem that may already have a solution.
I will quite happily post a debug log such that it can be analysed.
(2016-04-17, 09:17)Bluesmanuk Wrote: [ -> ]Just making a basic enquiry to see if it may be a common problem that may already have a solution.
Not aware of any such problem, but maybe a combination of various addons will cause it so we'll need a full debug log to understand what you've installed.
(2016-04-17, 11:46)Milhouse Wrote: [ -> ] (2016-04-17, 09:11)smiffy1989 Wrote: [ -> ]16/04 build seems to break ARGUS TV PVR Client:
Full debug log please
Here you go:
http://sprunge.us/efUa
EDIT: and just in case it helps, here's a debug log after downgrading back to the 14/04 build:
http://sprunge.us/OJEh
(2016-04-17, 13:10)smiffy1989 Wrote: [ -> ]Here you go: http://sprunge.us/efUa
EDIT: and just in case it helps, here's a debug log after downgrading back to the 14/04 build: http://sprunge.us/OJEh
Can you test the last OE build,
#0415 and see if you can reproduce the issue with that build?
Based on your #0416 log the addon seems to have a problem communicating with the back end:
12:06:41 21.099127 T:139802921920256 DEBUG: AddOnLog: ARGUS TV client: URL: http://192.168.1.10:49943/ArgusTV/Core/Ping/60
12:06:41 21.105751 T:139802921920256 ERROR: CCurlFile::Exists - Failed: Failure when receiving data from the peer(56) for http://192.168.1.10:49943/ArgusTV/Core/Ping/60
12:06:41 21.105930 T:139802921920256 DEBUG: CCurlFile::OpenForWrite(0x7f2658218070) http://192.168.1.10:49943/ArgusTV/Core/Ping/60
12:06:41 21.110489 T:139802921920256 DEBUG: AddOnLog: ARGUS TV client: Empty response
12:06:41 21.110600 T:139802921920256 ERROR: AddOnLog: ARGUS TV client: Ping failed... No connection to Argus TV.
The most obvious change in #0416 would be PR9621. I could try reverting that in a test build a bit later today.
